Short Bus Anonymous
100,000 miles, time to invest in a buffer! Help!
Well I just recently started to deatil my care and take my time, usually it was just a wash. Well a few months ago, I used a clay bar and then put on some mothers wax. Now I would like to invest in a buffer and try my hand at that. I am going to get the Port Cable 7336. I printed off a how-to on using the buffer from www.autopia.com and have been doing some research on what steps I need to take. It says first use a pre-wax cleanser, they used Sonus Paintwork Cleanser, apply with the Porter Cable. Then they say use a finishing pad or a buffing towel to remove the residue from the cleanser. Then they used P21S Carnauba Wax and applied with the Porter Cable and then wiped the haze away with a finishing pad. Are those two good products? And are those steps good? Will these work with the port cable http://www.autopia-carcare.com/sondas.html and is that backing plate just attach to the Porter Cable? So I am thinking of getting the backing plate, two blue pads and I am not sure if I should get two of the orange or green pad, I think the green as my paint is still okay, just swirls and dull in some spots or should I use the tougher one? And then two bonnets. Any suggestions/comments to first time user. Any help is greatly appreciated.
Hey kids!
Re: 100,000 miles, time to invest in a buffer! Help!
touchy subject as you can see in other posts
you dont want to use anypad thats to harsh. youll end up burning your paint off. thats not good. i dont know of the products they use for it. just go with the directions. does it say to buff with water to minimize swirls and heat causing the paint to come off? |
bagged1
As far as those steps... I would wash your truck well, clay bar the entire thing, polish the paint with swirl remover depending on the condition of the paint pick the proper pad/product combination. I like the Poorboys World SSR line of swirl removers, easy to use and work very well. http://www.poorboysworld.com And Raider660, the only reason one would use water while buffing is to mist the surface to make the product they are using MORE harsh/abrassive. Also its DIFFICULT to damage paint with a Portercable because its a dual action polisher, not a rotary. Last edited by dropped1 : 05-03-2006 at 11:41 PM. |
Short Bus Anonymous
My paint is like a tan, brownish. Thank you guys a ton for the help. So would you recommend the P21S Carnauba Wax still or ? And I will have to look at the poorboy stuff, thank you.
Hey kids!
bagged1
And if you have never heard of a Portercable 7336 or 7424...what kind of detailer are you? Last edited by dropped1 : 05-03-2006 at 11:54 PM. |
Hey kids!
ya dont listen to me. keep claying and like you said your paint still ist looking good.
your point is mute dropped1. |
Rustbucket Club
I buff properly and don't burn paint. I don't use water, I use a cutting pad, I use other pads, IO use a clay bar. Every day of the week...
Anywho, Pewter's an easy color to take care of. The PC is perfect for you ![]() |
bagged1
Durability? Protection? Wet Look? etc. |
under construction
hmmm we have this stuff at work, i will look tomorrow, and we just squirt it on the car and go over it with the finishing pad and then wipe it down with a terry cloth......comes out reall clean and smooth looking...
