Door pin and bushing repair - S-10 Forum
post #1 of 101 Old 06-05-2006, 10:38 PM Thread Starter
User is: DevilDriver is offline
There's a new story entry added:
Well, since no one has done a how-to on this subject, I figured I would since we always see this question...The following pictures were taken while we we're working on Grappler's 95 2 door Blazer (www.vettel.org/andy). We completed both his doors and my front passenger side door. (www.pghconsulting.net/teal). All told we averaged 15-20 minutes per door for this repair. The bushings on all 3 doors were cracked and at the beggining of being egged.
post #2 of 101 Old 06-09-2006, 01:52 AM
Wanna Race? To the ground
nimbyfaygo's Avatar
User is: nimbyfaygo is offline
Send a message via AIM to nimbyfaygo Send a message via Yahoo to nimbyfaygo
Thats a really good how to. I know that I need to relpace my driver side bushings, now I know what it consists of!
96 s10 ex cab. Tuckin 20's
Minisinmotion
post #3 of 101 Old 06-09-2006, 11:51 PM
chronic's Avatar
User is: chronic is offline
Send a message via AIM to chronic
where did u get the door spring tool?
chronic is offline
post #4 of 101 Old 06-14-2006, 12:52 PM
24dupontchevrolet
Guest
Posts: n/a
User is:
Re: Door pin and bushing repair
did you find out where to get this tool??
post #5 of 101 Old 06-18-2006, 06:43 PM
User is: arolon is offline
I did a search and found where they sell the tool for $15.25 plus shipping. Check out http://www.mytoolstore.com/toolaid/colli04.html
Door Spring Tool - GM Vehicles 87675 $15.25
Use to remove and install the door hinge springs found on late model General Motors vehicles. Makes a hard job easy. Can be used with 1/2" open end or ratcheting box wrench. Always wear eye and face protection.
arolon is offline
post #6 of 101 Old 07-10-2006, 04:55 PM
User is: s10dog is offline
Hey thanks for taking the time to show how to.
Pretty cool of you.
I have repaired egged hinges by using J.B. weld. I simply jb welded the new bushing into the hinge. The jb takes up space between egged hinge and bushing. Glue together, insert pin to keep straight, Let it dry of course a couple days then put door back on. Of course welding and drilling is much better but takes much more time and not everyone has a welder. I have done this on a couple cars and it seemed to work great but sold them before I could see if it lasted or not.
s10dog is offline
post #7 of 101 Old 08-08-2006, 01:47 PM
DIY
mrche's Avatar
User is: mrche is offline
Send a message via AIM to mrche
I have a hard time getting the pin all of the way in, are you sure it's alright to just hammer it in? I don't want to f' up the bushing by hammering too hard...
and a warning to everone, make sure you really really be careful taking the door off, since the top of the fender really f'es up the paint. Happened to me, and the tape didn't really help. The tape actually left residue! Damn masking tape. So, becareful and don't be stupid like I was.
1994 Sonoma
Former NJ S-Series
mrche is offline
post #8 of 101 Old 08-11-2006, 08:17 AM
User is: aj-in-jax is offline
There's ALWAYS a "tool" you need.
Glad I found this forum. This is exactly what I need to fix on my S-10.
Though I hope the bushings will be enoguh and I won't have to replace the bracket.
post #9 of 101 Old 09-21-2006, 08:21 PM
NOS make light brighter!
danssoslow's Avatar
User is: danssoslow is offline
How about a part number for the pin and bushing. I bought one from NAPA, but the SOB is four foot longer than need be. If I were to install the damn thing, it would stick out above the fender!
post #10 of 101 Old 09-23-2006, 06:52 PM
LoW - TX Chapter
STXS10's Avatar
User is: STXS10 is offline
Send a message via AIM to STXS10
Just did a door swap today!!
Air hammers own in getting door pins out!
STXS10 is offline
post #11 of 101 Old 03-05-2007, 10:07 AM
User is: DMACC is offline
Send a message via Yahoo to DMACC
hey whats up? my name is derrick. i have a 96 chevy s-10. i am getting a noise out of my drivers door when i open and close it. i have lubed the door many times. does that mean the i need a new door pin or some kind of adjustment?
