Cleaning interior trim/touching up paint chips...
Old 11-18-2004, 10:57 PM   #1
'Stevie Joe'
HighrollerII's Avatar
I got 2 questions....whats good to use to clean the interior trim panels (to get dirt and stuff from outta the grooves)
and how can i fill in all the rock chips on my hood? touch-up paint?
Old 11-19-2004, 01:01 AM   #2
has committed suicide!
Got-20z's Avatar
Re: Cleaning interior trim/touching up paint chips...
1. I always had good luck by using the edge of a washcloth to get the dirt out
2. ya touch up paint
Old 11-19-2004, 02:04 AM   #3
get a paintbrush to get the cracks and crevices(house paintbrush)
Old 12-09-2004, 10:21 PM   #4
dansellbuddy's Avatar
cracks are best dusted with a brush of some source. the panels themselves, i've found mr clean's magic erasers to do very well. they pull almost everything off. you'll probably want to throw down a light coat of armor all cleaner afterwards (the cleaner leaves a little shine without evaporating and making your windows a bitch to clean)
Old 12-13-2004, 02:55 PM   #5
I use a old credit card or something with an edge and put it through a cloth for the trim.
Old 12-16-2004, 08:26 PM   #6
1- Get 2 paint brushes, cut the bristles 1/2 length on one of the brushes.
2- For paint chips, use a touch-up paint with the exact color so the match is perfect..., then- Use Mothers Paint Chip Repair Kit to remove thebig ugly blob and rush marks, it makes the "TU" un-noticable
Old 12-16-2004, 09:20 PM   #7
SEP.29,2005
grover98's Avatar
follow the guys for the chip of paint but i use a little listerine (yes the mouth wash) and an OLD toothbrush and a towel to wipe up i've never had any problems with discoloring but i would test it some where first
Old 12-17-2004, 12:14 PM   #8
INNOVATIVE FABRICATIONS
Rompn's Avatar
I was really suprsied how clean my door panels turned out by using Simple Green mixed with some warm water. I applied it with a stiff bristle scrub brush. Results are awesome.
Old 01-14-2005, 10:30 PM   #9
The S-10 Scrub
skbmxer7's Avatar
I work at a detail place, if you can, get some degresser and an air gun, spray a lil degresser in there, get a cloth and cover it (so you dont spray it everywhere) and let at it with the air gun. Should be good as new
Old 01-31-2005, 11:03 AM   #10
david_the_noma's Avatar
for real walmart sells a makeup kit for girls its got like 12 different brushes in it and its cheep like 8$ i got that and it has alldifferent size brushes in it works awesome....
Old 01-31-2005, 11:19 AM   #11
CHANGE YOUR EMAIL ADDRESS
xtreme3411's Avatar
If the crevices are really bad.......spray some all puropse cleaner in them, then come back through w/ an air gun and a rag to blow the sht out of them....
Page generated in 0.57317 seconds with 31 queries
[Output: 72.54 Kb. compressed to 67.74 Kb. by saving 4.79 Kb. (6.61%)]
