i need help cleaning my glass?????
Old 05-19-2007, 07:21 AM   #1
!!!!!!I **** speel!!!!!!!
Paidfor's Avatar
the back 3 windows are facorty tinted (ex.cab) the prob. is that the side windows are water spotted and i cant get the shit off. all i have a club sticker witch i had for 4 or 5 years on the back. i know if i take it off it will still be there. i had one of them fake an-tenna,s on he back window for like a summer and i can still see where it was. is there anyway i can get the water spots off and hopefully get the burn letters off the back window. i have try many thing
rubbing acholhal
baking soda/water
invisable glass
carb cleaner
rubbing compound
even used the buffer to get the shit off and no go any help would be apprecated.
Old 06-03-2007, 09:12 AM   #2
Window Licker
thunder94's Avatar
Re: i need help cleaning my glass?????
try vinegar, that should get the water spots off.
Old 06-03-2007, 09:26 AM   #3
yeah yer mom liked it
low-s-dime's Avatar
and spell check
Old 06-03-2007, 09:36 AM   #4
Window Licker
thunder94's Avatar
Spell check what???
Old 06-03-2007, 10:08 AM   #5
In The Dog House
Rondog's Avatar
Not you.
Old 06-03-2007, 03:01 PM   #6
I RIDE LO
Kovz's Avatar
paint thinner or claybar
razor blade and goo gone for the back sticker stuff
Old 06-05-2007, 08:15 AM   #7
under construction
twelvam's Avatar
white scotch brite pad and some windex man......that will get your windows completely perfect and looking like brand new....
Old 06-05-2007, 09:48 AM   #8
Ticket Magnet
Rhotpursuit's Avatar
Glass shop...cerium oxide>all
Old 06-13-2007, 02:07 AM   #9
Banned
i think my spots are under the tint, which sucks balls
Old 06-13-2007, 09:51 AM   #10
didimakeyascream's Avatar
if its outside u prolly wont be able to get it off.. could be acid rain also.. if its inside, than its either under the tent or something was sprayd inside that faded spots on the tent..
Old 06-13-2007, 10:08 AM   #11
Ticket Magnet
Helllooooooo...is anybody listening?? Cerium oxide WILL take care of the waterspots. I use it all the time.
Old 06-13-2007, 04:36 PM   #12
i might not be water spots, if its acid rain u wont be able to get it off very easy.. i havent tried cerium oxide on acid rain either tho
Old 06-13-2007, 09:26 PM   #13
Ticket Magnet
If cerium oxide will take out scratches I would guess it will fix acid rain spots.
Old 06-13-2007, 10:04 PM   #14
Paidfor's Avatar
where can i get some of the cerium oxide at?? it ant in the glass or in side. its the out side. if you spray your windows and wait for the sun to dry it. that is what i got on my windows. but it dont come off. i tryed everything said above but the oxide??? ill get some and try it but i have no clue what it is little lone where to get it. let me thanks
Old 06-13-2007, 11:16 PM   #15
My self esteem is lower
get layed's Avatar
If I remember correctly from other threads, go to a glass shop and just ask for a rag with cerium oxide on it...(asking politely) Something like that....Not sure where else you can get it ?
Old 06-13-2007, 11:38 PM   #16
Ticket Magnet
You can get it at glass shops. It come a tub about the size of a butter container.
Look here
Old 06-13-2007, 11:45 PM   #17
Classifieds Nazi
2dxtreme's Avatar
http://www.unelko.com/store/product.php?productid=16135 glass scrub by unelko works excellent. my dad had some acid rain spots on his dodge like no tomorrow and i used that glass scrub and it was a night and day difference. just some elbow grease and water and ur done. i bought mine at o-reilly auto parts
Old 06-14-2007, 12:04 AM   #18
Ticket Magnet
I tried that when I ran out of c/o...worked ok but not nearly as well. It does smell good tho...
Old 06-15-2007, 06:12 PM   #19
mb252's Avatar
Try some wire wheel cleaner. No joke. It has some type of acid in it that takes water spots off windows and paint. We used some on a SS Silverado and it looked brand new. The kind we used was called wire wizard or something it's in a white spray bottle. Wear gloves and put some on a rag. Do a small area at a time. Make sure you keep the area soaked with the stuff, and rinse the area off and then dry it. It doesn't work as well if the panel is wet. It may take a couple of tries but it really does work. Just make sure you rinse everywhere the stuff touches, and DON'T LET IT DRY ON THE PAINT.
