Token Black Minitrucker
How to remove....?
How can I remove this double sided tape off the window seal without sitting there all day picking at it? Its a real pain, i just took the window bug deflectors off it came with and I can't get this crap off. Any Ideas?
Duh!
Re: How to remove....?
when i worked at a body shop awhile back we used a rubber eraser attached to a drill. takes it right off. might also use some laquer thinner to help loosen it up then use maybe a regular eraser like one of those big pink ones for pencils.
i tried goo-gone, didnt work....just made everything all sticky......
You can however try paint thinner. It should do the trick without drying out the rubber.
Wannabe Dragger
I had to take stickers off my windows when I first bought my Blazer (there were probably around 20 purple sparkly paw prints total covering the back windows and side rears lol) and I went to use Goo Gone or whatever. I read it though, and it says it can eat off paint. Being that it might drip down onto my paint that kind of scared me. Plus, we used a little bit and kept it off the paint and it barely did anything anyways. I ended up using regular WD-40 and it worked perfect. Came off pretty damn quick, it was just a little bit of a pain to get all the WD cleaned up, otherwise it leaves greasy streaks.
I RIDE LO
i just removed my whole body kit that had double sided tape around the whole entire truck. I used one of these rubber eraser wheels. I got the whole truck done in 30-45 minutes. They are amazing! and it didnt burn the paint at all!
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT But I would be a little hesitant on using it on the rubber. just be careful that it doesnt burn the rubber or melt it. If you dont want to use that, get a putty knife (plastic blade)... or rub your thumbs raw... |
yeah, im gonna need to figure somethin out cause its botherin me....
Wannabe Dragger
Did you try any of the suggestions yet?
wd40, dumb suggestion...lol
eraser, didnt work.... scrubbed like a dog, nothing.. that smess is buggin me.. this stuff is thick, not just a sticker |
Wannabe Dragger
lol Sorry it was a dumb suggestion, but what did the WD-40 do? It worked perfectly for me.
where's my chippy?
brake fluid worked for me, just careful not to get it on ur paint or itll eat through
forum idiot
Wannabe Dragger
Brian, was your sticker or whatever you removed on paint or on glass?
forum idiot
goof off works pretty good, but I have only used it on paint.
Former S10 enthusiast
Does anyone know where i can get the set? lmc?
I RIDE LO
did you actually use an eraser wheel on a drill or die grinder? You need the speed to remove it. you can just use a regular pencil eraser... lol
lol, i tried wd40, just made it all greasy and stuff, dont have a eraser wheel.
its on the molding so i cant really scrape at it..... check out my project thread (below) |
I RIDE LO
go to a real auto store (not autozone), and buy an eraser wheel. You won't regret it.
alright, ill do that tommorrow...thanks....ill let you know if it works
SK Whut !?!
dont use the eraser wheel.. it will burn the rubber up and make it look worst.. get some thinner and a rag and take your time.. rag with thinner on it and rub it on the spot with the glue.. then take your nail and scrape the glue off.. thats how i did mine and mine are all cracked apart..
thinner will crack the molding probably and its 2 sided tape, not glue....
#24 |
#25 |
Umm... that's a 3m tape mostlikely. Doesn't 3m have an strong adhesive remover in a spray can anymore its like $5-7 if they still sell it at home depot. That's what I used to get rid of the badges, stickers, and door moldings. I'm not sure what that does to rubber but fine on paint.
#26 |
Panda s10 driving mofo.
i had the same problem. i used a razor blade. if you do....go slow. like so slow. if not you'll **** them up.
i got in a hurry. you're right its not like the 3m tape...its hard and wierd. |
#27 |
full coverage, and a BB gun.
#28 |
I've got ventshades I want to remove on mine....waiting to see what he ends up doing before I delve into my own nightmare.
#29 |
#30 |
look mine had those same visors when i bought it....
you really dont need any kind of product. your gonna get blisters but dont be a bitch about it. get in there and rub at it. IT WILL ball up and fall off. when one finger starts to hurt use the next. u dont wanna use any products? there goes your solution.... dont tell me it doesnt work cuz ive done it plenty.... rub away til your little hearts content. in my experience goo gone helps along a lil, but mainly rubing. the heat from the friction causes it to ball up. im sure anyone of these product work too but posting up about how they dont wont make the tape fall off. get out there and bust ur ass. Last edited by CubanSDime : 07-21-2008 at 01:36 AM. |
#31 |
I RIDE LO
yeah, that oops crap doesnt work at all. I bought that and goo gone to take off my tape from my body kit.
Like the other dude said, use your thumbs and rub it off. Otherwise, get a rubber wheel and go to town. Just be careful not to burn the rubber with it. |
#32 |
Something I just thought of. Whenever I debadged a vehicle and had a lot of that tape left behind. I would use Good Gone in conjunction with a small plastic squeegee. The Goo Gone would act as a lubricant as well as helping to remove the stuff. The plastic squeegee is something like you would use to install a clear bra or headlight protection. I bet that would help you. I may even break down and give it a shot on mine.
Thought I would throw that out there. |
#33 |
i know yuor just tryin help or whatever but i was posting that it didnt work because it was a suggestion, i asked for products to make the job easier so i didnt have to rub my fingers bare. not everyone is all big and bad like you buddy. calm it down, ill get it off in due time, no rush...the trucks all hacked up right now anyway |
#34 |
#35 |
SK Whut !?!
#36 |
#37 |
GET THE ERASER WHEEL!!! i used mine on rubber and never hurt nothing..
#38 |
No More Chrome
3m eraser wheel. It doesnt burn the molding ive had to take off broken vent shades at work and thats all weve ever used. Our body shop guy was the one who told us to use it.
#39 |
It's 4:20 Somewhere!
I had visors on my truck when I bought it and used Mineral Spirits to remove the left over sticky's. Worked great.
