Just wanting to double check.
Did some searching, I've got a truck thats had the filler and metal work done, the rest of the stock paint was da'd down and went over in 220. Was told to Epoxy prime the whole truck, then Shoot my top color, I'm just going to flat black it then pinstripe it in white and red. Should i use a filler primer over the top of the epoxy or is that just an un needed step?
i'm back
Location: morton il User is: OffLine ![]() ![]() ![]() ![]() |
Re: Just wanting to double check.
if you go back over your paint with 320 da and make sure it is perfect then you can just spot in your bodywork with epoxy,let flash, then topcoat those areas with urethane primer...let cure.....then block your primer spots finishing with 320-400 grit.....then you can reduce epoxy as a sealer,coat the whole truck then top coat with paint.......
follow that? at the point you are at,and you can be sure there are no imperfections then this is the way to go... |
i'm back
just pay me... ![]() |
i'm back
i'm just kidding....i don't have the time to do a project right now.....i'm backed up as it is..(with a waiting line too)
