Homemade tonneau cover - S-10 Forum
 2Likes
  • 1 Post By beandip
  • 1 Post By Ordie
post #1 of 36 Old 06-09-2006, 04:44 PM Thread Starter
User is: Philb is offline
has anyone tried to make their own tonneau cover, probably a bad idea?
Philb is offline
post #2 of 36 Old 06-09-2006, 07:04 PM
Totally Confused
dickeydoo's Avatar
User is: dickeydoo is offline
Re: homemade tonneau cover
I havent but i'd be interested......all you need would be some sheet metal, some kind of lightweight tubing and a welder.....or fibreglass a frame of some kind....hmm have to think about that
post #3 of 36 Old 06-09-2006, 07:06 PM
Roadrunner=Chicken
Dozer600's Avatar
User is: Dozer600 is offline
Just need plywood, fiberglass, hinges, rubber gasketing, heavy gas hood props and a lock or 2. Fiberglass to protect and seal wood and allow for a good painting surface and you can imagine what the rest would be for. Would not be cheap but you could make it to look how you want.
Jason
98 2.2 5 speed
87 Astro (Next project: Topless with V8, lifted on a 80' Blazer frame)
54 John Deere 40U
00 Polaris 600 Touring
Dozer600 is offline
post #4 of 36 Old 06-09-2006, 08:32 PM
is a fungineer
ka_jd7and1's Avatar
User is: ka_jd7and1 is offline
Send a message via AIM to ka_jd7and1
I was going to make one with either square tube or angle for a frame with sheet aluminum over the top, but I bought one instead. =P A flush-mount design would be a cool cover to build though.
post #5 of 36 Old 06-09-2006, 10:25 PM
xplicit kustoms
lowdime's Avatar
User is: lowdime is offline
i was planning on making on from a sheet of plexi glass but having some trouble finding someplace that will have it big enough around here
just bought 09 wrx this thing is quick
98 s-10 convertible 2.2 bagged and fully shaved, cowl induction hood, e-fan, als header, stage 2 jet chip, helix tb spacer, custom exaust, home made intake, bucket seats,in dash dvd,pa fubr 12" sub,hifonics bx1200d amp clear corners all around and best of all primer
my other rides is a ducati
lowdime is offline
post #6 of 36 Old 06-09-2006, 11:54 PM
jds_truck's Avatar
User is: jds_truck is offline
Send a message via MSN to jds_truck
make it a 2 part tonneau then with hinge in center
post #7 of 36 Old 06-11-2006, 03:38 PM
User is: S105.7 is offline
i dont have pics anymore but i built one out or alum. i used 1" square tube and made a frame to fit inside my box then skinned it with sheet alum...then wrapped it in white vinal cus the truck was white...and like already said used hood props and hinges and a lock...workes awesome...i wanna build one for my noma if i do ill get pics and do a how to...
S105.7 is offline
post #8 of 36 Old 06-11-2006, 11:55 PM
User is: spaz100 is offline
i made my own. all i used was a 4'x10' piece of wood, some 2''x1''x1'' piece of wood "rails" and a piano hinge. i cut it to fit the truck, and coated the underside of it w/ thompsons waterseal, and i coated the top with undercoat (NOTE: DONT put the waterseal on the top then coat it with undercoating, it will rub off very easy.) just be sure to use a soft undercoating, hard ones wont flex with the wood and it'll crack. you kinda have to figure out your own way to clamp it down. i just used a sort of l-shaped block of wood and ran a bolt through the top of the cover. for the part up near the cab, i made a sort of wedge so it will slide into place with the inclining surface near the cab (just take a look at it and you'll know what i'm talking about) so basically all you can see on top is the hinge and the 4 bolts holding it down, easy to get at & take off, i can do it completely by myself and i dont have to climb into the bed to do it.
i didnt use fiberglass because it would have to be put on VERY thick. otherwise the wood will flex and crack the fiberglass. the undercoating works just fine, and if you put it on thick enough you cant even tell it's wood.
pics:
i rounded & cut the edges so it wouldnt hang off the edge of the truck, now it looks like cake!
edit- came up to be <$100 too, cheaper than soft tops.
spaz100 is offline
post #9 of 36 Old 06-11-2006, 11:56 PM
The doctor is in...
Dr. Nate's Avatar
User is: Dr. Nate is offline
Send a message via AIM to Dr. Nate Send a message via Yahoo to Dr. Nate
A checkmate is pretty cheap.
2003 Xtreme ~ Toy
2007 Silverado ~ Tow Pig
Dr. Nate is offline
post #10 of 36 Old 05-26-2009, 03:05 AM
Wondersmith
StirFrey's Avatar
User is: StirFrey is offline
do u have any pics of the inside of yours spaz? like how it was mounted?
It isn't a death wish. It's about living.
