painting frame
i was just wondering if there was any special paint that ur supose to use when painting ur frame i was just getting all the surface rust off it and i am just going to paint it black agin i was thinking about using the spray on truck bedliner stuff they have in spray paint cans at like walmart i dont know if that would help keep rust away any better than just a regular flat black paint but do u guys have any ideas on whut i should use ?
Canyon Carver
Re: painting frame
Do a search on por15
or I used Eastwoods Chassis Black on mine... http://www.s10forum.com/forum/f30/quick-project-185675/ |
RUB A DUB
Re: painting frame
por 15 and products will help u also house of color has products you can use..
Re: painting frame
I would NOT use the spray on "bedliner" stuff from WalMart. I have Duplicolor's version of the stuff on my bumper and it is no stronger than regular 'ol paint.
ZR2 member
Re: painting frame
I just used the cheap 99 cents a can stuff from Walmart.Done the fenderwheels and frame on the black truck I had once a year.Usually in spring after couple rains had washed all the salt off the roads.
5" closer to hell
Re: painting frame
rustoleum with rustoleum primer - they make a "Stops Rust" series of paint. works perfect and it lasted thru a pennsylvania winter so far. pressure wash the frame if you can before you paint it
Re: painting frame
por15 link |
IT DONT STOP BITCHES!
Re: painting frame