DMACC is offline
post #12 of 101 Old 03-12-2007, 07:37 PM
DIY
mrche's Avatar
look at the bushings in the hinges... if they're worn out, broken, missing, or cracked... that means that you need new pins and bushings.
1994 Sonoma
Former NJ S-Series
mrche is offline
post #13 of 101 Old 03-13-2007, 12:06 PM
User is: partsguru1 is offline
Hey guys...
Why not ever give your local Chevy/GM dealership parts dept. a shot? Most of the time you will find that the parts are easier to install and priced competitive. Even if the cost is more, you can get the advice you need to do the job right the first time. Just a thought.
Doug
post #14 of 101 Old 03-13-2007, 12:38 PM
Gaaoooooo
MINTSICK's Avatar
User is: MINTSICK is offline
I got my pins from Auto Parts Fast at RockAuto, however I bet you can find them at your local autoparts store with the "Help!" parts, that is the brand that came for me.
2004 Silverado Z71 ECSB - |Silver Birch Metallic|5.3|Custom Single Exhaust|Method Standards
1993 Mustang LX Hatchback - |Reef Blue|5.0 H.O.|5 Speed|MGW Short Shifter|70MM MAF|MAC Shorty Headers|Pypes O/R X|Spintech Pro Streets|3.55's|
1984 El Camino Conquista - |Black|5.0L|Comp XE262H|Holley 570|700r4 swap|2.41 open rear|
MINTSICK is offline
post #15 of 101 Old 03-25-2007, 10:00 PM
User is: ReiG3 is offline
With the door open lift up on the open end of the door, if it moves it needs bushings. When you close the door and it runs into and then up the striker it needs bushings. Look at the door hinge you will see the worn out bushing.
If you go to the dealer you will need two bushings(both different) one pin and one retainer per hinge.
Rain runs right down the pillar taking the grease off. Always lube your hinges and you will keep from having to do this repair. Also lube your Blazer tail gate hinge pins.
Bob
ReiG3 is offline
post #16 of 101 Old 03-30-2007, 12:53 PM
User is: jharding32 is offline
Does anyone know where the sensor is located that tells the truck that the driver door is closed. Mine is not working. The chime goes off when the key is simply in the ignition, even if the door is closed. When I turn the key to ACC to listen to the radio if I am just sitting in the truck, the chime continues to sound. VERY ANNOYING! Also, the lights do not come on when the door is opened. Actually I think the problem is with both doors. It does not matter which position the dome override is in. (OUT and the interior lights stay on continuously. IN and they never come on) Any assistance on this would be appreciated.
2001 LE
post #17 of 101 Old 03-30-2007, 02:38 PM
Droppedime08's Avatar
User is: Droppedime08 is offline
Send a message via AIM to Droppedime08
How much do these pins ushally run?
If i already have the pins and they are fine..Can i just buy the little caps?
96 Sten
Bagged & Painted.
Project thread> http://www.s10forum.com/forum/f30/my...thread-273000/
post #18 of 101 Old 04-01-2007, 12:55 AM
cokehead
Dr. Pepper's Avatar
User is: Dr. Pepper is offline
Send a message via AIM to Dr. Pepper
yea, so it feels like my door is about to fall off when im driving. rattles like a mofo. i look at the hinge, and it looks like its sperating from the body. heres what im talkin about:
looks like mine, but not my pic. i for sure need new bushings and pins. how big of an issue is this? should there be a bead of weld put on there? any help would be great.
★No Regrets★ MD
post #19 of 101 Old 04-01-2007, 05:13 AM
User is: bg's is offline
As far as I know the body section of hinges are spot welded on.
Top Down Solutions has a few tools avail that help knocking the
bushings and pins in and out..Here's one for example. TDS
is for mid gen Camaros and Firebirds, but some parts from
these and S-Trucks match up.
bushing tool
gmpartdirect.com has genuine gm pins and bushing fairly cheap if one would want to go that route.
bg's is offline
post #20 of 101 Old 04-01-2007, 08:05 AM
your opinion sucks
casey53's Avatar
User is: casey53 is offline
The hinge in the picture looks normal. The small gap at the top is just where the factory seam sealer has deteriorated(sp). You can check your pins by opening the door about a quarter of the way and lifting on the back end. Any play in the bushing will be evident. If it rattles while driving check the door latch itself or striker for wear. Worn weatherstrips may also be the problem.
