Moderator
Polished some items under hood...
i was bored today like usual. and i killed an hour doing a little polishing under the hood. i am going to go back over it all and do ALOT more work on the computer thing so it shines.
all i used was blue magic with a terry cloth. then when i was all done. i did one last clean wipe down with a polishing cloth. before ![]() ![]() after ![]() ![]() ![]() ![]() ![]() ![]() ![]() like i said, its only an hours time for all that, so it can def. be better! |
The Blue Pwns Joo!
Re: Polished some items under hood...
Sexy! Little touches and attention to detail like that can really make a truck stand out...
Whats up with your grille though? |
looks good man!
engine looked pretty decent to begin with too which always helps... lol at least compared to mine anyways
I'm Back!!
i LOVE blue magic, that stuff is the SHIT!Looks awesome for an hours worth of work, alot better than mine when i first started. Hey Chris, here is a tip on polishing the computer. you probably already know this but....
but yeah it turns out like a mirror ![]() ![]() |
Moderator
No More Chrome
needs some mud
I AM CANADIAN
I use the same Blue Magic, works good. I gotta try the dremel though, good tip!
www.Barstoolsports.com
can u guys post a pic of this blue magic stuff? i got some Irocs for free today and i want to polish and paint them and then try to sell them.
Here's a link. http://people.consolidated.net/cargo...talpolish.html
3/4 down the page (#400) is what I think most people use. |
I'm Back!!
I use this stuff
I AM CANADIAN
Mine looks like this...
..but same stuff. |
Moderator
I'm Back!!
well that other stuff is liquid (never used it though) and the stuff i use is a cream so for me its easier to spread on a polishing tip or a part.
I AM CANADIAN
it says liquid but comes out as gel like, I donno why
thanks guys... i cant wait to clean up these irocs i have and make some money off them... im gonna see how this works if not ill have to bust out some wetsanding skills over the winter. now im torn on which wheels i want to run.
Will that stuff work on like an aluminum edelbrock intake and maybe some other dull metals
It will work on anything aluminum or that can be polished. The Edelbrock intake will need to be sanded smooth before polishing.
started on mine the other day... gonna do the dremel thing because doing it by hand sucks!!! looks alot better already tho..
Good Bye SonomaST
one of mt friends did this with his Camaro SS. Thanks for reminding me Chris, I'm gonna do mine too. And werd on the Dremel, ill post pics when i get done
Good Bye SonomaST
ok i got started today, it looks better than when i started, but i have some corrosion i guess on the PCM and a little on the ABS module. I'm guessing the best way to get this off is gonna be to wet sand it with some really fine paper then polish?
I got my ABS fairly shiny, my AC lines are fairly shiny, and my PCM in one spot is pretty shiny, and my EVAP canister i hit the top real quick, it looks like its gonna shine up pretty well. I'm using Mothers and my dremel and a terry cloth(wash rag haha oops), I need to get a terry cloth and a polishing cloth. Any other ideas to make it go a little quicker or is patience a virtue here? lol |
I'm Back!!
yeah, depending how worn down the metal is is how much your going to be sitting there.
mother's works fine, i used it before but on the A/C condenser (evap, accumulator, whatever you call it) you do not need to wetsand it, the surface is fairly smooth. on the ECU and ABS module you need to wetsand with 800 grit, then 1500 grit, then polish. dont forget to apply some polishing cream on the dremel wheel every now and then, also it wont hurt to spread some on the part your polishing with your finger (light coat). after awhile you have a lot of black residue, just wipe it off and repeat. pretty much it took me awhile to get mine where it is now, its not going to shine like a mirror after the first pass with the dremel. but the better you wetsand now, the less work for you later. also if you have the 2.2 you have the option to polish the T-stat housing ![]() |
Good Bye SonomaST
cool, i was thinking about hitting it with a wire brush to get the majority of it off, then sand it and polish
for the 1.5 hours i spent on it today the stuff doesnt look to bad, but i have more to do, i want it to shine one more thing, with the dremel u get splatter all over crap, how do u get all that shit off? Last edited by 91sonomast : 09-07-2008 at 11:19 PM. |
#24 |
Moderator
i need to get back on all my stuff. still havent messed with it since i did the first session.