Old 06-23-2007, 06:30 PM   #20
I have heard that a mixture of soapy water and Bar Keepers Friend sink detergent does wonders on windows.....
John
Old 06-24-2007, 01:32 AM   #21
for a "homemade remedy" approach, you can try Bon Ami. I used this after searching for a while on the net to get rid of smears from the wiperblades in the rain (even new ones) I haven't used a window cleaner that does a better job then this stuff and its only 79 cents a can at the grocery store.
BMW had a service bulletin suggesting the use of Bon Ami to remove anything and everything from old pitted windshields that dirt and grime could not be scrubbed out with conventional methods.
Old 06-24-2007, 08:55 PM   #22
ohhhh yeahhhhh
rrray88sdime's Avatar
claybar works, and so doesnt that 'invisible glass' stuff with a razor blade
Old 06-24-2007, 10:58 PM   #23
Where can this Bon Ami be had?
John
Old 06-25-2007, 02:52 PM   #24
John
Go to your local supermarket and take a look there. It should be available in the cleaning section... you need to buy the Bon Ami cleaning powder... not the polishing cleaner. the polishing one might scratch your windshield.
Just remember, cleaning powder
http://www.faultless.com/bonami.asp You can see the difference in packaging here.
BMW Service Bulletin
Bulletin Number: 61 02 94 (3990)
Noisy Wipers, Poor Cleaning: Group 61 Electrical
Woodcliff Lake, NJ
May 1994
Product Engineering
SUBJECT:
Windshield Wipers Are Noisy Or Do Not Clean Properly
MODELS:
All
Situation:
Windshield wiper blades may start to make noise, or fail to clean the windshield properly, even though the blades are not worn and are properly adjusted.
This can be caused by contaminants on the glass, such as oily road deposits or wax residues from car washes. These contaminants can cause the blades to chatter across the glass or fail to wipe cleanly.
Correction:
Common contaminants that are not removed by conventional glass cleaner can be cleaned with Bon Ami(R), a household cleaning product.
The cleaner should be applied on a wet cloth or sponge and the windshield must be thoroughly and evenly scrubbed. Wipe off residue with a clean,dry cloth before the product dries on the glass.
Warranty Status:
Information only.
Additional notes
There appear to be some imitation products, or lesser versions of Bon Ami. Make sure you are buying the real product. Faultless Starch Company has the rights to sell it in the USA. Up in Canada, it's sold by the S.C. Johnson Company. If you have other questions for them, call them directly at:
Faultless Starch/Bon Ami Company
Kansas City, MO 64101-1200
+1 816 472 4987
+1 800 821 5565
Old 06-25-2007, 08:16 PM   #25
Thanks dude...
Old 07-05-2007, 05:44 PM   #26
Making the ladies cry.
I use some stuff called finess. You could try most rubbing compounds. Rub it on the window and take some fine steel wool and rub it in good. Take some window cleaner and clean them off.
This is what we did when I worked for a detail shop. worked good.
Old 07-05-2007, 06:10 PM   #27
ASASN8
bladehines's Avatar
painters trick, use XXXX steel wool! should clean the window very good, and no it won't scratch it!
Old 07-05-2007, 10:31 PM   #28
Day Dreamin
lohenslohe's Avatar
I kind of don't want to steal this thread, but I'm having a problem with my glass too. It appears that the prvious owner didn't bother to tape up most of the windows or didn't do a good job of it so there's all this primer (I'm guessing) all over the windows, I used a razor blade to take most of it off, but it's very tedious, to get off with that blade. My friend told me there's a compound or something I can use to get it right off, but I don't remember what it is called. Again sorry for doing this in this thread.
Old 07-15-2007, 01:47 PM   #29
99SonomaHeavenS's Avatar
claybar....
Page generated in 0.63014 seconds with 31 queries
[Output: 139.36 Kb. compressed to 128.05 Kb. by saving 11.31 Kb. (8.11%)]
