Faded Mirrors, Grill & Door Handles
Just got a 99 S10 LS Extended cab.
Both mirrors, parts of the grill area and the door handles have started to fade from their original black color to a chalky gray'ish/white color. Any suggestions as to what I can apply to them to bring back the dark black color.. or am I resigned to buying all new parts? |
my lower toy
Location: Dartmouth, Nova Scotia, Canada User is: OffLine |
Hello
Try using any good sealer or glaze on these parts, Mothers or 3M both worked well for me. Still have to do it quite often tho. Works great on taillights too. But now I have handles, grille and new ss mirrors painted body color. |
Oooo. It's so tiny!
Location: Corn Flake Central i.e. Battle Creek, MI User is: OffLine |
Meguiars makes some stuff called trim detailer if I remember right. Comes in a small black squeeze bottle. Works pretty good, but you have to keep using it. Lasts a couple of washes.
http://www.meguiars.com/whatsnew/whatsnew_template.cfm |
Oooo. It's so tiny!
BTW, there's a service bulletin about fading mirrors. GM says the dealer should repaint them. Some fix.
my lower toy
Is there a choice for the color? worth a try maybe? Paint wouldn't fade a fast a the plastic.
Oooo. It's so tiny!
There's also stuff out that's a vinyl paint for flexible vinyl surfaces. Not sure about colors, I had it in black. Used it on a motorcycle seat and it lasted for the 2 years I had it. Personally, I just go with the trim detailer since there's so much plastic and rubber visible that I put it on anyway. |
CHANGE YOUR EMAIL ADDRESS
Turtle was clear coat protectant is awesome for faded black mirrors.:headbang:
I just got a '94 S-10 with the same problem. The mirrors,doorhandles and the wiper cowl were all a nice shade of gray. Buy some 3M Plastic Cleaner and 3M Plastic Polish and prepare to use some elbow grease. If you work for a little while the plastic will come back to black in no time.
3M Car Care Online Store Last edited by lil_buzzin05 : 10-20-2002 at 09:52 PM. |
GAS BREAK PiMPiN
i use armor all. Armor ALLways works!!
WoW Addict
I bought a can of black spray paint... can't I just do it that way or not? Some areas of my truck are no longer black, but the metal actually shows through.
That being on my trims and stuff... like rear window and windshield washer blades and side mirrors |
Gettin' Lucky In Kentucky
Ive heard gasoline works, but Ive never tried it.
LA Trend Setters
Meguires.... Is the only way to go, I used it 2 months ago and my mirrors are still black.. Look almost factory...
mothers makes a plastic polish called back to black it works great and takes wax off your molding too
Still 2 High
bumper black works like a charm
