"SHOW TIME PRIME"
How Do U Get Scratches Out Of A Lexan Window?
These windows are junk. i got one and it got scratches in it quick so i called fbi up and they said use the novus 3 step cleaner/scratch remover so i tried it and it put a shit load more in it.Does n e one kno how to get the scratches out that actually works?
bagged1
Re: How Do U Get Scratches Out Of A Lexan Window?
Make sure your using a good towel.
Only things I know of for lexan is the Novus line, and Plexus. |
SVT Cobra Moderator
thats one of the downfalls and swirls will get you
"i got that slap"
I used the Novus 2 & 1 products with a wool pad on my electric drill. In thirty minutes I had both of my Civic lens looking like new, same on S10 and Camry. Both Civic lens were quite yellow. I know that's now Lexan, but the product is a good cleaner. I believe rubbing by hand would be quite time consuming and less productive than using the drill.
UNBANNED BITCHES!!
using a high speed buffer INCORRECTLY. tis the ONLY way to get "swirls"(not micro scratches=marring) |
"SHOW TIME PRIME"
i wasnt usin a buffer tho. i used the novus stuff and from what ive seen is some bullshit. it says its stactic free clean but if i rub my arm against it u can here the poppin like u would if u got shocked by some metal. and i figure that the scratches werent really scratches. there are some there tho but the swirls looked like residue left over from the novus stuff butt i can get it off no matter how much o rub it with those cloths it came with.
UNBANNED BITCHES!!
i can help u with this problem but id rather threw PM's.......
quick way to work around this problem is to TINT the window. |
X-10 4 LIFE
or buy a new one
