Sander Question
Go Back   S-10 Forum > General Tech > Exterior / Paint
Old 06-26-2008, 08:58 PM   #1
Static Truck owner
cuda_'s Avatar
cuda_
Sander Question
Whats the difference between a DA sander and an orbital esp. for body work?
Old 06-26-2008, 09:11 PM   #2
got beer?
paint toad's Avatar
paint toad will become famous soon enoughpaint toad will become famous soon enough
Re: Sander Question
by orbital i assume you mean a palm sander....they are both DAs,just palm sanders have a smaller orbit and are meant for finish sanding
Old 06-26-2008, 09:19 PM   #3
now XTREME
94redSS's Avatar
94redSS is on a distinguished road
Re: Sander Question
just to add....if ur gonna start doing body work learn to used good old blocks first im in my 3rd year doing auto body as a perfession an am now just learning how to get the d/a bodywork trick down.....just my $ .02
Old 06-26-2008, 10:44 PM   #4
Static Truck owner
cuda_'s Avatar
cuda_
Re: Sander Question
Thanks guys, exactly the info I needed.
Old 06-26-2008, 10:55 PM   #5
Grammar Nazi
dngrous_dime's Avatar
dngrous_dime is an unknown quantity at this point
Re: Sander Question
And just how evil is it to use a random orbital sander, instead of an air sander?
Like this one?
I don't have the access to air tools like I thought I was gonna, and I'm not doing finish work with it, either.
Old 06-26-2008, 11:17 PM   #6
now XTREME
94redSS's Avatar
Re: Sander Question
air sanders are for rookies
Old 06-26-2008, 11:30 PM   #7
got beer?
paint toad's Avatar
Re: Sander Question
what?????you're the rookie
i've been using air sanders longer that you've been alive and i am far from a rookie
Old 06-27-2008, 06:05 PM   #8
now XTREME
94redSS's Avatar
Re: Sander Question
.....ur just like all the old farts at work im a fan on 36 on the long board when the filler is tackey enough to sand it
Old 06-27-2008, 06:09 PM   #9
Grammar Nazi
Re: Sander Question
bump for my question.
Old 06-27-2008, 06:37 PM   #10
got beer?
paint toad's Avatar
Re: Sander Question
no...you are wrong....i do not like nor own an airfile......i use 36 on the longboard myself......or my 8" 'mudhog' (big da for those that don't know),depending on the situation,although any more,i don't do mudwork of that type.....back when i was paying my dues i used to have to save a shit load of panels because of tight asses....but i am fine with that,i would not be the bodyman i am today if not for that....
i try to not to put anything coarser than 80 grit on my long board anymore honestly...i am a painter,i shouldn't even own the tools...at my last job,all i took was my guns and my dynabrade.....
Old 06-27-2008, 06:50 PM   #11
dropt
Big_Bake's Avatar
Big_Bake is an unknown quantity at this point
Re: Sander Question
well DA is just dual action. exact same thing as a random orbital. it just means the disc itself spins as the whole thing moves around. DA is what it's called in the auto body world and are normally air powered. random orbital in the wood world and are electric.
Old 06-27-2008, 06:52 PM   #12
Grammar Nazi
Re: Sander Question
Kewl, so I didn't really "need" to buy that DA sander a while ago. Now that i have that knowledge, I need to get some of the good epoxy spray primer from the paint shop, and I can start getting shit done.
Old 06-27-2008, 06:52 PM   #13
got beer?
paint toad's Avatar
Re: Sander Question
brian,i wouldn't recommend that,but i guess you could use it....it'll get the job done but it will be awkward using that on a vehicle i think
Old 06-27-2008, 06:56 PM   #14
dropt
Big_Bake's Avatar
Re: Sander Question
yeah you might wanna find a round one. idk about using the one you pictured above. i have a porter cable random orbital here at the house. it uses the same size pads as my DA.
a DA is good for experienced body guys, but if your just starting out, a block will do more for you, especially on big panels that you are trying to get straight. it's takes way more experience to do good work with just a DA.
Old 06-27-2008, 06:57 PM   #15
Grammar Nazi
Re: Sander Question
I'm doubting I'll keep my original bed, anyway. Worth a shot.
Old 06-27-2008, 07:01 PM   #16
dropt
Big_Bake's Avatar
Re: Sander Question
what are the specs on that thing you posted above. is it just an orbital, or random orbital? what size orbit as well?
Old 06-28-2008, 12:08 AM   #17
Grammar Nazi
Re: Sander Question
1/4 sheet random orbital. Not sure which model exactly, I just know mine has the gel pad on the palm area.
Old 06-28-2008, 01:41 AM   #18
JSamsS10's Avatar
JSamsS10 is on a distinguished road
Re: Sander Question
Ive been doing bodywork for around 4 years now and i still cant get the DA down pat i knock my filler down with a DA then finish with a block
Old 06-28-2008, 02:59 AM   #19
got beer?
paint toad's Avatar
Re: Sander Question
that's the whole concept anyway
Old 06-28-2008, 06:44 PM   #20
optikal is on a distinguished road
Re: Sander Question
yea finishing bodywork with a da would make for one wavy mess
Old 06-29-2008, 01:36 AM   #21
dropt
Big_Bake's Avatar
Re: Sander Question
hmm guess it will work. i don't see how a square will spin very good. think of it as earth. it spins on it axis as it revolves around the sun. that's how a random orbital/DA work. most square sheets i've seen just vibrate around, but don't actually spin.
Old 07-02-2008, 04:32 AM   #22
pr0tus
Re: Sander Question
Not that it matters, but nobody answered your question. DA sander is an old term that is now stuck with orbital sanders, since there are no DA palm sanders. A real "Dual Action" sander, a National Detroit DAQ or one of the million copies, can be switched into a grinder by an adjustment above the pad. I doubt many people who own DA sanders even know about the feature, but now you know.
Old 07-02-2008, 06:20 PM   #23
now XTREME
94redSS's Avatar
Re: Sander Question
i found out the first time i used mine on a 1/4......btw ur from epharata i see im from quarryville
Page generated in 0.16273 seconds with 11 queries
