wiring pin out Question?
Old 07-03-2008, 12:17 AM   #1
NESS NOOB!!
raven2510's Avatar
raven2510 is on a distinguished road
so ive got this file for wiring an overhead console and im confused about one wire...
Electronic Control Unit Output - 12 Volt - Inadvertant Load Control
the one in red...what does it do/mean?
heres the file http://www.mediafire.com/?yu34jmbtt0j
thanks in advance for anybodies help
edit:
what does RAP Fuse Supply Voltage mean??
is that the ignition wire?
Old 07-03-2008, 09:59 AM   #2
capspauld's Avatar
capspauld is on a distinguished road
Re: wiring pin out Question?
I cant see your document because I am at work but I think I have the same one. The Electronic Control Unit Output - 12 Volt - Inadvertant Load Control is the one on the harness for the lights and homelink right? If you have a lighted mirror, you can put that one to the orange one on the mirror.
I believe the RAP is retain accessory power, like how the radio stays on after you turn off the truck until you open a door. Do you need a diagram for your radio? Or is the one on that document the same as yours, it wasnt the same as mine so that is why I am wondering.
Old 07-03-2008, 11:21 AM   #3
00' S10 Owner
Sandite5's Avatar
Sandite5 is on a distinguished road
Not sure, but a question I got is, where did you get that diagram from? I've been looking for a place to get all the diagrams for the wiring harnesses. Would have helped a lot when I had to track down which cord went to which fuse box.
Old 07-03-2008, 01:04 PM   #4
NESS NOOB!!
raven2510's Avatar
different sites
what wire is the RAP wire in the dash?? i would really like to avoid removing my radio if all positive...is there another wire i can get it from??
and the other wire? so what does it do? i dont understand??
Old 07-03-2008, 01:13 PM   #5
capspauld's Avatar
I will have to look to see if I can find another RAP source when I get home. Maybe on one of the BCM plugs or something. I think it either turns the lights on when you open the door with the other lights or it turns them on when you press it in. I think it is for when you open your door though.
Old 07-03-2008, 01:52 PM   #6
NESS NOOB!!
raven2510's Avatar
no the RAP is the thing that causes the radio to stay on after you take the keys out and before you open the door. i just need to know what wire i can get to besiedes the radio to do it.
and what this means...
Old 07-03-2008, 03:17 PM   #7
capspauld's Avatar
I know I was talking about the Electronic Control Unit Output - 12 Volt - Inadvertant Load Control wire is the one that does that to the lights. It was me who told you what the rap was earlier.
So I looked through techline and the only other thing I could find that has RAP was on the BCM and it was RAP coil or something so I dont think it is the same thing. Only things I can think of that retain power is the radio and the power windows, at least on my truck. I couldnt find any wire for the power windows that was RAP so unless someone else knows of another location, you may have to go and tap into the radio wire.
Old 07-03-2008, 04:24 PM   #8
NESS NOOB!!
raven2510's Avatar
ok well ill keep checking around and i might have to use the radio. thanks
Old 07-03-2008, 05:43 PM   #9
capspauld's Avatar
np. I seen some on there that showed a wire coming off the relay block that did it and one that is from the fuse block that goes to the radio so if you wanted to do it that way from the engine bay, I will see if I can send you the diagrams.
Old 07-03-2008, 08:37 PM   #10
NESS NOOB!!
raven2510's Avatar
ok sound good to me
email is
Raven2510@gmail.com
Old 07-04-2008, 10:21 PM   #11
capspauld's Avatar
Hey I sent the stuff to you, dont know if it will help though. I started my overhead console install today and pretty much finished but it got too dark. I will let you know if it works tomorrow.
Old 07-05-2008, 12:07 AM   #12
NESS NOOB!!
raven2510's Avatar
yea i got mine mounted but i didnt wire it today...fireworks got me sidetracked.
im gonna wire it tommorow and get back to ya.
and those diagrams are great...that helped alot
Old 07-05-2008, 03:49 PM   #13
capspauld's Avatar
Im glad they helped you out. I finished wiring mine today and everything seems to be working perfect surprisingly. I am going to calibrate the compass and I reset all the stuff so I will take it for a spin in a bit. I put some lighted mirrored visors in as well and they are pretty cool. I will post up pics later. Post some of yours when its done too.
Old 07-05-2008, 06:33 PM   #14
NESS NOOB!!
raven2510's Avatar
well sounds good on your end but not mine....nothing works
i drove around in circles for 15min. and the compass wont calibrate.
the trip/econ. displays nothing...but hey the dome lights work....but thats about all that works
Old 07-05-2008, 09:43 PM   #15
capspauld's Avatar
Oh that sux, do you get the c or cal when you hold them down for awhile?? What wire did you connect your class 2 serial data wire to?
Old 07-05-2008, 09:56 PM   #16
NESS NOOB!!
raven2510's Avatar
i get "C"
and the yellow wire from the console to the purple wire on the OBD II port.
but when i test it i get a code E4....all i know is it means "communication error".
so im buying another console and gonna try that unless somebody else has an idea?
Page generated in 0.14301 seconds with 11 queries
