Paint toad or maverick!!
lol now that i got your attention, i got the truck fully sanded with 80 grit then with 220 grit, body work done and epoxy primed, whats the next step should i wetsand the primer with 600 grit then paint? or sand the primer with 320 then wetsand with 600?, im painting my door handels and mirrors, so what are the steps for plastic? sand/plastic adhesion promoter, prime,paint,clear? TYVM 4 THE HELP!
Short Bus Anonymous
Re: Paint toad or maverick!!
You sanded the whole truck with 80 and then 220? And we've never primed over anything over 180.
should sand with 180 on spots you did body work 220 should be fine over existing finish thats if the existing finish is/was in good shape
but any way next step should be to block with 320/400 ( i usaly to 320 first to break the surface then 400 ) using a guide coat after 320 after that you wetsand or da with 600 then sealer, base , clear plastic sand 180 adenshion, primer, sealer, base clear pretty much like you said |
i'm back
Location: morton il User is: OffLine ![]() ![]() ![]() ![]() |
i dunno......
Anyway, to the guy you should have sprayed a urethane primer over the epoxy. No sanding. |
Heavy Metal Body Man
i absolutely hate sanding epoxy primer, even after a month of curing and with 400 wet it was hell
NOT DONE TO MANY PROBLEMS
how long after spraying your epoxy primer can you lay high build over it?
i'm back
well,you gotta let it flash......for the most part i like to wait an hour before primer.....if you can wetsand dirt nibs out of the epoxy it is ready to topcoat
I usually wait 30 minutes or so. Never had any problems. |
progress is slow for now
30 min- 1 hr is pretty common, just aquire and read the tech sheets on whatever product you are using there is not really a reason to take a shot in the dark with it if you can get the info.
alright cool, the tech sheets i read said nothing past 3 days or something but never said if there was a waiting period i normally waited around 6 hrs to a day. paint hasn't come off yet, thanks
i'm back
ppg-dp-xx series epoxy primer,when using 402 activator, requires(i think) an induction period(30 minutes @70 degrees)...(MATT???)....to let the components stabilize,before you should stir it again and put it in the gun to spray it...... |
i'm back
I'll do it tomorrow maybe
Location: Kingston Springs, TN. User is: OffLine ![]() ![]() ![]() |
If you epoxy it and then sand down and find it to be smooth then use a reduced coat of epoxy as a sealer and spray your base coat and your fine. It's hard to say what you need to have done because if you need to do body work still, sand through primer, etc etc. Epoxy is a bitch to sand though so have fun! ![]() |
He said he was sanding with 180. Would be hard to spray reduced Epoxy, as a sealer, over 180. I don't see any grit fine enough to spray sealer over being able to be used to sand epoxy with, without major gum issues. Then again I have been wrong plenty. ![]() |
i'm back
and btw....you really don't know what i am doing or why ![]() |
Custom Painter
i think he was talking to me 402 requires no induction. they do however recommend a 5 minute mechanical shaking. (what a waste of empty metal paint cans) 401 requires a 30 minute induction. same deal with the 5 minute shaking. not recommended on bare metal. pretty much only for plastics, sealer or groundcoat. works awesome on rhinos and new bumpers as sealer b4 paint. u should never mix the 2 together. 402 has a 30 min flash time to topcoat either paint or primer. and filler can be applied over in a couple hours with 1 coat only or 2 coats it must sit over night before appyling filler. 401 has a 1 hr flash time. sealer mix using either is 2 parts epoxy 1 part 40x catalyst 1/2 part dt reducer. 8 hour pot life 402 mix 72 hour pot life 401 mix the epoxy never fully cures and i wouldnt dry to sand it ever. only to nib like toad said. always topcoat with ur sanding primer of choice. |
i'm back
yeah.....the 401 requires induction.....duh...i've even got the tech sheets in arms reach and didn't check the number
