blown up .....again
cleaning fiberglass camper
what is the best method to clean a fiberglass camper that has dirt and tree sap on it.
Short Bus Anonymous
Re: cleaning fiberglass camper
Well aside from a normal wash job to get rid of the dirt and stuff. On cars I use Isopropyl Alcohol to remove sap.
drunk and bored
warm/hot water removes sap
blown up .....again
thanks guys, is there a special way to prepare the camper for paint other than cleaning?
drunk and bored
it really depends if it's real fiberglass or just a laminate......if it's a laminate red scuff pads will be sufficient.....if it's 'glass 320da would be preferred prior to sealing
blown up .....again
ok, so whats the difference between the two types? and do I just use regular primer?
drunk and bored
laminate is thin and flimsy,'glass is not
and i have no idea what you consider 'regular primer'......and i didn't even mention primer so i feel you are not going to follow my advice....someone else can pick up here,i am done |
blown up .....again
I only mentioned primer, cause I dont wanna clean it again. I'm new to this time of crap and dont want to screw it up. and by the way it is fiberglass shell. I've heard some people say I need to put an additive in my paint & primer and some say I dont. I'm an engine mechanic, not a body guy. I appreciate any advice you could get me. thanks in advance