#25 |
I'm Back!!
just get some sandpaper, a spray bottle, and a Popsicle stick (to wrap the sandpaper around to help with tight spots) i put wayyy more than 1.5 hours into mine, maybe like 8 hours, i lost count really, but not all at once. i would polish it and i would re-polish it a day or two later. also with the dremel i get some splatter but if you keep the coat on the dremel light you wont get much. it would be a good idea to keep the speed down on the dremel on the first initial pass, then you can put the speed up for the final pass (not final but before you wipe everything down to start over) what i would suggest is to get an old rag or towel and lay it around the work area. but to get it off DAWN dish soap works well, or just a wet paper towel with dawn dish soap. I really need to do a how-to with lots of pics and maybe a video of the process. Last edited by beandip : 09-08-2008 at 06:40 AM. |
#26 |
Keepin' it Gangsta!
Location: Levittown, PA-☆-NE Philly-☆-Trenton, NJ-☆Tha 19057 Bitches☆ User is: OffLine |
Looks so good...makes me wanna get off my ass and do some!
I painted alot of those harder to polish things such as the comp... |
#27 |
I AM CANADIAN
looks good bean!
#28 |
def looks better. Those certain parts sure stand out
#29 |
Minitruckin' 4 life!!!
Nice!... I did the same thing the other day with mine, but I did it by hand. I think tonight, I'll use my power ball.
#30 |
forum idiot
that has to be the worst siren location ever....jesus.. you should take it off and throw in threw the window of the shop that did that.. jesus...even on my worst day with no sleep i would not do that shit...christ... i am so disgusted right now
oh and why are you polishing things? dont you have betterthings to do? |
#31 |
I'm Back!!
I dont see a siren
, unless the pic was removed. |
#32 |
Top right corner of the engine bay... I had to search for it as well.
#33 |
The Blue Pwns Joo!
I wouldn't say its in the absolute worst spot for the siren... its position is what would concern me - should have the 'mout' pointed down.
I usually try and hide them to the lower left of the brake booster or tucked in on the rad support. |
#34 |
forum idiot
yeah when i do s-series i hide them in the front bumper or on the rad support...nice and loud when they are up front...that one is in a shit location and if someone does open the hood with it going off it is in a nice location for them to shut it down real quick...mine they have to remove the grill and the headlight to get to it and its wires...
#35 |
#36 |
forum idiot
#37 |
Moderator
#38 |
"Ass kisser" ![]() |
#39 |
forum idiot
#40 |
forum idiot
![]() i cant take the grill off since the lights are mounted to the bumper...but you get the idea |
#41 |
Moderator
![]() im moving mine their tomorrow. thats a good hidden spot. plus i never thought that if it actually did get stolen/broken into they could pop the hood and cut the wire to kill sound. Last edited by Wicked Mayhem : 10-10-2008 at 09:48 PM. |
#42 |
forum idiot
dont tell me they screwed it in and then bent the siren over?
#43 |
Moderator
nope.. they didnt bend it over...
the hood did when they closed it ![]() didnt bend it very much, but still. shitty ass install FTL |
#44 |
A bit OT, but I noticed you don't have your "heat shield" anymore?... does that effect the paint?... I wanted to take mine off, but I was afraid of what might happen to my paint, due to the extreme tempratures caused by the motor, and other things.
#45 |
forum idiot
that foam thing under the hood? i dont think any of my trucks had them after they were painted....the sonoma, 2 door blazer , red 4 door...only one that has it is the white blazer...
never had a problem... |
#46 |
Moderator
no problems with not having it.. it was kinda torn up and muddy as **** from when it was lifted.
bout to go and move my siren |
#47 |
Moderator
here you go brian..
where i had it.. ![]() how the dumb ass alarm people had it, nice and out of the way! ![]() where it is now ![]() ![]() |
#48 |
forum idiot
good for you!!
#49 |
forum idiot
mine is a little higher
#50 |
Moderator
yeah i had an existing hole from my ballast when i had hid's. so i used that hole. i want to add like sirens on each corner lolllllllllllll