-95 Noma (see thread >) - 2.2 5-speed http://www.s10forum.com/forum/f30/pr...sinoma-433674/
StirFrey is offline
post #11 of 36 Old 05-26-2009, 03:27 AM
joining 2.2l boosted club
1tuffs10's Avatar
User is: 1tuffs10 is offline
wow this is an old thread
2000 xtreme top mount twin scroll t3 header/custom 2.5" straight pipe/ac-delete/56mmtb/lowered 4"/ 44lb injectors/hptuners software tuning/baby blue H.I.D kit/carbon fiber ram air hood/ electric fan conversion/ Turboed with T3/T4 running at 9psi e-85/msd ignition/nkg plugs 2 steps colder/.63 ar hot/50 cold compressor
1tuffs10 is offline
post #12 of 36 Old 06-19-2009, 12:54 PM
User is: Jack Williams is offline
I know this is an old thread but I just finished my cover. It is 1" foam framed with cedar. It is attached to the bed with 2 thumb screws and 2 pins for easy removal. It is covered with padding and the black naugahyde. It is lifted with 2 18" actuators wired to a wireless remote located in the cab. The actuators came from www.firgellauto.com You can check out a video at http://www.youtube.com/watch?v=-HSCx8l93kw or pictures at www.crownmycar.com search for pickle .
ID:	104612   Click image for larger version
ID:	104613   Click image for larger version
ID:	104614   Click image for larger version
post #13 of 36 Old 06-19-2009, 03:55 PM
Address for actuators was incorrect. it is:
http://www.firgelliauto.com
post #14 of 36 Old 12-07-2009, 11:23 PM
User is: Streetrodder is offline
I've built two home made tonneau covers with fiberglass. One on a one off the line International Harvester C-900 ONE ton shortbox, stepside, pick-em-up-truck. I built it to go over the siderails of the box, to totally enclose it. It's the first one I built. The second was on my '48 Ford F-1 Pro-Street shortbox, stepside half ton pick-up truck. Again in fiberglass. It's quite easy. If you go to any car parts store, they sell all the products you need to form fiberglass. Laying the glass is the easiest part, forming it with a grinder, and sander takes much longer. If anyone is interested in seeing a finished product picture, you can write me at : Streetrodder@aol.com, and I'll get you a picture............thanks , COOTER
post #15 of 36 Old 12-07-2009, 11:53 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
sorry but i was just laughing at the idea of using 1" foam as a tonneau cover, but now that i look at it you really cant tell.
Chrisweber96 likes this.
-Jonathan
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #16 of 36 Old 12-08-2009, 01:13 AM
Better post-em.
comics22's Avatar
User is: comics22 is offline
i made my own outa plywood. ill see if i cna dig up a pic or two.
well dont have one of it closed... have 2 with it open
used regular hinges, sheet of 3/8" plywood
some 1X3 strips for support underneath
some aluminum C channel around the edge
a hood pin kit and 1 small locks to lock it to make it somewhat secure.
as you can see it kinda folds up over the cab, still allows the doors to be open
BUT i did find out the hard way you cannot use the wipers with it open lol.
i can remove it its attached to the bedrail by 4 carrage bolts.
^^^ can kinda see it
comics22 is offline
post #17 of 36 Old 12-08-2009, 10:24 PM
Varides.com
Stehl's Avatar
User is: Stehl is offline
Send a message via AIM to Stehl
I like Jack Williams
idea , only thing i would do different is maybe re-enforce it with some 1/4 inch plywood underneath.
Hey jack williams, check you pm. I have a few questions.
The Virginia Rides Forum
http://varides.com
Stehl is offline
post #18 of 36 Old 12-10-2009, 10:23 PM
Just got back to Forum. I used cedar for the frame and a cedar board to connect the 2 pieces of foam. This is where I connected the accuators. I'm building a boat now and I would probably use fiberglass over the foam.
www.youtube.com/woodmanjack1 Thanks
post #19 of 36 Old 12-21-2009, 07:02 PM
User is: andyvan88 is offline
I made one for my truck with an aluminum "C" channel screwed to the inside of each bed rail and to plywood panels that slide into them. I bought some toneau material from an upholstery shop and stapled it over the ply wood. I put a locking tailgate handle on it and it works and looks great. Since i used two panels they are easy to handle and i can lay them down flat inside the bed if i don't want the cover on. Just make sure to seal everything up real good... mine is dam near waterproof.
post #20 of 36 Old 12-22-2009, 12:48 AM
Better post-em.
comics22's Avatar
would you mind posting up pics? i like your idea but havin a hard time picturing it.
comics22 is offline
post #21 of 36 Old 03-12-2010, 08:27 PM
Acexofxspade's Avatar
User is: Acexofxspade is offline
Here's mine done about a year ago. no leaks or problems. Made with 5/8 "kresson" Plywood..Its Standard plywood with a fiberglass lining Alluminium "g-trim" all around for finishing ang reinforced with alluminium t bar =D total cost about 150$
post #22 of 36 Old 03-12-2010, 08:36 PM
Ridin' on Twankies
colbye32's Avatar
User is: colbye32 is offline
Send a message via AIM to colbye32 Send a message via Yahoo to colbye32
^^looks good.
but damn,you need to lower that thing.
