Brown Tires??
Old 05-30-2006, 10:13 PM   #1
2ND ACR
BLACKACIDEVIL's Avatar
Brown Tires??
How can I keep my tires from turning brown? I'm using Son-of-aGun aerosol to dress the tires after I clean them. What tire cleaner should I use? What tire shine should I use that doesn't make them look super glossy? Any help would be great. Thanks.
Old 05-30-2006, 10:20 PM   #2
96blazer's Avatar
Re: Brown Tires??
I use the Megiurers(sp?) Tire Gel. It keeps the wet look for a while, then kinda dries into a deep black over the days. Only thing is it tends to shoot off on the rocker panels if you drive right after applying it.
Old 05-30-2006, 10:21 PM   #3
NTBSSHEVN
NCHEVYHEVN's Avatar
Re: Brown Tires??
My tires did that from using gel tire dressings so I had to go and get a brass tire brush cleaner and some tire cleaner and scrub them down to get them back to black.
Old 05-30-2006, 10:22 PM   #4
2ND ACR
Re: Brown Tires??
Any tire cleaner you guys recommend?
Old 05-30-2006, 10:23 PM   #5
NTBSSHEVN
NCHEVYHEVN's Avatar
Re: Brown Tires??
I wanna say the stuff I used was Wesleys bleach white stuff. I can't remember if that's right.
Old 05-30-2006, 10:27 PM   #6
2ND ACR
Re: Brown Tires??
Will that damage my Xwheels?
Old 05-30-2006, 10:28 PM   #7
NTBSSHEVN
NCHEVYHEVN's Avatar
Re: Brown Tires??
I wouldn't go spraying it all over the place. I didn't cover my zq8 rims but it wouldn't hurt anything to cover them up. The stuff is pretty strong.
Old 05-30-2006, 10:30 PM   #8
2ND ACR
Re: Brown Tires??
Sounds good. Where can I get one of those brass brushes to scrub the wheels with?
Old 05-30-2006, 10:31 PM   #9
NTBSSHEVN
NCHEVYHEVN's Avatar
Re: Brown Tires??
I picked mine up at Autozone for a few bucks.
Old 05-30-2006, 10:32 PM   #10
2ND ACR
Re: Brown Tires??
Cool. Thanks man I reallly appreciate the help.
Old 05-30-2006, 10:36 PM   #11
dillon_b12's Avatar
Re: Brown Tires??
That brown stuff is wax that the tire manufacturers place in the tire to help increase the longevity of the tires. I use Wesley's Bleeche-White to clean my tires.
Old 05-30-2006, 10:40 PM   #12
2ND ACR
Re: Brown Tires??
Yeah, I've read that somewhere before it's supposed to help keep the tires from dry rotting.....or something along those lines. lol
I'm going to grab some Wesleys after work tomorrow and give it a shot. Thanks for the help.
Old 05-30-2006, 10:41 PM   #13
Bann3d
Huisurdady's Avatar
Re: Brown Tires??
what i used was ajax and a scrub brush with plastic bristles. It works great on tires.
Old 05-30-2006, 10:45 PM   #14
2ND ACR
Re: Brown Tires??
That is a good cheap idea. I like cheap!
Old 05-30-2006, 11:09 PM   #15
dillon_b12's Avatar
Re: Brown Tires??
Yea there is no reason to use a damn brass bristle brush. I just use a stiff bristle "fingernail" brush. Not sure of the actual name lol but it's just a plastic bristle brush that is about three inches long.
Old 05-30-2006, 11:37 PM   #16
<3 redheads
556mm's Avatar
Re: Brown Tires??
another vote for wesleys bleach white it's awesome!
Old 06-01-2006, 12:47 PM   #17
The Blue Pwns Joo!
RustyButTrusty's Avatar
Re: Brown Tires??
