drying....
Old 05-22-2005, 06:57 PM   #1
redrider's Avatar
drying....
was wondering what is the best product to dry the truck off with?
Old 05-22-2005, 09:00 PM   #2
Dude in the Blue
Low98Dime's Avatar
Re: drying....
i use a shammy cloth and it dries it off really well. I usually never see any water spots.
Old 05-22-2005, 09:32 PM   #3
redrider's Avatar
Re: drying....
cool....i want to buy sumthing that dries up the water quick
Old 05-22-2005, 09:32 PM   #4
NTBSSHEVN
NCHEVYHEVN's Avatar
Re: drying....
I just use a towel or go flying down the highway.
Old 05-22-2005, 09:40 PM   #5
Searching no more
mat1583's Avatar
Re: drying....
Just use a towel that's been washed a lot of times. After it's been washed so much it usually soaks up the water better than anything else and won't leave a bunch of fuzz, hair, or anything else. Also, towels like that are usually pretty soft. If you use fabric softener when drying, it'll be that much softer.
Old 05-22-2005, 09:44 PM   #6
bagged96ss's Avatar
Re: drying....
those california water blades work pretty good
Old 05-22-2005, 09:48 PM   #7
Rollin` Proud on 15's
Eight433's Avatar
Re: drying....
mr clean autodry. no spots if you do it right.
Old 05-22-2005, 10:46 PM   #8
buellwinkle's Avatar
Re: drying....
The quickest way to get most water off is to use water to dry the car. Take the nozzle off the hose and turn the pressure down to about 1/2 or less. Then starting at the top, run the stream of water across the body panels as to sheet the water off. Then use a real or synthetic chamois or one of those new waffle microfiber towels to dry the rest up. Some people use a leaf blower but for me, the time it takes to get it out, start it up and put it away is not worth it.
Old 05-22-2005, 11:03 PM   #9
Re: drying....
Have you read the "sticky post"?
Also try-
http://crspotless.com/
I have one and absolutely love it.
No spots for real!!! (not like some of the cheap filters)
This is a heavy duty system that really works
Old 05-23-2005, 08:38 AM   #10
Nate01Xtreme's Avatar
Re: drying....
Use the chamois that comes in a plastic tube called The Asorber
Old 05-23-2005, 10:10 AM   #11
redrider's Avatar
Re: drying....
i scene those....do they work well?
Old 05-23-2005, 10:12 AM   #12
Xtreme Dreams..
99xtreme's Avatar
Re: drying....
California water blade. Finish off with Microfiber towels....
Old 05-23-2005, 10:17 AM   #13
redrider's Avatar
Re: drying....
i heard towels(bath) can scratch......
Old 05-23-2005, 10:20 AM   #14
Xtreme Dreams..
99xtreme's Avatar
Re: drying....
Not microfiber... Too soft to scratch... Friend of a friend drives the Tahoe called tribal vision, he has a 10,000 paint job and that is all he uses.
Old 05-23-2005, 07:54 PM   #15
redrider's Avatar
Re: drying....
cool i might have to check these micro towels!!! how much they run?
Old 05-24-2005, 08:04 AM   #16
Re: drying....
The Absorber works, however, I do not feel it is perfectly safe (as do others that detail high end vehicles)
The problem is that if and debris gets caught between the paint and absorber, there is nowhere for it to go, except "swirl city" when drying.
Microfiber dries as well, if not better, depending on style and because most are not "flat", if something gets caught between the towel and paint, they are made in such a way that it is less likely to scratch as the debris will be pulled "into" the towel and not sit on the surface.
Most bath towels can also scratch if they are not high quality (price does not always nean quality), plus they do not absorb water as good a the absorber or a Waffle Weave towel can streak and leaves lint.
A quality Waffle Weave Towel will absorb the water, will not streak, will not leave lint, dries in 1/3 the time after you dry the vehicle and is much safer for your paint.
I also use the CR Spotless filter and like advertised, it is "spotless".
I just run the WW towel over the horizontial surfaces quickly to get the "puddles" of water broken up and allow the vehicle to dry.
No more worries of "pre-mature drying" and leaving mineral deposits on the paint.
Hope this helps
Old 05-24-2005, 08:06 AM   #17
Re: drying....
Depends on the size and quality.
You can get them from .50 up to and above $20
Average for a 24x36 towel is about $19 for a quality towel.
Old 05-24-2005, 09:19 AM   #18
Derek@2020Kustoms's Avatar
Re: drying....
Microfiber Waffle Weave.
Old 05-24-2005, 11:02 AM   #19
redrider's Avatar
Re: drying....
was that a response on saying go with that type of towel?
