Easiest way to remove stickers and emblems?
Old 04-15-2004, 04:57 PM   #1
The One & Only
Phantom's Avatar
title says it all. I want to take some emblems off that the previous owner had put on. To be exact it is on the back window. It is one of those <>< fish emblems. Pretty small, maybe 2-3 inches wide. Just want to know the best way to get it, and the residue off. thanks
Old 04-15-2004, 04:59 PM   #2
bristol16's Avatar
Re: Easiest way to remove stickers and emblems?
this should help:
http://www.s10forum.com/forum/f72/how-to-shave-s-10-emblems-off-doors-102443/
Old 04-15-2004, 05:00 PM   #3
bristol16's Avatar
for stickers and decals and stuff, if it is just on a window i just spray it with windex and scrape it off with a razor blade. wouldn't do that if it is on paint though...
Old 04-15-2004, 05:09 PM   #4
ENTERING BLING SEASON
c0nfus3d dime's Avatar
on the windows, just as bristol16 said, take them off with a razor blade. If they are decals on the paint, then they should peel off, but leave a residue behind...you can get that off with Goo-Gone or something along those lines. As far as emblems are concerned, use a hairdryer, heat up the emblem, slide fishing line behind the emblem, and you can take them off. Again, use some Goo-Gone to take off the residue, and you can use a plastic razor blade too if needed. You might need to hit the area behind badges and stickers with some rubbing compound if they have been on there for a long time...this will make sure you don't see where the badges/stickers once were.
Old 04-15-2004, 05:47 PM   #5
The One & Only
Phantom's Avatar
thanks guys
Old 04-15-2004, 05:52 PM   #6
The One & Only
Phantom's Avatar
thanks guys
Old 04-19-2004, 01:15 AM   #7
More Go then Show
THEKING's Avatar
Can you remove the side striping on the s-10. It's the strip that runs from front to back right under the windows.
Old 04-19-2004, 01:52 AM   #8
Flipmarine2k's Avatar
Phantom.. u in the Corps?
Old 04-19-2004, 02:11 PM   #9
The One & Only
Phantom's Avatar
just got out of boot camp about 3 months or so ago
Old 04-21-2004, 07:00 PM   #10
are the emblums on all s10s just held on with tape? becasue i have a 97 s10 and i would like to take them off. thanks for any help
Old 04-22-2004, 04:11 PM   #11
The One & Only
Phantom's Avatar
Yeah i'm pretty sure they are
Old 04-22-2004, 06:29 PM   #12
Thump Thumpin' Member
Tman's Avatar
what about the emblems on the tail gate? are they held on the same way...
Page generated in 0.59718 seconds with 31 queries
[Output: 76.26 Kb. compressed to 71.07 Kb. by saving 5.19 Kb. (6.81%)]
