cali combo
Go Back   S-10 Forum > General Tech > Exterior / Paint
Old 08-09-2009, 12:32 AM   #1
cali combo
ok so i was at the carlisle truck show today checking out trucks for ideas for new projects.. on the way home some guy rear-ends me at a stoplight so now im gonna do a cali combo.. does anyone have pictures in step by step on how to do it? im sure i can do it, im a ok welder just not sure what all i need and have to do
Old 08-09-2009, 09:40 AM   #2
CNC Plasma Cutting
GoingCustom's Avatar
Re: cali combo
Don't quite a have step by step pics, but maybe these will help? It's quite easy honestly. Remove tailgate/bumper, weld in tail light fillers or if you are keeping your stock tail lights, then remove them so they aren't damaged. Line up the tailgate skin so the body line matches, tack into place. tack tack tack tack tack tack, etc... until it's welded in. Add license plate box or different tail lights as needed. Also, make sure you put in some sort of bracing behind the skin so it doesn't crack at the seams.
Old 08-09-2009, 10:55 PM   #3
Re: cali combo
alright thanx man im sure i can handle it.. it dont seem too bad
Old 08-09-2009, 11:01 PM   #4
On the grind
Re: cali combo
can you just cut off the tailgate skin that is already on it and basically weld the cali combo to the back of the stock tailgate? you would maintain factory support then right? does that make sense?
Old 08-09-2009, 11:05 PM   #5
DeXtreme on 20/22's
Xtreme24's Avatar
Re: cali combo
the factory tailgate does not give any rigid structure to the bed. for example, take a jack and just up one side of the truck from the very back and look at the gaps between the bed and tailgate. you have to cross brace the bed sides to keep them from flexing and ruining the finished bodywork/paint.
Old 08-10-2009, 07:29 AM   #6
Re: cali combo
o ok i understand that it makes sense so how many braces? like one across the back right behind the gate and one across the front
Old 08-10-2009, 08:14 AM   #7
TTP
timtp2004's Avatar
Re: cali combo
Yes, and then most ppl do an X in between those rails then.
Old 08-10-2009, 12:02 PM   #8
Re: cali combo
ok awesome thanks for the info. ill post pix when i get it done hopefully in a week or 2
Old 11-02-2009, 04:33 PM   #9
Re: cali combo
dose the skin come touch both sides of the bed
Old 11-05-2009, 11:46 AM   #10
Got me a Stepside!
dbailey92's Avatar
Re: cali combo
Sorry if it seems dumb but I'm confused at welding in the bracing? Does the combo sit on it or come in contact with it? I can get the skin lined and all welded up but wasn't sure about the bracing behind it.
Old 11-06-2009, 04:03 AM   #11
CNC Plasma Cutting
Re: cali combo
I did on mine. Once I got the skin tacked on, I tacked in some 3/4" bracing against it that went from bed side to bed side. I've never had any problems/cracks. After the skin was fully welded, I went back and did some more tacks on the bracing to secure it.
Old 11-06-2009, 04:21 AM   #12
CNC Plasma Cutting
Re: cali combo
Edit: here's a pic...
Old 11-06-2009, 01:03 PM   #13
No more blazer
83blazerlaynframe's Avatar
Re: cali combo
Lol im gonna whore out dougs truck again...
Go to:
Oaktowntrucks.com>media>pics> then doug1's build near the bottom. Its like halfway through the pages and i dont know offhand what page.
We welded the braces in FIRST, AFTER we tested the straightness of the bedsides using a square AND the cali-combo. Once we knew it was striaght we welded it so it would stay rigid.
Then sat the combo on a piece at the very top that the skin "hung" on. Then did tack tack tack tack till it was fully welded in.
Hope that helps!!! (goin on 3 years and still holding up great!)
