Best way to remove emblems?
Old 09-25-2005, 07:16 PM   #1
bag_it_&_drag_it's Avatar
I want to take the emblem of my car that says focus, is there a good product for this? What kind of residue does it leave?
Old 09-25-2005, 11:22 PM   #2
ANGRY BABY!
Metlhed01's Avatar
Re: Best way to remove emblems?
fords use alignment pins for alot of their emblems, so be careful, removing the emblem could leave an exposed hole.
just drag a piece of mono-filiment behind the emblem, it will get it off. then to remove the glue use an old terry rag (anything that wont scratch the paint works really) and something like goof off to remove the gule. wax afterwords.
Old 09-26-2005, 07:03 PM   #3
low and slow
lowxtreme's Avatar
The focus's emblems are held on with adhesive. I took the emblems off the girlfriends when she got it. You will definatly need goof off for the left over adhesive.
Old 09-26-2005, 08:17 PM   #4
Dey took rrr jobs!!
GriMSysTeM's Avatar
I suggest one of these, it removes vinyl, adhesive residue or whatever really quick.
http://eastwood.com/shopping/product...odu ctID=1914
Old 09-26-2005, 08:43 PM   #5
ANGRY BABY!
Metlhed01's Avatar
yeah they work. it can VERY easily burn through your clear coat if you arent careful. you dont need that for removing glue from an emblem.
Old 09-26-2005, 09:20 PM   #6
Dey took rrr jobs!!
GriMSysTeM's Avatar
Yes this is true, but I use it all the time at work, Just keep it moving and it will be fine. I've burned thru only a couple times using it. Goo Gone does a pretty good job as well.
Old 09-26-2005, 09:38 PM   #7
ANGRY BABY!
Metlhed01's Avatar
yeah but they are normally a last resort, at least thats how ive always looked at it. and anyway, how many times have you burnt through with a plastic squegee or fishing line and some acrylac?
Old 10-02-2005, 08:13 PM   #8
thanks guys.
Old 10-03-2005, 01:26 AM   #9
Hey kids!
raider600's Avatar
heat gun/blow dryer. you can get adhexive off with, gasoline, or paint thinner. thatscommon household stuff. or if you want to buy something then that works too.
Old 10-03-2005, 02:04 AM   #10
jds_truck's Avatar
as long as you are carefull u can use a drywall spatula (get the thin metal flimsy type) then use wax and grease remover(will find in autobody section of most car parts supplier) its what i use all the time at my job to remove these
Old 10-03-2005, 09:15 PM   #11
98' Cowl Induction
GiveMeBreak's Avatar
Someone needs to make a Sticky for removing emblems...seems to be a highly asked ?
Old 10-05-2005, 01:57 PM   #12
Mecha-Shiva
DeMon76187's Avatar
i used goo gone and an orbital buffer to remove all the adhesive from my factory pinstripes, stickers, and symbols. time consuming, but gentle and works well.
filimint works great too. after u take off the symbols, make a belt buckel outa them
i alwasy get compliments on my GMC buckel
Old 10-26-2005, 11:37 PM   #13
acgreaser05's Avatar
as long as there are no pins ive found that fiching line and then some bug and tar remover is the best way to debadge a car.
Old 10-27-2005, 05:46 PM   #14
is out cruisin...
low98's Avatar
heat gun...then take a old credit card and slide it behind the emblems...keep up with the heat gun and use generously to get the emblem off...then with your thumbs, take and roll the excess glue off by rolling it...remove the rest of the residue with bug and tar remover
Old 10-27-2005, 05:48 PM   #15
Brewmaster
Psyphinx's Avatar
when i remove emblems i use plain old Isopropyl alcahol and fishing line
Old 10-27-2005, 05:49 PM   #16
I just cummed.
GreatWhite00's Avatar
Clay bar took off the remaining residue for me.
Old 11-08-2005, 05:54 PM   #17
cody250f's Avatar
After reading this thread I decided to finally take my emblems off, and it wasn't nearly as bad as I thought it would be. I used a plastic paint spatula to get behind the emblems and lift them off the paint and then sprayed the residue with 3m wax and adhesive remover, let it soak got what I could off with my thumbs, for the thick areas I used a razor blade and then thumbs. Then I went over it all real good with a wet wash cloth, and am extremely pleased with how it came out.
Old 11-13-2005, 06:01 AM   #18
xtremnut
xtremelink's Avatar
the way I did mine was:
1.heat up emblem, it didn't take my new heat gun very long.
2.pealed off the emblem with my hand
3.used fingernails for left over glue
4.used 3M adheiseve remover whiped off all left over glue
5.used meguire's scratch X to rub out "fade"(not really paint fade)
6.polished with turtle wax color polish(in my case black)
7.waxed with meguire's gold class wax
8.repeated steps 6 and 7 on the rest of the truck
It came out beautiful!
Old 11-15-2005, 01:44 PM   #19
got me some 20s
rockyroad217's Avatar
i just ripped mine off, then sanded cuz i was fixin to primer it anyway lol
Old 11-15-2005, 06:51 PM   #20
RedNoma's Avatar
"Saw" the adhesive with fishing line. Pour a little paint thinner on the adhesive. Rub it off. Clean the area real good. Wetsand the area with some 1500 to make sure you get anything off. Hand buff the area with some rubbing compound. Wash the area real good. Wax the area.
Page generated in 0.61625 seconds with 31 queries
[Output: 103.14 Kb. compressed to 95.07 Kb. by saving 8.07 Kb. (7.83%)]
