eagle alloys...help
Old 04-08-2007, 11:29 AM   #1
now XTREME
94redSS's Avatar
eagle alloys...help
i got a steal on some wheels.... i love them but there pittted an it looks like surface rust....but im pretty sure its not i dont think alloy rust's.....but what the hell should i use to clean these up??
Old 04-08-2007, 09:56 PM   #2
now XTREME
94redSS's Avatar
Re: eagle alloys...help
no 1 has an answer???
Old 04-09-2007, 03:14 AM   #3
96blazer's Avatar
Pics?
Old 04-11-2007, 09:07 PM   #4
2LO4BC
lowriderbowtie's Avatar
if you wanna go crazy on them, wetsand them with 1000 grit and then to a 2000grit and they polish the wheels with a powerball and mothers billet polish
Old 04-15-2007, 01:05 AM   #5
Fish
TintaAzul29's Avatar
so to wetsand do you only have to just spray some water on the rim and sand lightly or do you need a specific liquid to do it and not screw everything up. I am having this same problem
Old 04-15-2007, 02:35 PM   #6
you deserve it.
defekt's Avatar
some polish will help remove that surface rust. i know nevrdull does but it takes alot of elbow grease. i use just a tad bit of brake cleaner to remove the thick stuff then immediately wash them again then polish.
i wouldnt recommend wet sanding if you dont know what you are doing. its alot of work.
Old 04-15-2007, 03:52 PM   #7
2LO4BC
wetsanding..basicly, you want to soak some wetsand paper in watter for a while then soak the wheels with water (have a hose close by) and always make sure your paper is wet and the surface your polishing.
I polished a set of IROC's for a friend like this and got them looking as good as a high dollar billet wheel when i was finished
Old 04-16-2007, 01:14 AM   #8
Fish
thank you
Old 04-16-2007, 10:26 PM   #9
now XTREME
94redSS's Avatar
i have a buddy that washes big rigs he says they use a sort of acid on the wheels an said he would do it for my wheels...any 1 ever do this b4??
Old 04-21-2007, 01:06 PM   #10
now XTREME
94redSS's Avatar
i got them acid washed.... it took all of the shit off an all i had to do was polish them ill put some picks up later
Old 04-21-2007, 08:38 PM   #11
A CLEANMACHINE's Avatar
i do mine the same way you can't let the acid dry up,you must rinse with in 60 sec/ then you can polish w/ any thing that's good like buschs.hoosiers,mothers,and flitz alum-polish.
Page generated in 0.57721 seconds with 31 queries
[Output: 72.75 Kb. compressed to 67.91 Kb. by saving 4.84 Kb. (6.65%)]
