how to: suicide hood 2nd Gen
Go Back   S-10 Forum > General Tech > Exterior / Paint
Old 02-17-2005, 07:00 PM   #1
y2kblkxtreme's Avatar
y2kblkxtreme
OK here it is as promised, not too many pics to go along but i'll talk you through it. It's very
simple to do heres what you will need:
Hood hinge out of a mid 80's buick le sabre and all mounting hardware
Welder
Tape measure
Tubing cutter, a sawzall will also work but you cuts will not be as straight
OK first things first, you need to do is take a measurement of the width of where you will be mounting the hinge on the truck. If i remember it's like 2 and a quarter inches or so that you need to narrow the hinge. I did this by cutting the bar in the long section and welding it back together there. Pic:
After you have done this it is time to mount the assembly to the fenders. There is a hole down on the lower part of the frame where you can line up the hole on the top of the bracket to. I'll try and snap a picture of this tomorrow. Then just drill a hole for the bottom one and bolt it in. The bottom of the bracket should be about 1/4" away from the radiator/front support. I took the time to make a weld between the bracket and there for added rigidity. You will also need to reinforce where you bolted the hinge to. This is easily done with a piece of flat steel welded between there and the front support.
Now that the hinge is mounted to the truck, you will need to cut the middle bar off once again, so that you can rotate it and weld it back together so it will clear all the hose lines and such under the hood. pics of welds:
I dont know if it's necessary but i took the spring off the hood and welded it to the core support and removed the secondary latch, because they would rub the bumper. A little modification to the stopper on the hinge will allow it to swing out further.
Once this is done, it's time to start to attach the hood to the hinges. I personally dont have fenderwells in my truck so i just layed the hood down, pushed the hinges up onto the hood and tac welded them in place. Then I put a nice bead all around the bracket. I will take measurements if anyone would like so u can just measure and weld it in place.
Once this is done, close your hood and make sure everything sits flush, There was alot of massaging i had to do under the hood for it to sit flush and i assume it will be different for every truck due to mounting variations.
Good luck trying this on your own truck, hope this helps a little bit.
Old 02-17-2005, 07:07 PM   #2
illusivedreams.org
Bagged4MyPleasure's Avatar
Bagged4MyPleasure is on a distinguished road
Re: how to: suicide hood 2nd Gen
THANK YOU!!!!
**Edit** Location of where the bracket is mounted to the hood would be very helpful. Also, what you did to keep it from flying up in the rear, by the front windshield.
Old 02-17-2005, 07:17 PM   #3
Bad Mother F***ER!
dymetyme95's Avatar
dymetyme95 is on a distinguished road
thank you thank you. Think I may just do that. My buddy is doin it to his first gen.
Old 02-17-2005, 08:32 PM   #4
Hates 'know-it-alls'
grndscrpr03's Avatar
grndscrpr03 will become famous soon enoughgrndscrpr03 will become famous soon enough
you Are The Man!!!!
Old 02-17-2005, 10:26 PM   #5
Suicide Hood Guru
Nite Dragon's Avatar
Nite Dragon is on a distinguished road
kewl... i get out of writing one up with this crappy keyboard... good job...
Old 02-17-2005, 10:43 PM   #6
98 Noma ZQ8
thrteen's Avatar
thrteen
Thanks for the info! i'v been waiting a long time for this. i need some more info on the latching system, as well as some more pics.
Old 02-18-2005, 06:03 AM   #7
Afterhours Admin
AVTekk's Avatar
i dunno, it seems pretty confusing and the descriptiong are vague at best. i can figure it out but i think it will leave most people with a lot of unanswered questions..
Old 02-18-2005, 12:51 PM   #8
DfntPntbll's Avatar
DfntPntbll is on a distinguished road
Wal Mart Fuse Holder! Run!!!!!!!!
Old 02-21-2005, 04:35 PM   #9
feliz's Avatar
feliz is on a distinguished road
Did you have to relocate the fuse box, coolant reserve and ECM? Or is this a factor only on 4cyls?
Old 02-21-2005, 05:50 PM   #10
illusivedreams.org
get those new pics yet man?
Old 02-21-2005, 05:54 PM   #11
355 member
scrubz's Avatar
scrubz is an unknown quantity at this point
you know I may consider doing this later on down the road. From the hardware needed, it don't look that expensive, as most things, the install will be the most costly
Old 02-21-2005, 06:55 PM   #12
woof
whitedime's Avatar
whitedime is on a distinguished road
i think its time you picked up a bottle for your welder.
Old 02-28-2005, 12:29 PM   #13
illusivedreams.org
I did this this weekend, and Im sorry to say, but your pictures suck ass. Im getting better pics today at lunch.
Old 02-28-2005, 12:37 PM   #14
ROD TWISTIN MEMBER
dropped94's Avatar
dropped94 is on a distinguished road
well go on with your bad self I wanna see
Old 02-28-2005, 01:09 PM   #15
illusivedreams.org
Ok, here are the pics I have so far. Had to do some fabbing. If you look at one of Y2K's pics, there is a gap, or lower section of the hood on the drivers side and he welded to part of that but unsure where on the back side of the hinge, because you cant see it and there is nothing to weld too there. So I fabbed up a filler piece for there so I could weld the hinge too it.
My bro Jay and I also reworked the drivers side taillight.
Click thumbnail for larger pic.
Thats all the pics I have right now. Need to get the dust cleaned off at lunch and take some more pics. Got finished to late last night.....Also, my hood hits the tops of my hinges, so I need to lower it with some washers. Ill get pics later.
Old 02-28-2005, 02:48 PM   #16
illusivedreams.org
started a new thread for my work.
Committing Suicide
Old 03-01-2005, 08:39 PM   #17
Same Poop,Different Scoop
devilman13xx's Avatar
devilman13xx is on a distinguished road
i know that the ecu is in the way on a 4.3
Page generated in 0.18385 seconds with 12 queries
