older paint... make her shine
I've got an 88 blazer and i was wondering how (besides painting it again) to make her shine like new. i've been told it has a lacquer finish.. what products/ technics can be used? i did a search but couldn't find anything on this topic.
Re: older paint... make her shine
If it is the stock original paint you are pretty much screwed. But buy a buffer and some compound and compound the truck and then wax it and it will shine better than it did before.
NOTE: Don't press to firmly with the buffer or you will melt the paint and keep the speed of the buffer in the middle. Most range from 1-6 and I keep mine at 3-4 and it does a great job on the paint. |
Searching no more
There are also probably a lot of contaminants and dirt in your clear coat. To remove these, use a clay bar, preferrably something like Mothers California Gold clay bar. Make sure to follow the directions carefully. I can guarantee that you'll notice a big difference after you finish that up and wax it with a buffer. It may not be perfect or close to stock, but it will be a lot better than it is now.
I hate my truck.
If you still have plenty of clear left (I'm guessing that its pretty thin on that old of a truck by now) you could lightly wet sand the entire truck then buff it with a light compound, then polish, then wax...Would look better then stock. But on an older car/truck you have to be extremely careful to not burn through to the paint or you'll be re clearing the truck lol.
all these guys are right but buffing like he said let the buffer do the work and if ur gonna wet sand be VERY careful i personaly wouldnt wet sand because of the age but if u do make sure its light
Its probably a single stage paint so a good chemical cleaner product should help out bring back the shine. Not guaranteed though. Depends on how bad the paint is. Even if it does come back, it doesnt mean it will stay that way for a while. Try using mothers or Megs 3 step system for easily obtainable products. A buffer will help but isnt a necessity (sp?).
a buddy of mine said something about orange peal?? what is that and is it even safe for my paint? and if so how do you use it?
Searching no more
sorry, had to chuckle a second. Orangle peal is the bumpy surface that you often see on painted surfaces, especially vehicles. Most factory paint jobs should not have orange peel in them. It's mostly custom jobs that you find orange peal in, and it's almost unavoidable in urethane finishes. It's called orange peal because it looks similar to the surface of an orange...bumpy and rough. |
not true ^ my stock paint is full of it,
I hate my truck.
Yeah prety much every stock vehical is FULL of orange peal. Its sad when you pay $40k for a car and get a $300 macco style paint job lol.
Searching no more
But yeah, orange peal is almost unavoidable in any paint job, but it CAN be avoided, it just takes a lot of work. |
