wiring power seats in a non power seat truck - S-10 Forum
post #1 of 14 Old 07-01-2009, 04:04 AM Thread Starter
Banned
User is: 4x4zr2GA is offline
Send a message via AIM to 4x4zr2GA
picked up a drivers side power seat off a member on zr2usa.... i want to hook the seat up right and not all janky. does anyone who has done this using a relay and fuse setup have a diagram handy of what they did? and what amp relay and fuse do i need for these seats? they are '00 model blaZeR2 seats.
4x4zr2GA is offline
post #2 of 14 Old 07-01-2009, 04:05 AM
sonomanator's Avatar
User is: sonomanator is offline
Re: wiring power seats in a non power seat truck
there is a really detailed how to on this.
edited this 12/2013 but i wont be back for years.
post #3 of 14 Old 07-01-2009, 04:16 AM Thread Starter
Banned
ah, i no good at searching! i am searching right now.
is there by chance anyway i can go to a pick'n'pull yard and get the rest of the power seat harness and it will be plug and play to my truck?
4x4zr2GA is offline
post #4 of 14 Old 07-01-2009, 11:00 AM
Electrical Mod
deathphoenix99's Avatar
There really isn't anything to wire up other than a power wire and a ground. It should be fairly easy to tap into the stock location of the main wiring and run your own wire. You could get the stock wiring, but that may be more work, you just need the circuit breaker fuse.
By chau8238 at 2009-07-01
post #5 of 14 Old 07-01-2009, 02:50 PM Thread Starter
Banned
so basically your sayin just get a 25amp circuit braker and just run and IGN+ wire through the circuit bracker then to the power wire of the power seats, and then just ground the ground wire? i just hear alot of people who do this swap keep blowing fuses and stuff... i dont want it done all shitty where i gotta keep popping fuses. i want to be able to hit the switches for an hour if i felt stupid enough to do so withought anything going wrong.
4x4zr2GA is offline
post #6 of 14 Old 07-01-2009, 03:59 PM
Electrical Mod
You shouldn't have any problems given you use a breaker, not a fuse, and use a correct size wiring, probably around 12 or 14 gauge. The breaker is the same as the ones used for your power windows and locks. I don't know why other people had problems, its straight forward and unless they used a fuse, shouldn't blow it.
post #7 of 14 Old 07-01-2009, 07:48 PM
User is: Sammytheorangutan is offline
Slight hijack. Sorry.
What about adding power seats with memory to a non power seat truck? Any way to make use of the memory function?
post #8 of 14 Old 07-01-2009, 08:16 PM Thread Starter
Banned
now thats something i do know... the body control module stores the settings, you would have reprogram it if thats possible, or take the BCM out of a truck that had that option, but then you'd have to have your vin number match the engine computer. so ive been told
4x4zr2GA is offline
post #9 of 14 Old 07-05-2009, 04:50 PM Thread Starter
Banned
so how the hell do you get the wiring from the harness that goes to the pwer seats? i finally got a power track from a junkyard out of a blazer, but when i cut the carpet up to see where the wires went, they tied into a nother harness and went backwards to the back of the truck? not to the front and then the fuse box like people say? i really dont want a janky ass circuit breaker or any janky wiring in my truck.
4x4zr2GA is offline
post #10 of 14 Old 07-05-2009, 05:02 PM
forum idiot
orangesonoma's Avatar
your truck is like nine colors...thats not the look your going for??
Brian
orangesonoma is offline
post #11 of 14 Old 07-05-2009, 06:08 PM Thread Starter
Banned
lol. it wont be 9 different colors for long. i hope anyway. hey how come the damn wiring harness uses Ford plug ends on the motors? kinda weird.
anyway, just temporarily, if i get a 25amp circuit breaker and wire it inline with the power, and just ground the ground wire to the seat track, where is the best place inside the cab to hook the power wire to for the seats?
4x4zr2GA is offline
post #12 of 14 Old 07-06-2009, 02:48 AM Thread Starter
Banned
purdy please!
would i ahve to take the entire interior driverside harness out of the blazer and cut it up a little to swap it into my truck, so that its "plug and play"? cuase like i said, the wiring that goes to the seat runs towards the back of the blazer not to the front.
4x4zr2GA is offline
post #13 of 14 Old 07-11-2009, 05:52 PM Thread Starter
Banned
so im wiring them up right now. went back to the pick n pull and cut the male end plug from a blazer body harness, and pulled the extra 2 pins/wire out that i didnt need. did this so it would plug up the factory way so i can just plug/unplug it when needed to be removed. already grounded the big black wire, and wired a 25amp circuit breaker inline with the big orange power wire... now where is the best place to tap into a power source for that orange wire?
4x4zr2GA is offline
post #14 of 14 Old 03-06-2013, 11:28 AM
User is: tim73 is offline
Just a heads up guys, normally, for 25 amp circuit, you need #10 wire. #12 is only rate for 20amps.
tim73 is offline
