head lights
i have tyc head lights for my truck. i have had them bout 1yr. they are starting to turn yellow or something. can you clean?
thanks again, tx |
Pressurized 2.2 Member
use rubbing compound its on the outside I promise its 2 bucks from anywhere you rub it ir and buff it off rub it on and buff it off run it on buff it off it will be crystal clear I bet ya a new set of headlights.
Try mothers plastic polish.
Lots of different plastic cleaners that will work great. His idea would probably work ( rub comp) because I had a crown vic that had the lights hold moisture & turn yellow. I wet sanded them back to life. Looked new. I drilled a hole in the bottom so water couldnt re-enter & one hole on the back of the light. It let small amounts of wind travel through it without letting water in & I never had moisture problems again.
