"BUILT-NOT-BOUGHT"
How in the
%#$! do I get off old window tint??
My new project witch is an 89,has that old purple window tint on it & its allready off in spots & I want that $h!& gone!! |
Re: How in the
Razor blade.
"BUILT-NOT-BOUGHT"
Re: How in the
Yeah,but want it scratch my windows??
I'm Back!!
Re: How in the
as long as you use a new blade i wouldnt worry about it.
Re: How in the
Not if you are careful.
Re: How in the
Shops out here charge like $3 - $5 per window to remove the tint. Well worth it to me to have them handle it.
my lower toy
Location: Dartmouth, Nova Scotia, Canada User is: OffLine |
Re: How in the
Bon-ami cleaner softensup the glue and makes it easier.
Re: How in the
i have also heard put a black plastic garbage bag over it and put it in the sun helps loosen it a lot. peeling the film off itself isnt too bad to do. Its the getting all the residue off.
Re: How in the
just make sure the razor blade is level with the window. Its the corners of the razor blade that are going to scratch your windows.
Ginger army
Re: How in the
I used to tint windows and have removed window film on plenty of cars. wait for a warm, preferibly a hot day and let the windows bake in the sun so it softens up the glue and then use a razor blade or fingernail and pick at the top to get it started and it should peel off as you pull,but it will leave the glue behind. If that doesnt work use a sharp razor blade and scrape it off. to get the glue off, fill a spray bottle with warm water and a little bit of dish soap and spray the window and scrape the residue off. Older window tint tends to be brittle and a pain in the ass, but you should be fine on a hot day.
"BUILT-NOT-BOUGHT"
Re: How in the
Word..........thanks!!
Get on your bike and ride
Re: How in the
Re: How in the
Re: How in the
damn i need to move... seriously though a tint job here is about $250 easy! that's removing old tint and putting on new..
Re: How in the
Heat gun works well to soften it up, but when you pull the tint down pull soft and even. I saw a guy at work pull his off after getting pulled over and he did it all pissed off, pulled to hard, pulled the glass to far and broke the window. Take your time.
Re: How in the
When scraping with a razor, ALWAYS use a clean, sharp, new razor, and soak the area with soapy water first (dish soap). We use this when we're cleaning windows at work.
If it gets really bad, use Ronsonol lighter fluid. It gets sticky stuff right off (gum out of carpet and hair, stickers off of things, etc). Walmart carries it in the smoker's checkout lane. It looks like the middle thing in this picture: ![]() Last edited by philipalan : 08-04-2007 at 03:43 AM. |
