cleaning/ prepping fram for paint?
Old 07-16-2006, 06:57 PM   #1
Ruff Ryder
97s10chevy's Avatar
How do u guys clean ur fram to prep it for paint, mine is extremely rusty and wanted some tips or maybe what to use (besides sandblasting) to get it ready for paint.
Old 07-16-2006, 09:22 PM   #2
zq8sdime
perfect 10's Avatar
Re: cleaning/ prepping fram for paint?
What i have done to mine so far is take a wire brush wheel that you use with a drill and attack it with that..works very well and some spots that are worse i use my orbital sander. Once clean i hit it with eastwood pre cleaner then eastwood rust encapsulator and finally a coat of eastwood extreme chassis black. So far it has turned out great and looks really smooth. The eastwood chassis black is pretty much like por-15 and works great!
Old 07-16-2006, 11:13 PM   #3
Ruff Ryder
97s10chevy's Avatar
what do u use to get the inside of the frame? I am using a wire brush and angle grider for the inside but can't get it in between the frame.
Old 07-17-2006, 08:41 AM   #4
zq8sdime
perfect 10's Avatar
I got a real small wire wheel like a 2" i think it is and i have a flex shaft for my drill, this has worked well for the tuff to reach spots.
Old 07-17-2006, 11:04 AM   #5
I Like Fire....HaHaHa
NickZigaitis's Avatar
I have just completed the frame and painted it. I also used Eastwoods Extreme Chassis Hi-Gloss Black paint. To clean the frame I used a wire brush and brake cleaner. But first i would use a putty knife to scrap a lot of that rubbery tar shit off the frame. Then brake clean and wipe as much off with a rag, then I would wire brush it. For the inside of the frame, i did the same thing. A little trick I found was to take a small propane torch and heat the frame to melt that rubbery shit. Then I would shoot brake cleaner on it and blow that shit out of there. PLease where a mask when doing this. Singed brake cleaner creates a powerful vapor. Then I primed and painted it. It took 1 quart of Eastwood's chassis primer but it took 3 quarts almost to lay down a good, heavy and even coat of the top coat. Here were the results.
Before
Clean
After
Old 07-17-2006, 01:09 PM   #6
Ruff Ryder
97s10chevy's Avatar
mine gets nowhere near that clean with just the wire wheel, but then again my frame was a bout 10 times rustier than urs to begin with
Old 07-17-2006, 02:02 PM   #7
Brake cleaner helps. A flap disc also helps. Here is my axle. It was crazy f-ing rusty. Then I degreased it and spent a couple hours flap disc sanding it and then shot several coats of slick sand and then primed and painted it. Your rusty frame can look just as good. Just takes twice as long. Tray a flap disc on your frame. I spent about 2, almost 3 weeks cleaning the frame before I even start the fab work.
Rusty Shit
Rusty shit grinded off
Slick Sand high build primer. Seals rust and levels the surface.
Eastwoods Chassis Primer
Eastwoods Hi-Gloss Extreme Chassis
Old 07-17-2006, 04:04 PM   #8
how low can you go
quickline23's Avatar
thats looks awesome i am in the process of cleaning my frame up as we speak now to. its getting there just a taking some time to get the rust off
Old 07-17-2006, 04:34 PM   #9
Don't get discourage about how long it takes. Stay detail oriented and get ever nook and cranny.
I shot the frame with 1quart of primer and 3 quarts of gloss. Keep that in mind. I originally shot the 1 quart of primer and the 1 quart of gloss. The primer went on good but the gloss coat was too thin and 1 quart for the whole frame is really stretching it. I blasted the frame with a syphon feed gun 1.6 tip tuned to limit the flow as much as possible. I ended up ordering 2 more quarts. Keep that in mind.
Old 07-17-2006, 04:47 PM   #10
Ruff Ryder
97s10chevy's Avatar
how does naval jelly work? Does it do anything?
Old 07-20-2006, 12:13 AM   #11
bagged85's Avatar
that looks mint, i was lazy and just knocked the rust off with a hammer n wire brushed briefly by hand then sprayed bed liner on it lol ( it show but looks better)
Old 07-31-2006, 12:40 AM   #12
Pac is a hackin!
comics22's Avatar
lol i was thinkin the same but usin like rustoleum and paintin that on...
Old 08-02-2006, 04:57 PM   #13
DfntPntbll's Avatar
I hate you,.. you and your money,..... and your time,...
j/k man. I have followed your thread and it is looking totally nuts. wish I had the time, money, skill,... aw hell,.. I wish I was you.
Page generated in 0.59417 seconds with 31 queries
[Output: 84.56 Kb. compressed to 79.01 Kb. by saving 5.56 Kb. (6.57%)]