00' Noma, bagged, 20's, heat/ac, multicolor - Zq3-Specialty Road Head Package
colbye32 is offline
post #23 of 36 Old 03-12-2010, 09:06 PM
Ya i know. im thinkin about 3/4 drop + 16" iroc-z rims also need a new paint Those pics are old. Now have 98+ s-10 Grille =D
post #24 of 36 Old 03-12-2010, 09:31 PM
m4d l473
User is: n3f4r10u5 is offline
Meijers in Westerville off of Polaris ave. has a soft tonneau cover on clearance for 64.99 for an s-10.
I picked mine up there, just thought I'd put it out there.
-Rob
post #25 of 36 Old 03-12-2010, 11:27 PM
Jeff_R's Avatar
User is: Jeff_R is offline
take a big piece of fleece like blanket material i recommend close to the color that you are going to paint it cover a piece of wood the size of the top of you bed use fiberglass resin to harden the fleece and protect the wood place hinges and lock then ta da you have a cheap bed cover for under 100 that can be smoothed and painted just like the ones that they sell you can also add weather stripping to seal it onto the bed and have a water proof cover to protect the contents of your bed its the same as making a custom sub woofer box
bagged 1997 with 18in boss rims
Jeff_R is offline
post #26 of 36 Old 03-13-2010, 02:11 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
Re: Homemade tonneau cover
Moved.
I didn't realize how old but it's still useful with pics.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #27 of 36 Old 03-20-2010, 10:10 AM
stylin007's Avatar
User is: stylin007 is offline
I made one awhile back.I had a black vinal one with the old velcro strips that held it in place.I made a L bracket that ran the length of the bed on both sides and fastened it down 3/4 of an inch to make the plywood flush .Then I cut my old vinal up contact cemented it down.thats it looked great too.no pics tho but very easy
post #28 of 36 Old 03-20-2010, 12:58 PM
poop
JCmopar's Avatar
User is: JCmopar is offline
I've thought about making one like this, If i did it, id rivet the sheet of aluminium to the top and scuff it to give it a brushed look.
JCmopar is offline
post #29 of 36 Old 03-20-2010, 04:54 PM
4FX
4FX's Avatar
User is: 4FX is offline
Try using balsa core. build a jig/pan lay down 2 layers of cloth then two layers of mat lay in the balsa core then 2 and 2 with the cloth on the outside. I have built molds and produced engine hatche for a few offshore boats, with people some big walking all other them. with this layup should be about 65-80 lbs. using 1807 and 1708 weight cloth and mat. also gelcoated them
here' a couple that I've made
ID:	109957   Click image for larger version
ID:	109958   Click image for larger version
03' s10 ext cab soon 2 b a WS10 with LS6 405hp
99' WS6 Ram Air Trans Am 2,318 miles 1st owner
01' 35' Playboy Edition Cigarette powerboat 113MPH so far
4FX is offline
post #30 of 36 Old 03-20-2010, 05:03 PM
4FX
4FX's Avatar
couple more. These all cost me about $200-400 to build bepending on size and the addition of scoops. hope this helps
ID:	109960   Click image for larger version
4FX is offline
post #31 of 36 Old 08-16-2010, 06:20 PM
User is: 141265 is offline
Nice job !!
141265 is offline
post #32 of 36 Old 08-16-2010, 06:32 PM
rolling work in progress
Mr.woodscrewsNbondo's Avatar
User is: Mr.woodscrewsNbondo is offline
if you can weld maybe you could use a few sticks of L shaped metal for sides to sit plush with the bed, make a frame in between, then put a piece of sheet metal on top.
post #33 of 36 Old 08-18-2010, 04:12 AM
Professional Insultant
TokoDragon's Avatar
User is: TokoDragon is offline
Send a message via MSN to TokoDragon
I think it was on these forum that someone made it out of left over Vinyl fencing. Sat flush in the bedsides. Would need work to be water tight.
post #34 of 36 Old 08-19-2010, 05:03 PM
User is: Ordie is offline
Send a message via AIM to Ordie Send a message via Yahoo to Ordie
Like this one?
Greg
2013 Focus ST(3), Tuxedo Black, Cobb Accessport Tuner, Steeda Shifter/Bracket, 20% Tint
1996 S10 LS Ext Cab, 4.3, Auto - 3"/3.5"
Ordie is offline
post #35 of 36 Old 08-19-2010, 05:18 PM
No More SS
SmokeeJay's Avatar
User is: SmokeeJay is offline
I had a friend in High School that made one for his Toyota out of plywood. It was hinged in the middle. He covered it in black vinyl. I wish I knew how he mounted it. It was flush and looked really good.
Jason
Sold on 12/7/10 97 SS - 5/6 drop, 225/60/15's on swirlies, Shaved TailGate, Flowmaster, Kicker 10" Sold on 12/7/10
01 2dr Blazer - Daily Driver - 3/4 drop, 225/55/16's on 1st gen ZQ8's, Kenwood 200 watt amp/10" Sub
post #36 of 36 Old 12-03-2010, 10:34 PM
User is: johnsons63 is offline
hi, is it cheaper if will make a homemade tonneau cover than purchasing it? i haven't try making one because i think it will require a lot of time making this but im still interested...
____________________________________
Homemade tonneau cover, i wanna try this