If people could only say," I'm sorry, I'm not educated on this topic and cannot respond intelligently to it."
casey53 is offline
post #21 of 101 Old 04-01-2007, 09:36 AM
cokehead
Dr. Pepper's Avatar
o, its surely the bushings and pins. you can hear the door clunk up and down when i lift it. ill do that first, then if its still there, ill try one of you other suggestions. thanks guys.
★No Regrets★ MD
post #22 of 101 Old 04-01-2007, 11:46 PM
sportsdime's Avatar
User is: sportsdime is offline
i got my pin and bushing from auto zone for under 6$ two man job def, as for the spring in the door what i did was put it in a vice, and wired it with some i think 10g wire to keep it compressed just be careful i got a black and blue the size of a dam gatorade lid,
2002 s100 2" home made lift shackles 1" t bar crank 265/75's, cherry bomb, spray in bed liner, push bars, dual fog lights, cb radio,
soon---back to 30x10.5x15's. hood scoop. dual exhausts
some day---6" lift and 33's. 10k lb winch.
post #23 of 101 Old 04-15-2007, 11:25 AM
5speedz34's Avatar
User is: 5speedz34 is offline
Send a message via AIM to 5speedz34
The door switch/ dome light switch is in the side of the dash and pushes in.
That door spring tool is also available from NAPA.
2001 Sonoma SLS Crew Cab
post #24 of 101 Old 04-24-2007, 03:43 PM
Dropped 2" F and 2.375" R
carcentric's Avatar
User is: carcentric is offline
Has anyone tried to replace one pin at a time (rather than doing top and bottom together by taking the door off)?
There'd be less room to work, but the weight of the door would be supported by the unworked-on hinge (the helper would just have to keep it from tipping) . . . .
BTW, I just called my local GMC dealer - they want $250 (estimated) to replace a pair of pins and bushings on ONE door!
M D "Doc" Nugent - www.carcentric.com/gmc.htm
post #25 of 101 Old 05-27-2007, 03:35 PM
just another dime!!!!!
unclejames1's Avatar
User is: unclejames1 is offline
ok, my problem is when I changed my pins and bushings it made my door drop about 1 to 2 inches when I open it. And that is twice as much as it was before I changed the pins and bushings.
the truck is an 88' and it is bagged and body dropped. if it is because of the body drop what can I do about it.
Or if I bought a suicide door hinge kit would I be able to correct it that?
any help would be greatly appriciated!!!!!!!!!!!!!!!!!!!!!!
post #26 of 101 Old 05-30-2007, 10:46 AM
CandiMan's Avatar
User is: CandiMan is offline
Send a message via AIM to CandiMan
Someone mentioned egg shape hinges. Mine is beyond egg shape. If GM would have used bolt-in hinges instead of spot-weld hinges it would have been gravy. It appears my truck was hit in the drivers door which damage the hinge, the door wa repaired and the hinge was so called repaired.
I'm torn between replacing the hinge or welding and redrilling for new pins.
For those who might say hinge removal is possible, I already removed a door hinge from the salvage yard.
The first hinge I tried to removed I completely detroyed the hinge, the second hinge is what you're looking at. If I had to do it again I would drill of the 4 spot welds to make removal a lot easier.
I realize this is a little drastic but once a take pics of my current hinge you'll see what I'm dealing with.
CandiMan is offline
post #27 of 101 Old 08-27-2007, 08:03 AM
User is: freecicero is offline
Can I ask two questions about this repair:
(1) I've been reading as many places I can find about this repair and I'm concerned that hammering on the existing bushings to get them out will damage the hinge. Is there any trick to this I should know?
