Black crap!!!!
Old 08-08-2005, 12:52 AM   #1
LitRedSS-10's Avatar
Black crap!!!!
I am having trouble removing this black stuff, like tar that is right on my rear fenders, any typs for taking care of this?
Old 08-08-2005, 01:04 AM   #2
dillon_b12's Avatar
Re: Black crap!!!!
I got the same shit, I'd like to know. I read on here I think to try peanut butter. Something about oily substances breaks up the tar.
Old 08-08-2005, 10:42 AM   #3
Canyon Carver
Re: Black crap!!!!
Wax and Grease Remover cures all.
Old 08-08-2005, 12:05 PM   #4
chevyoverford43's Avatar
Re: Black crap!!!!
Use bar and tar remover. and some cleaner wax, not caranuba wax. If that doesnt work get some heavy cut compund and a buffer and rub it out
Old 08-08-2005, 05:48 PM   #5
Domestic newbie
Zizzo's Avatar
Re: Black crap!!!!
laquer thinner/light fluid. if it's real thick and heavy, use a brush to scrub it off.
Old 08-08-2005, 05:52 PM   #6
The Der
Re: Black crap!!!!
MMMMMM peanut butter and tar
Old 08-08-2005, 06:54 PM   #7
Canyon Carver
Re: Black crap!!!!
Lacquer thinner is not good for finished paint. It will remove your clearcoat and then your basecoat.
Old 08-08-2005, 06:55 PM   #8
jds_truck's Avatar
Re: Black crap!!!!
ya just go to autobody isles of any autoparts place and grab some wax and grease remover will cure all with some work
Old 08-08-2005, 07:31 PM   #9
Domestic newbie
Zizzo's Avatar
Re: Black crap!!!!
I didn't know that, we would use that at work all the time. Never caused any problems for us. Thanks for the heads up
Old 08-08-2005, 09:42 PM   #10
Trick Motorsports
C_Rog's Avatar
Re: Black crap!!!!
if it's road tar, try using spraying WD-40 on a rag and wipe it off. Just make sure you get all of the WD-40 off, it tracks dirt.
Old 08-08-2005, 10:12 PM   #11
jds_truck's Avatar
Re: Black crap!!!!
also bad if u are going to paint truck any time soon
Old 08-08-2005, 10:29 PM   #12
Rustbucket Club
LikeaRock's Avatar
Re: Black crap!!!!
Go buy a clay bar if you don't have one, and that should do the trick. If it doesn't work too well, use some Castrol Super Clean diluted with water at about 75/25 and let it sit for a few minutes and then run the clay bar over it. You MUST ilute it because it's harsh shit, but I imagine you can get everything off with the clay bar. I've been able to remove almost anything with them. Follow everything up with a mildly abrasive polish or a cleaner wax, top it off with your favorite wax or sealant and you're good to go
Old 08-09-2005, 02:30 AM   #13
ZR2 member
Scott01's Avatar
Re: Black crap!!!!
I know people who use it all the time.If wiped on and off with a rag nothing bad happens.If poured on and let sit,yeah its bad.Because then it has time to get into the paint.
Old 08-09-2005, 10:50 AM   #14
Canyon Carver
Re: Black crap!!!!
It's removing a thin layer of paint each time you use it. You won't notice it until its worn through the clearcoat. Their are other products on the market that do just as good of job, and won't harm your paint.
Old 08-14-2005, 09:40 PM   #15
Draggin' Daily
dwarfs10's Avatar
Re: Black crap!!!!
brake parts cleaner
Page generated in 0.59763 seconds with 31 queries
[Output: 87.00 Kb. compressed to 80.75 Kb. by saving 6.25 Kb. (7.19%)]
