****ing rusted ass body mounts - S-10 Forum
post #1 of 24 Old 12-10-2007, 08:40 PM Thread Starter
I Rather Be Wheelin'
ChrisInVT's Avatar
User is: ChrisInVT is offline
I really hate this truck, it's getting ridiculous....
So today I decided it was time to replace the rear cab mount brackets (in the following pictures you'll see why). Well I figured while I was at it I'd fix the metal that's rusted on the cad side of the body mounts so they don't go through the floor (like some of them look like they're about to do). Figured, hell - while I'm at it I'll install that 2" BL that I've had laying around for about 9 months now too, the truck could use the new hardware.
Boy did I not know what I was getting myself into! I thought that my impact gun and my ridiculously large breaker bar would save me from the rust. Well all they both managed to do was rape the body mount bolts, which I now cannot remove. I really would like to get these things out as I have to completely replace the rear two body mounts and brackets soon, and other bits and pieces.
I could really use some ideas on how to get these freaking things out.
Excuse the pics, it's kinda tricky laying on a creeper a with a DSLR...
(All clickable thumbnails)
The pile of rust the impact gun made
Left rear body mount & support I'm replacing
Left middle body mount and cab support I need to replace
Left front (not radiator) body mount
Right rear body mount & support I'm replacing
Right middle body mount... This is what most of them look like before I take the impact gun or breaker bar to them.
It's freaking ridiculous. I wish I could just find a good used cab, but where I live this truck is in better condition than most. Already replaced cab corners, rockers, and most of the floor already. Now this body mount problem is a big pain in the rear.
Originally Posted by 96superflow View Post
Who needs independent suspensions when you have independent engines?
1987 4.3L 2D GMC S-15 4WD X-Cab Anti-Bro Truck (4.3 & 700R4 Swap, Custom bumpers, too many other mods. )
post #2 of 24 Old 12-10-2007, 09:11 PM
started as a 4X4 anyway
Demotte4x4's Avatar
User is: Demotte4x4 is offline
Re: ****ing rusted ass body mounts
My 84 4X4 S10 was the exact same. I needed to take the cab off to finish the body drop and do some frame work. On the rear two, cut the bolt heads off, cut the rivets off that rivet the bracket to the frame, with the bracket gone and the mount off all you have left there is a long bolt-with-no-head that is easy to take out with vise grips and a torch.
The middle ones and front ones are the hardest. All 4 of the plates that are welded to the floor for the mounts on mine were toast, getting the head off the bolts is the hardest part, especially if they have that metal plate on them still. I found it easier to use a cut off wheel to make an X in the head of the bolt and hit it with an air chisel. 3 of my studs I could not turn, even with heat, so I used a hole saw to put a 1" hole in my floor right above the mount, hit the stud with a BFH so it breaks the welds on the top nut, take it out through the floor, weld up hole in floor when done putting in new mounts.
Not what you wanted to hear, I know, but it is a crappy job. Rust sucks, no way around it.
91 Jimmy, 4.3, 4 door, 5 speed, bagged, bodydropped on 20s
92 std cab/bed, bodydropped daily, bought it the most hacked truck in the world and gave her the love she deserved.
Laying 4 doors build
http://www.s10forum.com/forum/f30/la...-doors-394464/
post #3 of 24 Old 12-10-2007, 11:30 PM Thread Starter
ChrisInVT's Avatar
That sounds like a ****ing nightmare. The rears I'm replacing the brackets anyway so that wont be as much of a bitch to do, but having to cut a hole in the floor and messing more shit up sounds like too much of a bitch to do. I'll really hat to do that if it's the only way to go.
How the hell did you get to the front ones by the wheel well?
post #4 of 24 Old 12-10-2007, 11:33 PM
Demotte4x4's Avatar
From top or bottom?
post #5 of 24 Old 12-11-2007, 12:54 AM
85smallblock's Avatar
User is: 85smallblock is offline
Send a message via MSN to 85smallblock
surprisingly my mounts were in not bad condition for how bad the cab corners rockers and floors were. I would have NEVER used a breaker bar on anything rusted. ALWAYS impact. ur lucky the nut welded to the mount on the cab side hasint broke loose like mine. I might be drilling a hole with a hole saw in my floor to weld a nut on the inside......
