Cleaning Brake Dust Off Front Rim
Old 06-13-2009, 06:41 PM   #1
Hello All, just discovered this forum. I appologize in advance if this has been covered before.
2003 / 65K miles. Have front weeks off for brake job and trying to clean all the brake dust off the inside of the rims. I have used Eagle One A2Z with a scotch brite pad and have as much off as I can get, but the rims are still horrible. I was hoping to get them spotless and spray the inside of the rims with some clear Krylon spray paint to seal the aluminum and make them easier to clean in the future.
Any suggestions greatly appreciated.
Thanks,
Dr Dave
Old 06-13-2009, 07:02 PM   #2
Yes-Man
oweezy9's Avatar
Re: Cleaning Brake Dust Off Front Rim
Have you tried a cleaning product like Simple Green or a degreaser? Might help
Old 06-13-2009, 07:55 PM   #3
Sisk's Avatar
x2...Simple green will work wonders. I haven't had it not work on brake dust yet. Just spray on, let it sit for a bit and soak in, and wipe off.
Old 06-13-2009, 07:59 PM   #4
I started with Formula 409 and a Scotch Brite pad....then SOS/Brillo....then Eagle One A2Z All Wheel & Tire Cleaner with Scotch Brite pad....then Mothers Mag & Aluminum Polish with a Scotch Brite pad and the inside of the rim is still specled with millions of little black dots where the brake dust appears to have pitted the rim.
Old 06-13-2009, 11:36 PM   #5
Peco's Avatar
I use Purple Power 50/50 mix as a scotch brite pad. Then go over the inside with a Magic Eraser as the final step. Heres a pic of my 95 Grand Prix (front)rim.
Old 06-13-2009, 11:40 PM   #6
2in da pink 1in da stink
Dr. Steve's Avatar
x3 simple green is the stuff to use man
Old 06-14-2009, 09:23 AM   #7
Sisk's Avatar
Simply green is just so...well simple. lol. None of this scotch bright pad stuff, just spray on and wipe off. No multiple products.
Old 06-14-2009, 10:27 AM   #8
Thanks for all your help. I'll pick up and try the products suggested. The problem is the brake dust appears to have invaded the micro pores in the wheel casting. I took a picture this AM and this is the best I can do.
Not sure this attachment is going to work
Old 06-14-2009, 10:46 PM   #9
Slap my meat on your pita
GeorgesBlazah's Avatar
If you buy an aggressive claybar you might be able to get some of that stuff off with clay.
http://www.autodetailingsolutions.net/ht-12bu.html
Make sure you throw it away after and dont use it on your paint lol.
Old 06-14-2009, 10:49 PM   #10
<3 redheads
556mm's Avatar
what kind of rims are they?
Old 06-15-2009, 07:47 AM   #11
Standard factory rims that came with the 2003's.
Simple Green and Purple Power made no additional progress over the picture posted earlier. I even tried E-Z Off oven cleaner. I'm resigned to the fact that the rims are permanently damaged. I did hit the inside with a few coats of Krylon Clear spray pant. Hopefully this will seal the aluminum and not make the situation any worse. Should also be easier to clean.
What was GM thinking not sealing the inside if the rims???
Old 06-15-2009, 08:17 AM   #12
Sisk's Avatar
Damn....I've never had simple green not work before, and I've used it for years. I'd be inclined to think your rims are perma-f'd lol.
Old 06-15-2009, 01:32 PM   #13
BoSoxFanSims34's Avatar
Ive never seen anything work better than this stuff. Spray it one let it sit for a minute scrub with a brush then wash it off.
Old 06-17-2009, 08:19 AM   #14
I like Simple Green but you have to be VERY CAREFUL when using it because it can dry on the wheel and then you will have to spend a long time polishing them back out.
Trust me I learned the hard way
Old 06-17-2009, 08:15 PM   #15
BTE
I have no idea
BTE's Avatar
Purple Power works awesome too.
Old 06-21-2009, 12:30 PM   #16
Thanks to everyone who replied.
Took me a few stores, but I finally found the Eagle One Etching Mag Cleaner...and with a scotch brite pad I was able to get the inside of the rims as clean as they are ever going to get. There is some definite damage where the brake dust must have eaten into the pours of the Aluminum casting. About 95% clean.
I'm going to hit them with some Krylon Clear and see if that helps future cleaning.
Page generated in 0.58836 seconds with 32 queries
[Output: 88.52 Kb. compressed to 81.92 Kb. by saving 6.61 Kb. (7.46%)]
