debadging...
well i've been meaning to take off the bravada emblems for a LONG LONG time now.. kept putting it of
started today and just finished one, but there is like an outline around where the emblem used to be. will it buff out? should i just wax iT? what to i doo help lol heres a pic ![]() you cant see it very good but if you look at where it used to be you can notice, and i am very picky about how my car looks so if it cant be removed i will be putting them back on thanks in advanceee |
Re: debadging...
btw i did use adhesive remover and it would not come off.
I'm Back!!
Re: debadging...
what i did was carefully use rubbing alcohol. or you can scrub it out with a clean rag and soapy water.
I'm Back!!
Re: debadging...
what i did was carefully use rubbing alcohol. or you can scrub it out with a clean rag and soapy water. good luck
also what adhesive remover did you use? |
I Roll My Own
Re: debadging...
I used a hair dryer and then SLOWLY peeled the trim off my s10.
Most of it came off that way. I then used spray-on Goo Gone on the adhesive that was left. I let it sit for a while and scrubbed off with cloth. Repeat. Took a few times. Then washed whole truck. My truck is white though. I couldn't tell where it was after. |
Re: debadging...
compound it then wax and u will be good as new!
I pee standing
Re: debadging...
rubbing alcohol should get most of it, but if it doesn't, put some elbow grease into it with a soft cloth damp with goo gone. then wash it really well and be sure to wax and buff it too since the goo gone isn't the nicest thing on your clearcoat
Re: debadging...
thanks for the help guys.. buffed it right out
