Cleaning Rims
Old 01-09-2009, 02:28 PM   #1
Cleaning Rims
Whats the best thing to use to clean grease or any hard dirt off rims?
Old 01-09-2009, 11:55 PM   #2
Short Bus Anonymous
wagonproject's Avatar
Re: Cleaning Rims
Well if you have grease, just a simple degreaser will work. And hard dirt? On some cars I detail they require. Megs Wheel Brightener (just make sure you know what your rims are made of first and use it as a last resort so to speak)
Old 01-19-2009, 07:07 PM   #3
Minitruckin' 4 life!!!
sykominitrkr's Avatar
Re: Cleaning Rims
Hot water, and pressure for the dirt... if they're polished, then a nice aluminum polish should do the trick, once they've been washed, rinsed, and dry'd. If they're chrome, then just wash, and rinse... anything more than that, that needs to be done, can be done with a FINE grade steel wool, and almost NO pressure... just glide it accross... the weight of your hand should be enough to take just about everything off. If it's a painted surface, then a clay bar, and some wax will do wonders for you! Well, good luck!
Page generated in 0.57309 seconds with 31 queries
[Output: 45.31 Kb. compressed to 43.35 Kb. by saving 1.96 Kb. (4.34%)]
