Guys,
I decided to pull the pinstriping off my truck yesterday after seeing how crappy and stuff it looks since I mainly use it as a work truck. After pulling it off though, there are two small lines where the edges of the pinstriping used to be. Will just rubbing compound get this off or is there something else I can use? It looks good w/o the pinstriping, but the white lines kill it. Any help is appreciated. Thanks, Zach |
forum idiot
Re: After pinstriping is pulled off....
wax?
Senior Member
you may have the glue left there where the stripe WAS hence the "white" you speak of. try to use something like goof off or rubbing alcohol or some type of light solvent first than possibly a light compound than a polish than a wax. the problem your having where the stripe WAS is that your truck is slightly faded while where the stripe WAS is new paint never been faded from the sun yet. ![]() |
Rustbucket Club
If it's glue, 3M eraser wheel. Anything else, polish...
Mecha-Shiva
i used goo gone + a orbital buffer, don't be afraid to relaly lean into it on some parts.
wax it that same day |
could also be dumb ass cleared over it before u had it seen done before hope for you sake that not it if just glue left on there get some goo gone or rubber eraser wheel
NOT DONE TO MANY PROBLEMS
I can't find an eraser wheel anyone give me a link to one.? thanks
ZR2 member
Rubbin alcohol.Then wax afterwards.
Senior Member
I play in the street
jw where are u located in PA???
would that wheel take off the double sided tape stuff they used on the body moulding trim?
98' Cowl Induction
Here it is at Eastwood for 14.99 http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT when I pulled off the pinstripe I just did it in the sun, then went over it with my buffer and glaze. The only issue I had was when the cowl hood was painted they cleared over the front pinstripe. I had to pull the stripe off, I used a razorblade to take the hard edge off, then wet sand with 2000 then buff. No line, perfect blend |
