Will a 95 Blazer passenger front door fit on a 95 S10 pick up truck? - S-10 Forum
post #1 of 19 Old 12-05-2009, 03:56 AM Thread Starter
User is: bigdaddykane93 is offline
hi all,
would a 1995 Blazer passenger side front door fit on my 1995 S10 pick up truck? are they the same door? thanks
1995 S10 4x4 Pick Up Truck Extended Cab 6' Bed with a Cap 4.3 Vortec CPI "W" Vin Engine and Automatic Transmission with a factory 3.73 Posi rear with Z85 increased capacity suspension...
post #2 of 19 Old 12-05-2009, 05:11 AM
Its Fish Stick Day
stoboi's Avatar
User is: stoboi is offline
Re: Will a 95 Blazer passenger front door fit on a 95 S10 pick up truck?
Yeah, it should. Im trying to figure out if a drivers side door off of a S-10 with a ex cab with the 3rd door will fit on a reg cab.
stoboi is offline
post #3 of 19 Old 12-05-2009, 05:14 AM
Its Fish Stick Day
stoboi's Avatar
Im guessing that they will all work, just kinda makes you wonder. They all look the same.
stoboi is offline
post #4 of 19 Old 12-05-2009, 10:58 AM
Zeeke98's Avatar
User is: Zeeke98 is offline
Front doors are all the same on S trucks including crew cabs / Blazer/ Jimmys / Bravadas from 94-03 on trucks and 95-05 on Blazers. 3rd door has nothing to do with the front door. Trim will be different on the Jimmys and Bravadas than an S truck though.
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #5 of 19 Old 12-05-2009, 11:29 AM
Doordragger
imfnlo's Avatar
User is: imfnlo is offline
There is to kind of doors all 94-97 and 98 up
Project <SOLO> Supporter
imfnlo is offline
post #6 of 19 Old 12-05-2009, 11:32 AM
Got me a Stepside!
dbailey92's Avatar
User is: dbailey92 is offline
Yeah ^ you cant buy a 98 door with 98 panels if you have a 94-97 Truck the panels wont match with the glovebox and the 94-97 panels wont mount to the 98 + door so make sure to get a 94-97 Panels and doors and vice versa
1995 S10 - 98 S10 front, 4/4 Drop, Shaved, Stepside, Stepshavers, 18 inch Panther Juice 5's
post #7 of 19 Old 12-05-2009, 01:44 PM Thread Starter
oh really? so i can only look for a 94-97 passenger front door for my 95 S10 pick up truck? otherwise i cant re-use my original door panel? is that correct? i also forgot to mention that i DO NOT have power windows or locks. so anyway, i just want to make sure i understand correctly....
post #8 of 19 Old 12-05-2009, 02:12 PM
Zeeke98's Avatar
I don't buy that the inner door is different and you can't fit any year door panel to it.
Wade
Zeeke98 is offline
post #9 of 19 Old 12-05-2009, 06:02 PM
User is: Sammytheorangutan is offline
The mounting location for the inside handle/lock assy is different but it's easy enough to swap them out by drilling a hole or two. I had '98+ inside door panels and power accy switches (working) in my '96 Jimmy. Took me all of 3/4 of a day to do it without any guidance. If you put a late 2nd gen door panel in an early 2nd gen truck, you'll have to figure out a way to extend the door pins (that turn off the overhead lights). I found a couple of 3" long rubber tubes that fit over the existing door pins and cut them to fit.
Looking for a perfect dk gray floor shifter center console. (I don't need the shifter assy.)
post #10 of 19 Old 12-05-2009, 11:34 PM
Got me a Stepside!
dbailey92's Avatar
If he's wanting to keep his stock panels with no work then yeah it don't fit. (Without mods)
post #11 of 19 Old 12-06-2009, 02:15 AM Thread Starter
also, how can i tell if the door is an original GM and not a repo chinese door? like lets say im im looking at a 95 parts truck, is there a date code somewhere on the door? or something that will tell me its the original door from 1995?
post #12 of 19 Old 12-06-2009, 12:46 PM
Got me a Stepside!
dbailey92's Avatar
Might want a 2nd opinion but I think there is a Gm tag on the inside of the door? My trucks been repainted and everything was stripped so I cant say for sure. ???
post #13 of 19 Old 12-06-2009, 01:06 PM
Zeeke98's Avatar
Most should have a GM sticker with the VIN of the vehicle on it. Drivers side also has a couple other GM information stickers as well.
Wade
Zeeke98 is offline
post #14 of 19 Old 12-06-2009, 01:38 PM Thread Starter
how about a date code stamping ? i noticed my fenders have a date stamped on the top insides where the bolts are, do your have a date code there too?
post #15 of 19 Old 12-06-2009, 11:46 PM
Its Fish Stick Day
stoboi's Avatar
They should come from the factory with some kind of manufacturing stamp I belive.
stoboi is offline
post #16 of 19 Old 12-07-2009, 02:54 AM Thread Starter
how can i find out?
post #17 of 19 Old 02-24-2010, 01:09 AM
i want this wheel
well worn s10's Avatar
User is: well worn s10 is offline
WOOOOOOOT! I found 20+ blazers in the junkards this weekend, but only a few trucks. And one had the door halfway off. I shall go remove it the rest of the way.
Trying to customize my s10 for $200.00 total. I'll do a build thread when I'm done. Trading and selling my way there.
'98 S10, 4.3 5spd, 300,500+ miles and it looks somebody bashed every panel with a hammer. Low budget slow improvements under way.
post #18 of 19 Old 02-24-2010, 03:32 AM
The Chop Shop
J Tizzle's Avatar
User is: J Tizzle is offline
I replaced a door on my '94 s10 with a '98 Blazer door(r/f),fit perfect.But...........I ended up cutting out the whole inner door structures out of both doors and welding 'em back together so I could stay with the '94 door panels/linkages,etc.It was kind of alot of work,but I already had the '98+ Blazer door so it didn't cost me anything,but some time.
2003 ZR-2 tukin' 24's
2000 S-10 Ext.Cab ZR-2
1979 El Camino 1984 El Camino
2001 Harley Sportster
1996 Suzuki Katana 600 1986 Kawasaki Klr 600 Enduro
J Tizzle is offline
post #19 of 19 Old 03-04-2010, 12:36 AM
i want this wheel
Are electric window and manual window door frames the same? Most of the ones I find in the boneyard have the door panels already missing.