my washers that hold the rubber in were like dust.... i dropped them on the ground and they fell apart!!!!!! just to think me flying around a corner and those puppys coming apart
since your this far replace EVERYTHING.
and I can relate in the fact that finding a clean first gen in a salty canadian city is literally imposible
good luck with that
-85' std cab sb lowered 5-6 16" GTA wheels. 295-50-16 rear 215-55-16 front, 305 tpi v8,700r4 stage 2 shift kit,tci 2000rpm stall,hedman elite shorties,jegs 2.5" true dual mandrel bent exhaust kit,
in progress............. Project Thread
SOLD
-92' TEAL BLUE s10 BLAZER 4X4 4DOOR 4.3 TBI. LOADED. GETTING LOWERED WITH 95' Z28 WHEELS SOON
post #6 of 24 Old 12-11-2007, 09:52 AM Thread Starter
ChrisInVT's Avatar
Yeah, but that breaker bar is the only thing that's removed some of the bolts on that truck. Most of them the impact gun won't even touch, it won't move 'em at all until I hit 'em with the bar. I tried not using the breaker bar on the body mounts in fear of doing just what you said, but when the impact gun wouldn't move 'em I figured it was worth a shot... Boy was I wrong...
post #7 of 24 Old 12-15-2007, 11:32 PM Thread Starter
ChrisInVT's Avatar
Heeeeey... What about a set of these things
http://www.sears.com/shc/s/p_10153_1...+Taps+%26+Dies
post #8 of 24 Old 12-18-2007, 10:03 PM
NICE WELDS MAKE ME =)
SCOOTER77's Avatar
User is: SCOOTER77 is offline
Im Right There With You Man, I Have A 91 Reg Cab. I Suspected The Mounts Would Need Attention But Damn ! The Left Side Of My Cab Is Just Sitting On The Frame, Not Bolted, Mounts And Mount Washers Completely Rotted Gone. If I Hadnt Already Put So Much Work In This Truck I Would Probably Be Listing It For Sale. Keep Your Eye On The Prize, Well Atleast Thats What I Keep Tellin Myself
post #9 of 24 Old 12-18-2007, 11:49 PM Thread Starter
ChrisInVT's Avatar
What seems to get me is the fact that my '91 parts truck was rotted; and the cab and body mounts were in MUCH worse condition than mine - but they came off with no problems at all.
post #10 of 24 Old 12-19-2007, 01:22 AM
Low N Slow
MINIGfather's Avatar
User is: MINIGfather is offline
I'm getting ready to tackle the same thing. Came out to my truck the other morning for work and found the mount washer and a pile of rust sitting in the driveway...WOOHOO!!! I can't wait to start on this job. Where is a cheap place to get the body mounts? Auto Zone told me bout $70 for all the cab mounts.......
post #11 of 24 Old 12-31-2007, 08:01 PM Thread Starter
ChrisInVT's Avatar
Well, $55 later those things were completely ****ing useless.... Sunovabitch!
post #12 of 24 Old 01-05-2008, 03:26 PM Thread Starter
ChrisInVT's Avatar
Alright, so my co-workers husband (the metalworker) came over and had all the mounts out in 45 minutes, I was like WTF....
I don't know why I didn't think of it, but he welded 1" nuts right onto the heads of the stripped bolts. Took 'em right off with a 1/2 ratchet like they were nothing. I was like sunovabitch....
Pics to follow.
post #13 of 24 Old 01-05-2008, 03:43 PM
chaospartners's Avatar
User is: chaospartners is offline
Send a message via AIM to chaospartners
I dont think i have ever saw any rusted that bad Damn!!!!
03 Extreme, 4.3 5speed! core short throw shifter, custom y pipe, no cats, with flowmaster duals..
post #14 of 24 Old 01-05-2008, 04:20 PM Thread Starter
ChrisInVT's Avatar
I need to get new ones.
Ripoff, ummm I mean LMC wants like $30 a freaking mount. I have some decent mounts from my parts truck but everything else on this POS is new, so I'd like to just get new ones all the way around. Where's a good place to get 'em for CHEAP?
post #15 of 24 Old 02-23-2012, 01:19 PM
User is: mrockwell is offline
My rear mounts are perfect my middle ones are gone there rusted off the frame and rusted out on the body side. Im thinking im going to weld a 2x4 c channel to the frame and to body weld abut on the body side c channel put new bushings in and crank the bolt from the frame side c channel.
post #16 of 24 Old 02-23-2012, 02:17 PM Thread Starter
ChrisInVT's Avatar
Holy necrophilia.
post #17 of 24 Old 03-09-2012, 12:49 PM
run and tell that
slammed isuzu's Avatar
User is: slammed isuzu is offline
I am in the process of replacing the body mount bushings on my truck right now as well. It is a 94 reg cab S10, with 200,000 miles from the midwest. The left side were not horrible. The rubber bushings were pretty bad, but the bolts and bottom plates were fine.
