Head Lights.
Old 01-10-2008, 12:20 AM   #1
spanky1224's Avatar
Head Lights.
Ive sanded and polished my head lights but they are not as clear as my new corner lenses. Whats a really good polish for them to make them a little bit more shiny. Should I sand them some more and polish more? Thanks for the help.
Old 01-10-2008, 12:27 AM   #2
Certified Auto HVAC Tech
layinlow88's Avatar
Re: Head Lights.
did you work your way down?? starting off with a rough grit(400 maybe) and ending with a fine grit(2000 or 2500 maybe)
then use a rubbing compound(turtle wax makes good stuff)...then polish and buff
Old 01-10-2008, 01:00 AM   #3
I'm Back!!
beandip's Avatar
Re: Head Lights.
post a pic of your headlights (for visual help) also its very important that you WET sand your headlights, and just wondering what polishing compound did you use?
Old 01-10-2008, 01:03 AM   #4
layinlow88's Avatar
Re: Head Lights.
agreed...forgot to mention wet sanding...this usually takes place with the finer grits
of course...some wetsand on every grit
Old 01-10-2008, 01:18 AM   #5
I'm Back!!
beandip's Avatar
Re: Head Lights.
http://www.techguys.ca/howto/polish_lenses.html
this stuff here is great on headlights.
on headlights i would recommend it.
Old 01-10-2008, 08:43 AM   #6
spanky1224's Avatar
Re: Head Lights.
I wetsanded and then polished with a wax that i thought might work from auto zone. Its a Head light wax that is used for small scratches. It worked fair. Ill try to buff it a little or go try a different wax. Ill get some pics. Maybe Im just being a little to OCD about it. They just dont look like other s10/blazer headlights that are CLEAR! Sorry for blurry picture in a hurry out to work. Thanks guys.
Old 01-10-2008, 11:27 AM   #7
User Registered
Re: Head Lights.
I think the problem is that your clear corners are "crystal" clears and you didnt get the headlights to match. Making your headlight seem dull or less transparent.
Old 01-10-2008, 11:52 AM   #8
User Registered
Re: Head Lights.
make sure to put the lower clips off the headlight in they dont look like they are.
Old 01-10-2008, 11:56 AM   #9
Fvck New Jersey
Tim99Zr2's Avatar
Re: Head Lights.
yea, fix your headlight. brian will kill you if you dont
Old 01-10-2008, 12:00 PM   #10
I'm Back!!
beandip's Avatar
Re: Head Lights.
maybe, but they are dull nonetheless
Old 01-10-2008, 01:23 PM   #11
spanky1224's Avatar
Re: Head Lights.
Lol I did..I noticed it when I took the pictures.. Hehe..Thanks. Ok well thanks for the help guys Ill just try to polish them up a little bit then buff it out.
Josh
Old 01-10-2008, 01:59 PM   #12
ChrisNJ's Avatar
Re: Head Lights.
They dont look too bad. I'd go w/ some 4" pads on a cordless drill w/ a finishing polish at this point. Might be all it needs left.
Old 01-10-2008, 07:45 PM   #13
spanky1224's Avatar
Re: Head Lights.
Sounds good Ill give it a whirl. Thanks.
Old 01-10-2008, 09:02 PM   #14
spanky1224's Avatar
Re: Head Lights.
Will this buffer and this pad do it?
Old 01-12-2008, 10:14 AM   #15
I'm Back!!
beandip's Avatar
Re: Head Lights.
i dont see any pics, but you can polish them by hand, its not that hard.
the way your headlights look you can probably get away without sanding but if you want to really get them to shine i would recommend wet sanding.
Old 01-12-2008, 02:18 PM   #16
forum idiot
orangesonoma's Avatar
Re: Head Lights.
Old 01-12-2008, 02:20 PM   #17
forum idiot
Re: Head Lights.
get a hair cut...lol
yeah i think you have them as good as there are going to get....you have to get the diamond clear headlights to match...
Old 01-12-2008, 04:47 PM   #18
zq8fromhell's Avatar
Re: Head Lights.
you realize all that work is totally useless unless you get the lenses UV coated again correct? otherwise they will be brittle, yellow pieces of shit in about 6 months...
Old 01-13-2008, 10:33 AM   #19
I'm Back!!
beandip's Avatar
Re: Head Lights.
Well with the Blue metal polish it leaves a silicone protective film, i dont know how long it lasts but do these look like yellow pieces of shit? (done 9 months ago & pics taken 5 minutes ago)
Old 01-14-2008, 09:45 AM   #20
spanky1224's Avatar
Re: Head Lights.
Well i think my headlights are as good as they are going to get. Polished them a few more times and I did wetsand them. They are looking ok.. not as crystal clear. But They are fine. Thanks for the help gents.
Page generated in 0.66790 seconds with 31 queries
[Output: 107.71 Kb. compressed to 99.56 Kb. by saving 8.15 Kb. (7.57%)]
