do i need to?
Go Back   S-10 Forum > General Tech > Exterior / Paint
Old 07-02-2008, 10:27 PM   #1
Sipolt89 is on a distinguished road
do i need to?
so i was removing the jack bracket out the back of my 97 dime because im puting a sub in there. so what happened is one side the rivets poped off then the other side i couldnt get so i got a chisle in there and thats where i ****ed up because now there is a hole in the back of my truck,so my question is am i going to need to take off the bed so i can patch that up,i bent it in already and put some jb on from the inside to plug it but am i gonna have to get it from the other side.and if so what will i have to do?and exactly how do i take the bed off?i know its a stupid question but ive never done it before and i dont want any more problems.just lmk if anyone can help.thanks
Old 07-02-2008, 11:39 PM   #2
Panda s10 driving mofo.
97dimedrop's Avatar
97dimedrop is on a distinguished road
Re: do i need to?
there are bolts in the bed, you should weld it, and you can weld it from the inside, but be careful.
Old 07-03-2008, 02:50 AM   #3
2002dime's Avatar
2002dime is on a distinguished road
Re: do i need to?
should of drilled the spot welds out...
Old 07-03-2008, 04:38 AM   #4
pr0tus
Re: do i need to?
I know someone is going to hate me for saying this, but I will anyway. You can get to that spot from under the truck when you jack it up, I know because I did the same thing about 6 years ago the day I bought my s10! Sure welding that up is the right thing to do, but that would be a real PITA. I slapped a couple pieces of quality duct tape over that hole and it hasn't rusted yet. Just spray or brush some paint over the bare metal first and don't worry about it, you would be suprised how much rust protection a piece of tape can provide. Also, you simply can't see this area from anywhere but under your truck. Alright, now someone will call me an idiot...
Old 07-03-2008, 05:06 AM   #5
got beer?
paint toad's Avatar
paint toad will become famous soon enoughpaint toad will become famous soon enough
Re: do i need to?
hmmmm....thank god for drinks.......
Old 07-03-2008, 01:07 PM   #6
B&B Customs
fastSdime's Avatar
Location: Rolling in the Midwest in the Driftwood Metallic S10
fastSdime is an unknown quantity at this point
Re: do i need to?
Do it the right way like you were going too. Dont listen to the whole using tape BS. Dont hack your truck. Live and learn from your mistake and move forward not backwards.
Old 07-03-2008, 04:37 PM   #7
pr0tus
Re: do i need to?
If you don't believe me, take a piece of bare metal and put a piece of tape on it, then let it outside for a couple months in the rain. When you pull that tape off let me know what you find under it. Unlike a lot of people on here I'm actually speaking from experience, and I'm giving you the best answer in YOUR situation. And what do I mean by that??? Well the OP is asking how to fix this and so far hes worried about taking the bed off, which is the least of his worries if hes going to try welding this himself. If he does actually get his bed off, and find a way to weld this hole shut, then hes going to have to PROPERLY prep that weld, properly seal that fresh weld, and paint it yet with real paint. The cost of materials and time is going far beyond what he wanted to get into to put a damn sub box in, and if that hole isnt welded and finished perfectly its going to rust out WAY FASTER than a small hole in the back of his cab with some tape over it. If anyone feels like calling BS on this again I will take pics of my cab from 6 years ago that still has no rust on it.
Old 07-03-2008, 05:21 PM   #8
pr0tus
Re: do i need to?
I'll tell you the "right way" to do it also just so you can choose for yourself. Start by taking the bolts out of the bed floor, 4 or 6 bolts I forget. Remove the tail lights/ license plate lights and the wiring harness. Also remove the gas fill tube. Set that off somewhere and begin to grind your sheetmetal area that needs welding, flaten it with hammer/dolly if you need to. Once thats ready to go get yourself a small mig welder, with gas. Have someone hold a piece of copper bar inside the cab behind the hole so you can fill it in with weld. The weld wont stick to the copper. After your hole is tacked shut use a small grinder to smooth out your weld and check for any holes, finish welding as needed. Alright, after your weld is ground nice and smooth you can move onto paint. You cant see this spot so just sand what you need to with some 80 grit and mask off everything you don't want painted. Use either Epoxy primer, or Etching primer on the bare metal. You can talk to your local paint supplier for info on how to use either of these. After you prime you can finish up with some paint of your choice, also from the paint supplier and not a spray can. Make sure you paint the inside also, just to be safe.
Old 07-03-2008, 06:01 PM   #9
This is doo doo baby!
wildman ss's Avatar
wildman ss is on a distinguished road
Re: do i need to?
you're an idiot
Old 07-03-2008, 07:19 PM   #10
got beer?
paint toad's Avatar
Re: do i need to?
jesus christ.....one second he wants to say how to patch with duct tape...next second he says don't use rattle can..............
make up your mind hack boy!!!!!!
i should buy more drinks so i can learn bodywork...................fuuck
Old 07-03-2008, 07:48 PM   #11
now XTREME
94redSS's Avatar
94redSS is on a distinguished road
Re: do i need to?
BWAHHHHAHAHAHHA........ btw toad i got a new job start monday....
Old 07-03-2008, 10:52 PM   #12
got beer?
paint toad's Avatar
Re: do i need to?
you painting?
Old 07-03-2008, 11:42 PM   #13
pr0tus
Re: do i need to?
you guys are cute, but wrong. The problem with "doing things right" is just that most people dont have a ****ing clue what they are doing and make shit 100 times worse. In this case I told him to slap some tape on it, because his other best option is to pay out the ass and have a professional, like me, do it for him. Sorry, but unless you have or know someone with all the tools you will need to do this right, its not worth doing yourself.
Old 07-03-2008, 11:54 PM   #14
pr0tus
Re: do i need to?
Quote: Originally Posted by wildman ss
you're an idiot
Nice contribution! But hey, join the party! I haven't seen anyone else give this guy useful information either.
Old 07-04-2008, 12:08 AM   #15
wildman ss's Avatar
Re: do i need to?
you're an idiot
sounds like to me you were asking for it
Old 07-04-2008, 10:25 AM   #16
dimedragin22s's Avatar
dimedragin22s is on a distinguished road
Re: do i need to?
i just took a $hit
Old 07-04-2008, 06:31 PM   #17
now XTREME
94redSS's Avatar
Re: do i need to?
you painting?
im gonna be doing it all for a week until i prove my self....so HOPEFULLY i got the painting job
Old 07-04-2008, 09:51 PM   #18
got beer?
paint toad's Avatar
Re: do i need to?
my last job,i gave one sample paint job and i was in
it takes time.....then you'll want out!
Page generated in 0.13948 seconds with 11 queries
