#1
Inspired Soundwave
[How To] Tilt your bed!
similar job
hey man im wantin to do the same thing on my full size 02 sierra, can you show me how to make brackets to dump the bed like a dumb truck with air bags like you did from the side?
The Visionary
Old Skool! I love it.
DTC built
Re: [How To] Tilt your bed!
great how-to I want to do this bad..
My self esteem is lower
Thumbs up mod...
Man, that looks sweet as hell. I'm definately going to hold onto that how-to. :TUP: man
would this be possible to do with a stepside?
Awesome! What did you use for the upper bag mount? And my tailgate/ lights are shaved, would this couse it to crack?
bellcranks no more
Re: similar job
you gotta find a way to hinge it so the bed front bottom wont hit ur cab when it goes up. i would just have the hinge as far down as possible. optimally as low as the bottom of the bed. buuut you have a gap between the bed and cab. so you can pull off a bit more. |
Tattoos & 2tone paint
This tilt bed sounds like crap who would waste their time
![]() what up Christian?, How you been and are you still in school? Kerri Clayton is in a bunch of my classes and your name came up the other day, it was funny she said her boy friend hayes you, ha ha. How you are good man. |
YEA, WE CAN DO THAT
a waste of time .... thas a good one.....
YEA, WE CAN DO THAT
![]() ![]() i guess im guilty of "wasting my time " |
Registered Fabricator
haha, that's freaking great!! She is always trying to start some drama between me and her boyfriend. She's ate up, lol ...I've been good though, I graduated in December. I'm still in the boro, just looking for that career path right now. I've been putting my resume out a lot and getting quite a few bites, it's only time before I'm into something. ...when am I gonna see that amazing truck of yours back out on the road and dominating the show scene? pictures?? |
drifting 98 sonoma
i love the how to bro, that rocks! clean looking set up too! keep it up
Love how you tilted it to the side, something I have never seen before.
I love wasting my time.
'01 Noma
If you place the hinges almost exactly where the last mounting bolts are, then it will clear the cab or will after a very slight amount of trimming.
![]() If you can imagine these welded up into that. Works fairly well if it didn't warp slightly and make it impossible to fit the 3/4" bolt through them. ![]() ![]() It was really cool actually but I ran into to many problems and decided to scrap the whole project. One main reason was to show off the remote mounted turbo but I went with an engine mounted one instead. I had problems getting the hinges to line up, I mounted the bag in the back about 13" from the hinges which would have worked with more supports, but it actually bulged out the bed when I lifted it. The bed was also loose on the hinges and clunked around alot. I finally decided that it wasn't worth it for me. I'm more into the sport truck category so the extra weight didn't help either. One thing I thought that would have been sick was the fact that I would have to lift the bed to fill my tank (plus shaved gas lid). I couldn't imagine all the "wtf" stares I would have got. |
Heres mine so far.. im still waitin for the valves to show but other then that its ready to go..ill get some vid of it when everthing arrives..
Lil' Red
Hola Bitches
TUCKIN
bellcranks no more
any pics of sumone's setup for a backwards tilting bed?
#24 |
that's sick, i guess i have a new idea for the rebuild of my dime...
#25 |
Diverse Imagez
i have a question on your air tank, did you custom fab that? if so what guage steel did you use, and how many gallons is it, and how much psi can it hold?
this info would be greatlt appercated, for i'm trying to get ride of my two bulky tanks, to make room for my four link. |
#26 |
whos that reply to dragon_lowrider?
#27 |
Diverse Imagez
who ever wrote this tech, or anyone that has the same type of tank |
#28 |
i would like to get some info on how ppl that have done this strengthened the box so it won't twist when lifted also more pictures of the box and also picture of a rear tilt setup hinge would be kool thanx all
#29 |
bellcranks no more
i guess side tilting wouldnt need quite as much if any bracing... but tilting it back would most likely need some. and to keep the bedfloor from buckling as well. im planning on doing this this summer so hopefully ill be able to do a nice how to on that |
#30 |
FloridaTruckScene.com
Is this possible to do with a camper top?
#31 |
bellcranks no more
#32 |
#33 |
bellcranks no more
personally i think itll look dumb tilting a camper top.
one or the other imo |
#34 |
great how-to!!!!!!!!!
i guess i found me another project ![]() my bed is fully welded and tubbed on the top so the only way to access my air managment is from the bottom of the truck, yet are there any close ups off the dump type? sounds like it would be a b*tch to get without hitting the cab..... :| |
#35 |
#36 |
bellcranks no more
what do you mean by 1/4 ton air hydrolics? you mean cylinders? and at what pressure? what diameter? |
#37 |
I would just invest in a cheap, small bag. The bag allows for flex and is easier to mount IMO. BUT, the air cylinder would use less air volume and be a LOT faster, maybe to fast, depending on how far you mount it from the pivot point. The closer to the pivot point, the faster and more air pressure it will require. But closer will require less air volume to fully lift the bed.
#38 |
YEA, WE CAN DO THAT
ive been out for a while due to a ATV accident and then getting sick not long after with sum virus (SUCKED!!!) anyways, im back and im gonna see about adding to this tech HOW TO as far as the bed tilting as a standard "dump" bed. as soon as i can get everything together including pics and find time to post , ill do it. take care
Q |
#39 |
bellcranks no more
awesome. looking forwards to it
#40 |
where's my chippy?
thats sick man, i love it, i also love your grille, what kind is that
#41 |
Its a Billet Specialties I got through Stylin Concepts a few years ago for about 125. Not sure how much they are now or where to get them from. I'm sure it's still about the same
#42 |
I'm thinking about doing this but you think its possible to use an actuator
#43 |
#44 |
its not a waste it time its very helpful if u need to service your air ride in the rear........or service n e thing in the rear...................................way bettte than pulling the bed and disconnecting wires
#45 |
#46 |
Fish sticks hard as tits
I think that guy is just jelous b/c he didnt do it himself.
they both look sick. I would do it if I had the money....but I have alot of other shit to knock out first. |
#47 |
snapdaddy
any one got some new updated pictures?
#48 |
bellcranks no more
#49 |
snapdaddy
got any pictures of the air bags,
#50 |
bellcranks no more
its not lifting under its own power yet
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f72/how-to-tilt-your-bed-270514/
| mazdabscene.com ~ View topic - old school mods | This thread | Refback | 11-30-2007 01:01 AM | |
| mazdabscene.com ~ View topic - old school mods | This thread | Refback | 11-29-2007 11:25 PM | |
