2LO4BC
Cleaning under the hood
What do you recomend for dressing up the hoses? I have some Turtle Wax wet n'black that i use on my tires...would this be ok on heater hoses and rad hoses?
I always keep my engine clean, but my hoses have been neglected Thanks guys ![]() |
NTBSSHEVN
Re: Cleaning under the hood
i always just used armorall or this stuff the cleaning boys use at the dealer is awsome. Makes the engine look brand new. its some sort of an engine detailer in a can.
slowly, but surely.
any kinda tire dressing is fine.....
2LO4BC
thanks
slowly, but surely.
no prob man...take some after pics
NTBSSHEVN
O i think the stuff the dealership uses has alot of silicone in it. I don't know if thats right it or not but its what I think they said was in it.
has committed suicide!
tire shine will work too
2LO4BC
i'll throw up some pics in a day or 2
Best bet for detailing the engine compartment is CD2 Engine Detailing Kit . It will take your piece of poo and make it look shiny and new. It maybe hard to find, check Walmart or Pep Boys. Meguiars makes a great engine compartment detailer called HyperDressing. You control the amount of shine by how much water you mix with it. It's not sold in stores, check out this place for it, they pour into smaller bottles for us non-pros http://www.autodetailingsolutions.com/Meguiar's%20Detailer%20Line%20Prices.htm
for rad hoses I have always used hand cleaner. not the citrus stuff but just the plain ol white stuff in the tub... just get a good amount in your hand and go to town on teh hoses... cleans and shines em up great!
PowderCoat Guru
Try No-touch spray....it works wonders and u dont need to do anything else!
CHANGE YOUR EMAIL ADDRESS
If you have alot of plastic under your hood.. Like us 2nd gen's really have alot of it lol
I use any type of tire shine in a can, and go to town on it.. Let it sit over night, efore a show.. And it's blingin.. Actually worth poppin the hood! ![]() |
The other "body" man
Brake fluid!
so you guys are talking about just poping the hood not doing anything else and just spraying this stuff all over the engine compartment and then leting it sit over night and then what? do oyu just spray it off?
Dime Dreamer
Some of these tire shines could cause the hoses to dry-rot prematurly by extracting oils and moisture from the rubber compounds found in your hoses. I'd get a rag and spray silicone spray lubricant on it and wipe them down, if I were you.
Aftermath (Canuck side)
oil will definately kill any hoses that you have, will make them spongy and swollen. ixnay on the brake fluid.
At any rate, something I found is that you can get large bottles of heavily concentrated silicone lubricant that works *wonders* on tires and other plastic and rubber trim pieces at.... sex stores. A big bottle of silicone sex lube is dirt cheap compared to similar "high end ultra performance" tire shines sold at autozone and such, and works just as well. I just get a thin piece of foam sponge, load it up with the lube and go to town. A few drops is all it takes to do your entire truck. |
lube it up and jack off your hoses? lol
![]() If you're straight, I find it helps to have your girlfriend or at least a bikini calendar on the wall when you're lubing and stroking the hoses so you don't feel too gay. |
