Cleaning chrome wheels w/ #0000 steel wool??
Old 07-27-2008, 08:00 PM   #1
air ride equipped
stalephotograph's Avatar
ok so ive heard of people using #0000 steel wool on cleaning chrome wheels, since its so fine it wont leave scratches. it will also remove small pits and whatnot. what is the best way to go about this? i bought my wheels used and want to clean them up one good time and then just wash and polish them as usual. just like to hear how some people go about this.
here are the spots im talking about, which are in between the spokes....
Old 07-28-2008, 12:40 AM   #2
BarelyGettinBy's Avatar
Re: Cleaning chrome wheels w/ #0000 steel wool??
I have aluminum wheels but i use the wool with some mothers polish and they look great
Old 07-28-2008, 01:34 AM   #3
tohoopty's Avatar
yeah you can use the fine steel wool on chrome.and it should take out the little pits in them as well
Old 07-29-2008, 09:11 AM   #4
rusty bumper member
HofinaterSS's Avatar
I'm gunna have to try this on my bumper...even though the chrome is completely peeling off.
Old 07-29-2008, 04:43 PM   #5
air ride equipped
what should i use while using the wool? just water and soap?
Old 07-29-2008, 04:45 PM   #6
I SHIT BRICKS
OneLowSdime's Avatar
chrome polish
Old 07-29-2008, 05:25 PM   #7
tohoopty's Avatar
just the steel wool
Old 07-29-2008, 05:32 PM   #8
SK Whut !?!
kms_dude1's Avatar
i use steel wool alone or sometimes i use the foaming glass cleaner.. neither should scatch the wheel if its clean and no rocks are in the steelwool
Old 07-30-2008, 02:26 PM   #9
danGMCsonoma's Avatar
will this process work on regular factory alloys?
Old 07-30-2008, 03:04 PM   #10
needs to be lower...
nimrod8560's Avatar
^ditto for Xtremes
Old 08-04-2008, 08:18 PM   #11
Slap my meat on your pita
GeorgesBlazah's Avatar
No it wont.
Old 08-07-2008, 02:24 PM   #12
Broken Handed Superman
MeltingPlastic's Avatar
i did it to clean up my boss 304s.. it worked quite well... what i did was haad a bucket of carwash and soaked the 0000 in it for a bit while i wet the entire wheel.. i then sprayed the wheel with Mequires Hot Rims cleaner and then proceeded to scrub it with the steel wool... took out a LOT of imperfections but there will still be pitting.. it wont get rid of it completely but it will help it out.. afterwards i polished them with mothers chrome polish
Old 08-08-2008, 01:39 AM   #13
s10gmconversion's Avatar
use SOS pads they work great
Old 08-08-2008, 01:48 AM   #14
No More Chrome
OBrienChevSuper10's Avatar
i used steel wool on my boss's too. just got the rim wet with soapy water and rubbed lightly with the steel wool. helped alot and i didnt notice anything hurt on the rim.
Old 08-08-2008, 03:08 AM   #15
Shawn F.'s Avatar
Use 000 or 0000 steel wool only with some kind of lubricant such as glass cleaner or something similar. When done, polish them up by hand or a mothers power ball and then seal them with a wheel sealer such as Poor Boys wheel sealant. The sealer will keep dirt and brake dust from ever sticking to them and when they get dirty just get the hose out and spray the dirt right off.
Old 08-08-2008, 10:02 AM   #16
blazer is dunnnnnnnnn!
purplepassion's Avatar
im assuming this will work the same for my chrome tanks? i found some at work, so i borrowed some just incase
Old 08-08-2008, 05:16 PM   #17
Shawn F.'s Avatar
Yes, it works for chrome wheels, bumpers, glass, etc. Just use some kind of glass cleaner or such to prevent scratching. You can do it dry but I usually use something as to not take a chance.
Old 09-02-2008, 02:56 AM   #18
you just have to make sure its chrome plated, #0000 and protect all from walmart always did the charm for me.
Page generated in 0.60517 seconds with 31 queries
[Output: 96.00 Kb. compressed to 88.68 Kb. by saving 7.32 Kb. (7.62%)]
