hood insulation
ok i searched but didn't find anything. anybody have any tips on cleaning the hood insulation. that fiberglass mat that is mounted to the underside of the hood. i mainly have general dirt but there is some white chemical residue as well. i have it off right now because of another project, and would just like to clean it up.
thanks for any advise. |
Useless posting member
Re: hood insulation
Try steam cleaning?
Re: hood insulation
Power washer?...just dont get real close
Re: hood insulation
really? cuz the one in my old jimmy when it got wet it basically fell apart. maybe it was just really old.
steam might be good but i don't have a steam cleaner. |
Riding High 2wd
Re: hood insulation
Yeah I wouldnt get it wet. A few years ago a oring for the heater line blew and coated the underside of my hood. After that the insulation has been sagging and the outer surface is hangin in shreds, it looks like hell. Im probaly going to just pull mine off and leave it.
needs a bigger truck
Re: hood insulation
power washer works fine.
mine hasn't fallen apart in 9 years i've owned it. |
4x4 v6 blazer
Re: hood insulation
get rid of it?
Re: hood insulation
Tweed It Ftw!
Road Racing Blazer
Re: hood insulation
What purpose does it serve other than to protect the hood paint? |
Megabyte
Re: hood insulation
Keep heat in the engine bay and not up on the bottom of your hood...where it could crack the paint on top of your hood.
Re: hood insulation
I used to work at a delta sonic (car wash place) and they did full details and what not. I am pretty sure i have seen people there spray paintin them black to make them look new/clean
4x4 v6 blazer
Re: hood insulation
I've always taken the ones off of my first gens if they have that crap and never had paint problems. My V8 truck had the factory hood and never got hot enough to cause the paint to flake or bubble up, even while I was having overheating problems with the motor.
Xtreme Measures
Re: hood insulation
I turn.
Re: hood insulation
I ditched mine for clearance reasons almost a year ago and the paint is still perfect. I didn't notice any difference in sound levels
Re: hood insulation
Xtreme Measures
Re: hood insulation
You can't polish a turd.
Location: Hawaii - stationed in S. Korea - chillin' in the Philippines User is: OffLine |
Re: hood insulation
My advise is to find a dumpster.
Blazer User
Re: hood insulation
for those that removed the insulation like me, does ur hood surface have small lines like cracks? ive been noticing more and more of those recently
Have a nice day!
Re: hood insulation
well i was thinking about removing mine, but after reading this i think i'm not going to... |
Negative 10
Re: hood insulation
Xtreme Measures
Re: hood insulation
4x4 v6 blazer
Re: hood insulation
Paint is 20 years old and besides the rock chips on nose and the clear peeling all over the middle of the hood is the best looking spot on the blazer. Mine been off for at least 6 years that I know of now. |
Re: hood insulation
I'll be a bit more clear and concise.
Step #1 Open dumpster lid. Step #2 Put hood insulation inside dumpster. Step #3 Close dumpster lid. That bit of advise was free. You're welcome. |
#24 |
Negative 10
Re: hood insulation
#25 |
Xtreme Measures
Re: hood insulation
#26 |
Re: hood insulation
at the dealership if they are not shredded up we pull them down and paint them and they look like new.....
#27 |
Re: hood insulation
See, you have options! |
#28 |
It's a Blue thing...
Re: hood insulation
![]() Kenny its like going home and shuttin the door. ![]() |
#29 |
Negative 10
Re: hood insulation
oh i get it now. hahaha.
ok seriosly tho. wouldnt taking the insulation off actually kinda help with the engine heat? it seems like the insulation would trap the heat in there. as to where if you took it off it might let it out a little better. does that make sense to anyone else? |
#30 |
where's my chippy?
Re: hood insulation
^i get where u comming from
#31 |
Re: hood insulation
just pressure washed mine 2 days ago... don't get too close, leave it to dry and don't touch it for a day. it'll be fine
#32 |
orangesonoma supporter
Location: Warren, MI -- Home of GM's Tech Center--soon to be the new GM Headquarters User is: OffLine |
Re: hood insulation
my 84 S10 came from the factory without one. as you can see in my sig still good as new.
#33 |
Re: hood insulation
I replaced mine with Dynaliner from Dynamat. It looks better than the factory one.