(2) Does anyone know the answer to the earlier question about replacing one hinge at a time? Looks to me like my lower hinge is OK and only the top one needs a new bushing. Anyone have any insight on the feasibility of replacing only the top one?
thanks
post #28 of 101 Old 03-01-2008, 09:24 PM
User is: rick shower is offline
for jharding 32 did you fix your door over ride i have same issue on 2001 s-10 did find the parts under the dash.behind the dash.
post #29 of 101 Old 03-01-2008, 09:32 PM
91s10green's Avatar
User is: 91s10green is offline
damn wished i knew about that before we replaced the pins in my door man that was a bitch to do, and its still not aligned right.
post #30 of 101 Old 03-01-2008, 10:33 PM
CandiMan's Avatar
My Cardomain pics must have gotten mixed up. Those pics are totally unrelated to the subject at hand.
My first Dime was sold http://www.cardomain.com/ride/748801
CandiMan is offline
post #31 of 101 Old 03-02-2008, 08:34 AM
for 5 speed z 34 read your note.where is part in dash for contol the chimes.
post #32 of 101 Old 03-03-2008, 12:15 PM
LoW - TX Chapter
STXS10's Avatar
lol I was like uhh ok
STXS10 is offline
post #33 of 101 Old 03-03-2008, 06:43 PM
User is: b-rad739 is offline
The holes in the top hinge of my '96 Jimmy are now worn oblong--I guess I've read it being called "egged?"
Anyway, a year and a half ago, I had the pins and bushings replaced, but the top one blew out again. A local body shop suggested drilling out the holes a bit and replacing the pins with a set of over-sized pins and bushings.
Anyone have any advice on this? If not, I plan on just replacing, using the standard hinge and filling in the open ends of the oblong hole with JB weld.
Any advice would be much appreicated..thanks!!
B-rad
b-rad739 is offline
post #34 of 101 Old 03-12-2008, 11:12 PM
User is: Jadran is offline
Looking at my 2001 S10 door it seems that bottom pin have to be knocked out from the bottom of the door contrary to the top pin that head is actually upside down.
Jadran is offline
post #35 of 101 Old 05-20-2008, 09:28 PM
Truck #121616
Golana's Avatar
User is: Golana is offline
Send a message via MSN to Golana
pictures dont work in the thread anymore... i need the pictures hahaa!
Project CumminS10 : 1992 S10 Ext Cab 2WD
Golana is offline
post #36 of 101 Old 05-20-2008, 10:16 PM
User is: Matt2000 is offline
You can get the door tool (spring compressor) at Steve's Wholesale Tools and/or Harbor Fright for about $5-$6.
Matt2000 is offline
post #37 of 101 Old 06-01-2008, 10:28 PM
i saw what you did there!
fast68chevy's Avatar
ok gmpartsdirect is totally worthless for finding anything for anything newer than 72 i am tired of trying ot use that crap heap sorry excuse for a site
how about a part number/brand for the hinge pin and bushing kit for the first gen s-series trucks ??
anyone ?
need to know what will fit these trucks for sure instead of just going and picking a random kit and wasting $
thanks!
post #38 of 101 Old 09-30-2008, 12:05 AM
umm yea
JoPre's Avatar
User is: JoPre is offline
Send a message via AIM to JoPre
well i know this is old but someone may want to know go to autozone or advance auto , look in the help!(brandname) section at the doorpins on the back of one off the gm ones it specifically says s10 and s10 blazer, thats obviously the one you want. i think the number is something like 30043 but dont quote me on that.
. ________
/___/__\\___
[_________]
'94 S-10 Blazer 4.3 4L60E 5/3 drop lightly modded
JoPre is offline
post #39 of 101 Old 12-06-2008, 01:57 AM
StenZR2-LetsGetIt's Avatar
User is: StenZR2-LetsGetIt is offline
Im not sure exactly what its called, but try sguirting a bunch of lube inside that little bearing/wheel looking thing that rides between the door and hinge, thats what I did to mine and its like butter now.
post #40 of 101 Old 12-06-2008, 11:21 AM
TA^Guy's Avatar
User is: TA^Guy is offline
I bought mine at HarborFreight for about $6.00.
http://www.clubecm.com My Daily Driven Project Thread
ForSale- Deville and Fleetwood tail lights. - PM 4 Details.
TA^Guy is offline
post #41 of 101 Old 12-06-2008, 01:21 PM
Need LSx swap.....