Old 05-24-2005, 11:14 AM   #20
Re: drying....
Yup. California Water Blade & The Absorber do work but scare the hell out of me. The safest solution that works is a Waffle Weave.
Old 05-24-2005, 11:22 AM   #21
Re: drying....
I use a MF waffle weave towel.
Old 05-24-2005, 04:46 PM   #22
Re: drying....
I agree and currently use the WW towel..., too much of a chance of getting debris caught between the paint and blade or the paint and chamois.
News flash!!
There may be a new weave even better than the WW on the market soon...,
As I said, I do a lot of testing and am in the process of testing this..., so far, so good
One of my last tests was the CR Spotless..., I will no longer wash a vehicle without one, absolutely NO chance of spots!! Amazing and I love that thing (I wish I could buy into it and market it..., but satisfied just using it and having the benifits...
One of my favorite new products
Old 05-24-2005, 05:24 PM   #23
S10Blazer98's Avatar
Re: drying....
I use the California Water Blade and a Shammy at the dealership I work at, and I have never had any problems.
Old 05-24-2005, 05:29 PM   #24
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Re: drying....
Nothing lol I love a white truck
Old 05-24-2005, 11:46 PM   #25
redrider's Avatar
Re: drying....
how much is the WW towel?
Old 05-24-2005, 11:57 PM   #26
Re: drying....
Do not pay more than $19
Lots of online stores
Old 05-25-2005, 09:17 AM   #27
Re: drying....
Poorboy's 24"x36" Soft & Absorbant Waffle Weave Drying Towel (no tag)
Old 05-25-2005, 04:47 PM   #28
redrider's Avatar
Re: drying....
so do not pay no more than 20 bucks for the WW towel?
Old 05-25-2005, 04:51 PM   #29
IT DONT STOP BITCHES!
afterS10's Avatar
Re: drying....
If you click the link that Derek has put up, he is selling that towel for $12.....
Old 05-26-2005, 08:08 AM   #30
Re: drying....
Try the towel Derek is selling for $12.
Once you try them, you will never go back to trying to dry with cotton.
Remember, you will still have drips from the mirrors, doors, etc, etc..., so use an electric leaf blower when possible to get the "drip areas" and puddles, then use the WW towel...
Old 06-08-2005, 02:25 AM   #31
Automotive Renderings
01Blue's Avatar
Re: drying....
the new mcguiars microfiber towel works well i got a blue 01 and i never see water spots,,,,,,,,cost me like 7 bucks from pepboys and my dad has a black 300m and we both never have any problems.
Old 06-08-2005, 01:32 PM   #32
Low in Alaska
Alaska's Avatar
Re: drying....
i use that thing in a tube..forget what it's called though
Old 06-08-2005, 01:36 PM   #33
CevJuan
Posts: n/a
User is:
Re: drying....
See there's that country-boy shit I was talking about
Old 06-08-2005, 01:38 PM   #34
CevJuan
Posts: n/a
User is:
Re: drying....
I use mr. clean spary thingy with hard water removal. Works great on the 21.5" of ohh-so-hard to keep clean chrome
Old 06-08-2005, 01:44 PM   #35
Low in Alaska
Alaska's Avatar
Re: drying....
ain't nothin wrong with flyin down the highway to dry.....but it doesn't get everything, and i'm waxed like crazy
Old 06-08-2005, 02:15 PM   #36
CevJuan
Posts: n/a
User is:
Re: drying....
Why even wash your truck...? If your trucks still wet its a dirt & dust magnet dumb hillbillies
Old 06-08-2005, 02:19 PM   #37
Chyeah
StaticDime02's Avatar
Re: drying....
These work awesome IMO. I need to get another one. My dumbass friend dropped mine on the ground so I had to throw it away.
Old 06-08-2005, 11:26 PM   #38
Fuckhead
EvenFlow's Avatar
Re: drying....
Next time just wash it in the machine like it says, I'm sure any debris will be gone after a trip through the washing machine. Oh yeah and who was it? Ben?
Old 06-12-2005, 12:56 PM   #39
Po-rican Pimp
Red 2.8's Avatar
Re: drying....
Micro-fiber all the way.
Old 06-14-2005, 03:50 PM   #40
Low in Alaska
Alaska's Avatar
Re: drying....
teehee...yeah i know...having a white truck owns though..the dirty aint' usually too bad when I get home though
Page generated in 0.65933 seconds with 31 queries
[Output: 169.76 Kb. compressed to 154.66 Kb. by saving 15.10 Kb. (8.89%)]
