body work and paint questions - S-10 Forum
post #1 of 6 Old 04-24-2012, 08:37 AM Thread Starter
Dems 22s
mattadams13's Avatar
User is: mattadams13 is offline
My truck is in pretty good shape, it just has a few door dings and pecks. I want to body work and paint this myself. I have a couple of friends that work in the best body work in town that are going to look over me as i do the mud work and help me, and give me pointers on it.
After i do the mud work, can i spray polyester filler primer to help get my truck perfectly straight? I know my friends are going to help me, but they are not going to babysit me and make sure everything is perfectly straight. I feel like this primer will make it a lot easier to get it perfectly straight.
If this is not a good method, what primer do i need to get?
If this method is ok, after i block it out do i just spray my bc and cc over it? or do i need to put a sealer or regular primer over the polyester primer.
My dad is going to spray it for me in our shop. We are going to wet the floors and make a plastic paint booth. Im going to pay my friends that work at the body shop to wet sand and buff the truck.
Also I plan on keeping my truck the factory metallic blue. What is a good, but affordable bc and cc to spray with?
Thank you and sorry for the novel.
Matt Adams
Project thread: Laying on billet 22s http://www.s10forum.com/forum/f30/si...thread-486853/
post #2 of 6 Old 04-24-2012, 09:15 AM
death trap's Avatar
User is: death trap is offline
Re: body work and paint questions
Polly primer is good and it will need to be sealed or primed over with high build.
post #3 of 6 Old 04-24-2012, 01:46 PM Thread Starter
Dems 22s
Thank you, I was thinking that, but wasnt sure so i thought i would ask the experts.
Matt Adams
post #4 of 6 Old 04-24-2012, 03:07 PM
Longbeds FTMFW
gunther19820's Avatar
User is: gunther19820 is offline
some 2k primers can be reduced a bit and used as a sealer as well
http://www.s10forum.com/forum/f143/p...nto-it-490214/<---- my body drop thread
Originally Posted by aaronweisler View Post
I can one up the hummer
Originally Posted by s10xtremist View Post
By blowing bubbles before you swallow?
post #5 of 6 Old 04-25-2012, 10:41 AM
Uni-Joint Snapper
2k2indigoxtreme's Avatar
User is: 2k2indigoxtreme is offline
Send a message via AIM to 2k2indigoxtreme
The Poly primer we use (evercoat super build 4:1) is a bitch to sand. If you're just doing spot repairs, then just use a direct to metal high build 2k on those spots and feather them back to your stock finish. Montana makes a good product for that. I would recommend at least spot sealing over the primer spots, or sealing the entire truck before spraying base. Nason makes a good product called Select Seal 2k.
B&H Collision
'92 Caprice, layin' frame. Tubbed for 22s, 4 link in rear, stock bench seats front and rear. Seatin' 6, A/C blowin' and tuckin lugs!
post #6 of 6 Old 04-26-2012, 12:02 AM
death trap's Avatar
Slicksand sands very nice and isn't too expencive but does need to be topcoated with high build. Sikkens polysurfacer is great but is a bit pricey.