Kampz69's Avatar
User is: Kampz69 is offline
Send a message via AIM to Kampz69
so did i, good deal
Nick
Currently Blazerless...but looking
Graphite Double Din bezel for sale, PM me!
OEM new Maroon plastic air dam for sale, PM me!
Originally Posted by AVdime View Post
it was just an old factory with a bunch of whores
Kampz69 is offline
post #42 of 101 Old 12-06-2008, 07:33 PM
Hmm.. well now..
Gearstix's Avatar
User is: Gearstix is offline
Send a message via AIM to Gearstix Send a message via MSN to Gearstix Send a message via Yahoo to Gearstix
My father and I replaced the pins and bushings in the drivers door. The hole was egged pretty badly, but we used Caterpillar epoxy and a thicker wall bushing.
Works good, no more sag.
1996 Chevrolet S10 LS 2.2/Auto... Soon to have a 305/700R4
'94 Sonoma. < Project Thread... Now with tree damage... Now a parts truck.
'05 Blazer 2DR 4x4 < The 'new' daily
(j-body.org)
Originally Posted by OHV notec
Might as well point out that you could spend $10k modifying a Briggs & Stratton-powered lawn mower, or a dining room table.
Gearstix is offline
post #43 of 101 Old 02-11-2009, 06:55 PM
User is: vines1984 is offline
can anybody tell me if a 93 s10 blazer 4 door passenger door will fit 94 s10 pu??? thanx
post #44 of 101 Old 02-11-2009, 10:30 PM
Rarely goes over 20mph
beaniebmx's Avatar
User is: beaniebmx is offline
if the blazer door is the front door, then yes.
the blazer and s10s are the same for most body parts, i put a 94 blazer hood/grille/bumper/core support on my 1991 s10 i had and it worked with no problems.
im replacing my 03 s10's driver door with a 98+ blazer door.
03 S10 Ext Cab-BD 3.5" bagged- 18/20s its ORANGE
1991 s10 reg cab 5spd- SOLD- biggest mistake
1985 2wd 2dr jimmy-totaled- samwhiched in a 5 car pileup
post #45 of 101 Old 02-12-2009, 05:42 PM
thanx alot for your knowledge
post #46 of 101 Old 02-12-2009, 06:04 PM
Need LSx swap.....
Kampz69's Avatar
no, the 93 blazer is totally different. 2nd gen S10s started in 94, and 2nd gen blazers in 95.
Nick
Kampz69 is offline
post #47 of 101 Old 07-14-2009, 03:54 AM
User is: ajowel is offline
thanks for all the tips. will help me a lot. I had the impression there were some pictures of the door removal, but could not find them. they are still somewhere available?. Did you remove the fender before removing the door?
Jan
ajowel is offline
post #48 of 101 Old 07-14-2009, 01:03 PM
Need LSx swap.....
Kampz69's Avatar
i think the pics might be gone, they were pretty old. i dont remember seeing anything about removing the fenders however, just tape/cover them up so you dont scratch them.
Nick
Kampz69 is offline
post #49 of 101 Old 08-07-2009, 06:31 PM
User is: Ron Glowczewski is offline
Dorman sells the door hinge pin, 2 bushings (one slightly larger than the other) and the retainer ring in a kit through their "Help!" Motormite brand stocking number 38419. This number is good at any parts store. You would need 2 of these to fix one door. This kit covers S-10s, Blazers, Jimmys, Sonomas, and Bravadas 1994-2005.
They work perfectly, I've fixed my 2000 S-10 driver's door and my mom's 2000 Blazer driver's door with them. The Blazer pin holes were slightly "egged" too. These kits took care of it, no JB Weld, no problems. I replaced these pins and bushings by myself, I used a car jack with a folded wool Army blanket draped over it to hold up the edge of the door while I pounded out the pins. The hardest part was re-installing that stupid heavy duty spring. To get it out, I just smacked it out of the way with a hammer and brass punch. I highly recommend that Harbor Freight door spring tool, though. It is kind of a piece of crap and hard to operate, but for $3.00 it makes life a lot easier.
post #50 of 101 Old 09-10-2009, 07:50 PM
User is: hunter05 is offline
Go to harborfreight.com and you will find it for 3.99.
hunter05 is offline
