Weeeeeee
If anyone needs any help, or tips with detailing and cleaning, I work @ a detail shop...go ahead and ask me.
kaught yah sleapin racing
how can i bring depth back into my black paint. it is only abouta few month's old but i still would like to know 4 later on and even 4 now as well. i just don't seam to get it as shinny as all the other black ones i see around.
Weeeeeee
At the shop I work at, we do a three step process on most cars. A good cut, polish, and wax job would do the trick...If it is fairly new you shouldn't have to do the cut part (wool pad with a rotary buffer if you have one and feel comfortable using it, and compound), but this will take out any surface scratches and smooth out the clearcoat...Then, use a good polish with a foam pad , this will shine it up more...And to finish it off a hand wax job will protect the paint and help it stay clean. If you do a good job there will be no streakiness in the sun...and hand wash your car if you can, automatic car washes are horrible on black paint.
yea the most i do is hand wash like 4 times a week but i got tons of swilrs and lil scrathes i wash my mitt too than every now and than i take a clean rag and wax it up by hand.
Weeeeeee
...you can either do all that yourself, or it would cost about 75-100 bux to have a shop do the whole three step process (pricing may be different in your area), then afterwards, probably wax it monthly.
ok. some guys around here thought it would be a funny practical joke to "test" that black magic car tint sh!t on my entire truck. On the can it says "washes right off". the metal flakes will not come off for anything. i went to a body shop, and the guy that runs it said he would charge me $75 just to do the hood and 2 front quarter panels. i ask about those 3 in particular because their the worst ones. what could i do myself?
Weeeeeee
What have you tried so far??
When you say cut, do you mean stripping the old coat of wax(es)
off? What type of wax do you prefer& why? What do you use on the chrome grills? Have some oxidation on front grill& would like to get my truck back to above average appearance |
Senior Member
how can i get 4 years of grease/gook/tire shine/brake dust/dirt off my tires. ive tried just about EVERYTHING
:thanks |
Best to soak a rag in the diluted solution then wipe the tires with some elbow grease. If you get any on your wheels, wipe it off right away with a clean rag. Try it at your own risk. |
Weeeeeee
cutting is the process of buffing the paint with a rotary buffer and compound to get the scratches out.
At the shop I work at we use auto magic products. the type of wax depends on what youre doing. If you have cut and polished the paint then you only need regular wax. If you're looking for a one step then use a cleaner wax. I would try blue magic metal polish on the grill.. I'm not completely sure if it's ok on chrome, I imagine it wouldn't do any harm, but it will remove the oxidation. I would try a brass wire brush on the tires w/ some degreaser. I would try that way before trying oven cleaner. |
Senior Member
Weeeeeee
...Wire brush and degreaser...Try it.
Senior Member
Weeeeeee
the stuff we use is this alkaline base degreaser...It's auto magic "red hot". I think it is an engine degreaser.
What's the best way to detail the engine on a 98 2.2 Also, what needs to be covered as so not to get wet?
True Ambition
rim haze
Location: Plains,PA Posts: More than 1 Angry Hazy Crazy rims won't shine I have a set of Colorado Customs rims and they are looking somewhat dull and hazed up. Quite possibly this happened after they came back from the shop where I had my body work done. There was quite a bit of crap on them...grrrr. Anyhow....I need some suggestions....someone said have them wet sanded...i dont' know about that. Where can I go and what can I say to get these blings blinging again. Thanks |
sonoma350ed, just use some simplegreen, should do the trick. Always works on the cars I detail here. 98greenmachine, how long you been detailing? I believe the guy I get all my products from is in oregon.
Re: rim haze
Tranzaddict
hey green , how 'bout when wax gets in those rough black plastic parts, like the door handles and bedliner edges and leav white stains? (I've gotten rid of them, but they come back!)
Weeeeeee
Clean S.X., There's some stuff called new car solvent we use, works really well on removing lots of stuff, but definitely removes the wax from the black parts. If you can't get a hold of that stuff, then gasoline would work.
Weeeeeee
For the wheels, Blue Magic or that extreme metal polish should do the trick. I wouldn't wet sand the polished rims unless you wanted the hazed look or a subdued look.
Dain Bramaged Member
#24 |
Location: a lil town outside of new orleans User is: OffLine |
I've seen a lot of people with black vehicles and they always seem to have that nice wet looking sine to them. Ive tried some wet wax but eagle one but it doesnt seem to give me that wet look. DOes anyone know what kind of wax would give me that look?
#25 |
Tranzaddict
hey green, one more thing.
The best way to clean tonneau covers? Mine has like some fine dust stains engraved between them "leather" grooves. I tried a soft brush with car wash soap on it. no luck P.S. Stock02, that AV looks painful |
#26 |
www.zainobros.com
zaino ownz me......best out there by far........great for black cars...really gets it deep and gets rid of almost all the swirl marks......i know people that wont even try anything else but zaino....... |
#27 |
oh and BTW....zaino is a polish not a wax.......
#28 |
Gettin' Lucky In Kentucky
My trucks Indigo blue, and theres some pretty bad swil marks and paints circles, and scratches in it. You cant tell, unless its in direct sunlight, but I think it looks so bad, it kills me. Ive waxed and it didnt help, someone recommended Zymol, but the weathers been so bad I havent had a chance. If that doesnt work, what can I do? Thanks
#29 |
1st Texas Heat Wave 2003
Zymol works, I just used it on my indigo blue X, took some swirls right away with minimum work.....
#30 |
Did it get all of them out? I hope I can, because I was thinking about painting my truck another color, just to get rid of the swirls. If I dont have to do that, Ill get my rims a lot sooner.
#31 |
It got all I had out. Mine were pretty bad, and you can't see them anymore. So it worked for me.......
#32 |
xtreme101 try buffin it out w/ a rag or sometype of terrycloth towel or something it will rub it down and in and take away the swirls in the dark paint. thats what i do i got a 10" buffer and i wax pollish than buff and if the sunlight there are no swirls just reflections.
#33 |
spinnin Shysters
Location: just moved to the big town of prosper, tx User is: OffLine |
what do you guys use on your wheels to clean out the nooks and tight spots?
im getting some buildup in these areas |
#34 |
SK= Midwest's Elite
How do you get brake dust pitting off of chrome rims? Any good polishes? I got some compound im trying tomorrow but i wanted to know your opinions.
#35 |
ZAINO
If you want a wet glossy loof on a black truck get Zaino it is amazing stuff.It is the only stuff I will use.The more you put on the deeper it gets.Only need like 2 dime size drops dor the hood and so on.My opinion try Zaino you won't be dissapointed.