The front ones (the radiator mounts) were also in good shape, and came loose just fine. Again, the rubber bushings were shot, but all of the metal (bolts and lower plates) were in good shape.
Got the to the right side, and the lower plates are pretty much gone!! Similar to the pics you originally posted. haven't tried the bolts yet, but I am assuming they will fight me pretty hard.
Where can a person buy the hardware at? I already have a bushing kit, but of course, they do not include the hardware (bolts and plates).
Thanks.
Baggin Pics
post #18 of 24 Old 03-09-2012, 01:31 PM Thread Starter
ChrisInVT's Avatar
I was putting in a body lift, so I had all new bolts to go along with my new mounts.
The rear cab supports/front bed mount I removed from a parts truck I had in my garage.
post #19 of 24 Old 03-09-2012, 01:52 PM
run and tell that
Yeah, I have no parts truck and am not lifting mine. Just replacing the factory hardware.
Shitty thing is, I actually did have a parts truck, but I sold it years ago. It was a bit of an eye sore, and I had not owned an S10 for some time, so I got rid of it. It was stripped down quite a bit, but the body mount hardware was still there though!!!
Baggin Pics
post #20 of 24 Old 05-30-2015, 08:37 AM
User is: jons56 is offline
Q-Buy UM Part# Description Price Ext Stock Status
EA 50-88-67 BOX FLOOR SUPPORT,UNIVERSAL 49.06 49.06 0 in stock. Drop Shipped from mfg. with $50.00 min. order, otherwise lead time about 7 days.
Total if Backordered 0.00 49.06 MDSE-TOTAL
Estimate for 1 box(es) 5 pounds, See below. 13.72 Shipping Estimate **
62.78 Expected order Total
This kit repairs your rusted out cab mounts quickly.* Factory rubber
mounts retain moisture and cause rust which can weaken the mount and
create an unsafe condition. A cab mount ties the frame and body together.
Our repair kit is easy to install and makes it safe again.We recommend
welding for extra safety.* This fits all S-10 Chevy pick-up trucks from
1982-2003.* These fit over the top of the mount..no need to cut away old
mount.* Our mounts are made from heavy duty 11 gauge steel and sold as a
set of 4.
https://www.autorust.com/product/chevy-s-10-cab-mounts/
$100.00
jons56 is offline
post #21 of 24 Old 05-30-2015, 09:36 AM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
Yeah, Just slap them over the rusty destroyed body mounts. Sounds like an ingenious fix.
TelAmeriCorp
post #22 of 24 Old 05-31-2015, 08:31 PM
Bold as Love
Harry Canyon's Avatar
User is: Harry Canyon is offline
**** man, 15 pop rivets per mount, 1 gallon of roofing tar, and it'll pass inspection.
1998 S10 4.3/Auto daily driver.
1984 S15 2.2 Diesel.
1988 S10 2.5 5-speed lowered 4/4.
post #23 of 24 Old 05-31-2015, 09:20 PM
2.2 Extremist
GMC Motorsports's Avatar
User is: GMC Motorsports is offline
Its not hard to fix body mounts correctly and I'm not a body guy at all. Still wouldn't try it but I can tell its easy.
Why try to rig something like a body mount is beyond me
2000 GMC Sonoma SLS
ECSB 2.2L Flex Fuel L43 bored 0.40, 0.20 head shave, 5-Speed, 4.10 gears, Space Blue Metallic, Graphite Int, OBX Header, straight pipe cat delete, Thrush Welded, urethane motor mounts, ZQ8 sway bars, Hurst Short Throw Shifter, ClutchMasters 9lbs flywheel
Other Rides: 09 Canyon 5.3 ZQ8, 05 Duramax, 85 Monte Carlo SS.
post #24 of 24 Old 06-02-2015, 03:52 PM Thread Starter
ChrisInVT's Avatar
holy necro post
