what temp do u put bondo on?? - S-10 Forum
post #1 of 20 Old 01-07-2005, 10:09 PM Thread Starter
91 S10's Avatar
User is: 91 S10 is offline
I have used filler and know how to use it properley (prep etc) but i was wondering if any one gets the panel or the area that they are applying filler to a certain tempurature? or can it be applied in any temp?
thanks
91 S10 is offline
post #2 of 20 Old 01-07-2005, 10:26 PM
Supa Fly
BlazerPimp's Avatar
User is: BlazerPimp is offline
Re: what temp do u put bondo on??
its better if it is warm..like room temp 70 degrees or so, and the area is completely clean...that has always worked for me.
post #3 of 20 Old 01-07-2005, 10:28 PM
00bluesdime's Avatar
User is: 00bluesdime is offline
the colder the air is the longer it will take to set up
post #4 of 20 Old 01-07-2005, 10:44 PM
88GMCs-15's Avatar
User is: 88GMCs-15 is offline
yes i agree with the above post. its possible to spread bondo on at -10 C but it takes all night to setup enough you can sand it. unfornuately (sp?) i dont have a real heated shop so this is what i have to do. i have a heater, but its still like at least -5C in there. if its colder, and you can play with it a little more because it takes longer to set.
Truck: 1988 S15 GMC Sierra 4x4. 2.8L V6,5speed manual.
Quads: 1986 Suzuki LT250EF(for sale) 4 stroke , 1994 Trailboss 250, 2wd, 2 stroke.
http://pg.photos.yahoo.com/ph/my_photos
post #5 of 20 Old 01-07-2005, 11:15 PM
User is: xdreamz99 is offline
agreed with all above, 70-85deg is best but if its colder just mix the filler hotter it shouldnt take too long to cure since most fillers are chemical curing not air cured, hot air=cold mix cold air=hot mix avg air=avg mix,
now i dunno about using it in -5deg weather but ive gone from about 50deg up to 105deg in texas and right mix worked fine,
post #6 of 20 Old 01-07-2005, 11:21 PM
THE SDIME98
stepasyd's Avatar
User is: stepasyd is offline
s i've mixed some in the cold and in hot weather
(SOLD) - 98 Regular Cab Stepside - (SOLD)
- 03 Crewcab ZR5 -
Yea, I'm still here.
stepasyd is offline
post #7 of 20 Old 01-07-2005, 11:55 PM Thread Starter
91 S10's Avatar
thats all i was wondering, DOES any one really KNOW if temp is related to how it will last in the long run or the strength?
91 S10 is offline
post #8 of 20 Old 01-07-2005, 11:57 PM
woof
whitedime's Avatar
User is: whitedime is offline
Send a message via AIM to whitedime
it doesnt matter dude. is what everyone is saying. just know its gonna take a while to set up. which might be good.
post #9 of 20 Old 01-08-2005, 12:38 AM
Hates 'know-it-alls'
User is: grndscrpr03 is offline
Send a message via AIM to grndscrpr03 Send a message via Yahoo to grndscrpr03
once it hardens it's gonna be as strong no matter what temp it was mixed in, the temp will only affect curing time
post #10 of 20 Old 01-08-2005, 01:14 AM
88GMCs-15's Avatar
yes its gotta be about -8C or so in my shop right now, and it sux spreading filler at that low of temp. it mixes and spreads the same, it just feels like its set up already when your mixing it thats all. but i would recommend you NOT to mix it when its that cold, unless you have to like me because i dont have a real heated shop. im wearing a pair of workgloves while working on my truck its so friggin cold in there. and if you take your glove off its freezing cold in less than 2 minutes. its gay.
post #11 of 20 Old 01-08-2005, 01:21 AM
wow, yea i bet at that cold the filler without hardener is just thick cus the cold, same with paint it thickens up when cold but flows better when hot
yea it dont matter about the long run, as long as it hardens b4 you paint it
post #12 of 20 Old 01-08-2005, 03:48 AM
88GMCs-15's Avatar
xdreamm- ya its a bitch to spread because like you said it gets thick and starts to freeze up. but im SOL, because its the only way i can spread it right now. and if i dont do it now, then i bet its never gonna get done.
post #13 of 20 Old 01-08-2005, 05:36 AM
not to hijak or nothin man but cant you hang some tarps over the sides and get ya a area heater or somthing to warm that shop up? thats so cold i wouldnt even piss in that if i had to!
post #14 of 20 Old 01-08-2005, 06:05 AM
User is: DevilDriver is offline
haha. you should live her in midwestern canada. the other day, it got down to -40C which is the same as -40F. i've spread some bondo and done some glassing and painting in temps below -20C and it's not fun in my garage. but i try and seal everything up and turn on a couple space heaters to make it almost manageable.
mind you, that post is only going to make MORE americans think we live in igloos
post #15 of 20 Old 01-09-2005, 12:38 PM
THE ANTIBOWTIE OUTKAST!!!
THE BAG HAG's Avatar
User is: THE BAG HAG is offline
How's that igloo work'n out for ya????
post #16 of 20 Old 01-09-2005, 01:14 PM
ibanez691's Avatar
User is: ibanez691 is offline
Send a message via AIM to ibanez691
get a shop heater damm i got a propane heater that was 100 bucks from lowes and i can get my garage to 90 deg in 10 min from freezinng.
There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter."
-Ernest Hemingway
post #17 of 20 Old 01-09-2005, 02:04 PM
88GMCs-15's Avatar
well we have a space heater. it does a not bad job of heating it. but i think im just gonna surffer the cold until my dad gets half of his shop in this year. because he wants to find an old furnace(sp? im slow today) and put it in there.
post #18 of 20 Old 01-13-2005, 06:30 PM
User is: dirtyworkcustoms is offline
when it's cold here i've used a heatgun on the stuff after it's spread to help it setup makes it alot faster
post #19 of 20 Old 01-14-2005, 02:00 PM
User is: aberrant is offline
If the surface is cold you should worry about condensation more than curing.
aberrant is offline
post #20 of 20 Old 01-15-2005, 02:14 AM
User is: 90s10 is offline
what r u fillin in with bondo, i hope not a bodyline or nuttin cuz thats what i was goin to do but all the fellas on here said that aitn good, so im goin to fiberglass it now. so goodluck and let me know what ur bondo is goin in and how good it works and do u use bondo alot?
90s10 is offline
