zq8sdime
pin stripe removal??
Id like to remove the pin stripes on my 1st gen, im wondering if i can just spray some goo gone on them and then peel them off?? Will this work? I posted a topic on the body molding removal and im thinking that almost the same technique is needed here.
thanks, andrew |
Hyundai Owner
Location: Rotterdam, NY (Albany area) User is: OffLine |
Autobody stores sell a stripe removal tool that mounts on a drill. Its made of rubber and supposedly doesnt hurt the paint.
I am NOT a Post Whore!!
itll look better once you do it, post pics
wher ma bags
mine a painted on.. guess i should take my s10 somewhere to get them removed? i was planning on getting it painted a brighter red later.. should i wait?
It's called a Eraser Wheel made by 3M. It works great .
I'm going to remove my stripes also (on my 2000 S10, not 1st gen)... so
a: how much does mr. 3m eraser wheel cost?, and b: is taking it off myself a problem, because mine seems to be coming up easy, but there's a residue i need to wash off... which brings me to my last question... Can I get that residue off by just some hot soap water? What have you guys experienced in your pin stripe fiascos. Thanks. |
2.2 drifter
the eraser wheel is fairly cheap, cant remember the cost, but i had stickers on my truck and that takes it right off, you could do it yourself if you have a dril, and there was no residu on mine, just came off like nothing.
Xtreme Dreams..
The stripes on my s-10 Xtreme cam off so easy, all I did was start at the door and work my way front, and then to the rear, cleaned up the area with alochol and put a fresh coat of wax, came up crystal clean, I have a black truck, and if you do also take your time and peel slow, so you don't leave too much residue behind.
Most pinstripes could just be pulled off. It's easy, just slowly peel it back.
It' wasn't me !
Re: i also need advice
Works slick ! |
Use the 3M no matter how easy it seems, this will be tons quicker & keeps the paint perfect. Just did it on a 95 Z28 that had a thick- gay-pinstripe on it. Took it off so easy it was rediculous & kept the paint perfect as they claim!!
Check out this website it had great tips on e n body work that you can do urself. http://www.goodspeedmotoring.com/?page=decalremoval
thanks
hey guys thanks, your info helped me out too.
now... what to do about the chevy, and s10 logos on the tailgate... should they stay or go... hm. |