On my girls BFG's I usually hit them with Bleach White and a stiff brush, then dress them with Meguiar's NXT InsaneShine tire spray. Works great and theres zero spray-off on the rocks/bedsides, even if you apply it and drive right after.
Old 06-01-2006, 01:19 PM   #18
98' Cowl Induction
GiveMeBreak's Avatar
Re: Brown Tires??
used wesley's bleche white myself with an extra brass gas grill scrubber...lol
Don't get that on your rims....once or twice is ok..but its to harsh for rims all the time. It will make clear coat crack
Old 06-02-2006, 12:36 AM   #19
2ND ACR
Re: Brown Tires??
I picked up some Wesleys last night so I'll give it a shot this weekend. Any ideas on what I can use to protect my wheels while I'm spraying the Wesleys on them? Thanks.
Old 06-02-2006, 12:43 AM   #20
dillon_b12's Avatar
Re: Brown Tires??
I just try to minimize my overspray but I guess if you wanted you could cut a piece of cardboard the diameter of your wheel and just hold it up there while you spray.
Old 06-02-2006, 12:51 AM   #21
2ND ACR
Re: Brown Tires??
That gives me a good idea! I do plastic injection molding for a living so I can take one of our products and cut it down to fit my wheels and that will last a hell of a lot longer than cardboard. Thanks for the idea.
Old 06-02-2006, 01:04 AM   #22
crap
bg's's Avatar
Re: Brown Tires??
Did mine....I ended up using simple green to clean em
real good and no touch tire care to keep that nasty brown
out of em. Mine were bad, but the above recipe fixed it.
Old 06-02-2006, 09:04 AM   #23
98' Cowl Induction
Re: Brown Tires??
I have seen them for years ...but never bought one..it is a good idea tho!
http://www.autogeek.net/wheelshield.html
Old 06-02-2006, 06:16 PM   #24
Chivalay Mane
LoRollinLS's Avatar
Re: Brown Tires??
thats what i use, yea just dont spray it allover your wheels, alittle overspray is hard not to get on there, but just rinse the wheels and tires off real good and wipe the wheels down with a seperate cloth......
Old 06-02-2006, 06:45 PM   #25
2ND ACR
Re: Brown Tires??
I made one at work today. I'll have to see if I can borrow a digicam so I can post a pick.
Old 06-02-2006, 08:10 PM   #26
Hey kids!
raider600's Avatar
Re: Brown Tires??
scrub them
Old 06-06-2006, 10:22 AM   #27
goin over the falls
Slow01S10's Avatar
Re: Brown Tires??
i rarely ever use tire shine because the acetone in them will cause dry rotting over time. I just get the tire wet a bit before and let the wheel cleaner mix with the water on the tire, wipe it around and hose it off. Never had any problems that way. To keep the tires black i will use Meguiars vynal and rubber protectant, it comes in a red spray bottle, works awesome. Ill put that on a tire swipe pad and wipe it on. Stays black and there is nothing that flies onto the rockers or body. Just let it sit for about 5 min before moving.
Old 06-12-2006, 12:18 AM   #28
2ND ACR
Re: Brown Tires??
Well, I finally got around to using the Wesleys today and it worked great! Now what kind of tire shine should I use? I don't want to use anything real shiny just something to get them nice and black. Thanks.
Old 06-12-2006, 01:01 PM   #29
goin over the falls
Slow01S10's Avatar
Re: Brown Tires??
meguiars vynal and rubber protectant works great
who remembers the eagle one tire tint??? i used to use that all the time on my old cavalier
Old 06-12-2006, 06:20 PM   #30
NOFAT1S
RedHott99's Avatar
Re: Brown Tires??
I either use Wesley's Bleach White on mine or I'm also very fond of using Eagle One Tire Shine. Both work equally well with my applicators that I have for putting on tire shine with no mess at all.
Page generated in 0.63817 seconds with 31 queries
[Output: 140.80 Kb. compressed to 129.14 Kb. by saving 11.66 Kb. (8.28%)]
