Does NOT Work For CIA
How do I remove Oil and Grease From White Paint?
After spending 2 years getting my ride in working order, the paint has suffered horribly. greasy hand prints, all worked into the scratches and finish and will not clean.
I have tried cleaner waxes, rubbing compounds, even tried Gojo hand cleaner. no luck. anyone have any tricks I could attempt? Thanks, -Bill |
Re: How do I remove Oil and Grease From White Paint?
I know ppl use purple power degreaser on flat paints/primers .. THOUGH IF you do it your gonna def wanna do a good wax/buff after you u do .
slowly, but surely.
claybar?
carb cleaner
I'm slap happy, bitches!
nah, go to bath and body works, and get some good glycerin soap.
that will lift the oil, but if it is stained, you will need some westleys bleach white, and a good wax. |
Panda s10 driving mofo.
spitfire degreaser cleaner. works wonders.
Is this it? I really want to clean this truck up now. thanks for all your suggestions guys. |
De-Xtremed
I've used cleaner wax in the past, it worked.
I RIDE LO
have you tried dawn dish soap? that works well for a degreaser and then make sure you wax afterwards.
Slow Roller
simple green worked for me
wd-40? I have used it on grease, and it works well
Do not put degreasers and crap all over your paint. Not good. Buff the truck. Wool or Foam pad with 3M Compound, Swirl Remover, Wax and your done.
If you want, first and you have the money go to www.autoint.com and look at their 3 step process cleaner. It's the M-32 kit on the main page. Works great and will take all the contaminants out of your paint. Follow that up by a quick buff, swirl remover and sealer and your paint will be completely clean and last much much longer with a very nice shine. Just do not put WD-40, carb cleaner, degreasers, etc on your paint it will eat at your clear and even though you will do it just a few times here and there it still is not good. Hopefully this helps some. |
Wd-40 work good for tree sap? I need to try it because I have tree sap all over my silverado and i am looking for something to take it off. I tried to claybar it but it didnt work.
