#51 |
I.G.'s FTW!
Re: motor cleaning HOW-TO with lots of pics!
I took my inner fenders out and repainted them semi gloss black, looks a lot better. There are 2 rivets holding the d.s. one on, so that made it a little harder to get off, GM is stupid. |
#52 |
i wouldnt undertsand
and yeah the insulator isnt needed. ive always left it on my other vehicles cause i never kept under the hood clean, except for my luv. but they didnt come with it haha |
#53 |
The How-To Guy
Location: Cache, OK User is: OffLine ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
so yeah i guess its just to keep the noise down then, looks like i need to remove mine then
#54 |
I.G.'s FTW!
#55 |
your mom was great!
if your engine catches on fire it will melt the little round plastic tabs and it will drop on the motor to slow the fire. |
#56 |
will detail for food
be careful of just soaking everything under the hood with degreaser. I typically find the paint to be considerably thinner under the hood. (not just on our trucks) spraying degreaser (simple green, purple power, etc) will eventually thin the paint and remove it after a few times, if not the 1st time.
I don't recommend hitting the paint under the hood with a pressure washer either. your best bet is to knuckle bust it and use some rags, preferably, microfiber.... happy detailing |
#57 |
#58 |
a standard hose will work good.
For the degreaser, make sure it is diluted correctly. Spray on, let dwell for a minute or two, agitate with a microfiber towel, then rinse. NOTE: make sure the fenders (outer) stay WET! Degreaser will leave "runs" in the paint. you do not want degreaser just sitting there doing damage, so, better safe than sorry and keep the paint wet. |
#59 |
I needs paint!
ok, i got motivated to this. I used GUNK as the degreaser. Good how-to Nota
#60 |
I.G.'s FTW!
I've gotta get around to doing mine.
#61 |
The Werk Truck
Location: Huntington Beach, Ca. User is: OffLine ![]() ![]() |
Hey Nota, The water neck on my truck exploded a couple of years ago and covered the engine with dex cool remnanats. Is there anything out there that can help me get it off? It's kinda stubborn around the cast aluminum pieces and on some of the plastics.
#62 |
I.G.'s FTW!
^ try a scotchbrite pad, that worked on my cast parts when I had the same problem.
Ok I did mine last night, notice the nasty firewall: ![]() ![]() and after cleaning it with Simple Green, notice that $15 cold air intake, god that thing gave me like 50hp, still gotta armor all it better and next time I wash it I'm going to use gunk to clean it up a little better: ![]() I would have painted the A/C clutch, but I've gotta get a new one anyway. I also had a bad squeek from the serpentine belt or setup and I already had a new belt. I sprayed some WD-40 on the belt and all the pulley and voila it quit instantly. Last edited by ZQ8 Blazer : 08-08-2008 at 10:29 AM. |
#63 |
The Werk Truck
Thanks Man! ^
MAnual Labor! I don't mind it so much when it's for something I want to do. LOL ! |
#64 |
I.G.'s FTW!
If it's bare cast iron, you can also start off with steel wool
#65 |
be careful when using degreasers if the motor is hot, some degreasers are flamable... one dealreship burnt down the whole car wash last year because of a degreaser fire.....
also if you have "rust" type of stains on plastic or painted surfaces or anything fron a hose bursting or something scrubbing bubbles and a terry cloth do wonders... i detail cars for my dad's used car dealership and you just get to know helpful little stuff like that |
#66 |
The Werk Truck
^Thanks man!
#67 |
snow camo!!
great how to man.....i plan on doin this when i get the truck back!
#68 |
Chat Bitch
That's why you start with a cold motor. Notice that you're not spraying the motor hot with water, either. |
#69 |
United by individuality
i have everything to do mine except two things... time and a hose lol looks good
