Where is the wire harness for electric trailer breaks??
Old 05-29-2008, 10:07 PM   #1
sonoma247's Avatar
sonoma247 is on a distinguished road
ok so i wired up my 7-pin in the back and i went to install the break box up front and i cant find the wire harness that hooks up to the break box(it has 4 wires in it) to save my life....... any help??
Old 05-30-2008, 12:02 AM   #2
goin broke but n style
S15vortecpwr's Avatar
S15vortecpwr is on a distinguished road
Re: Where is the wire harness for electric trailer breaks??
i do not believe s10 have that harness pre-wired. It is not hard to make one yourself and install it.
Old 06-02-2008, 10:18 AM   #3
I am sofa king we todd ed
nd4spd18's Avatar
nd4spd18 is on a distinguished road
There are two optional trailer wiring harnesses one has an aux power wire the other does not.
Old 06-02-2008, 11:29 AM   #4
Distracted Longbed Driver
old_skool_noma's Avatar
old_skool_noma will become famous soon enough
it shouldn't have one from the factory, to run the brake controler, you need to tie into the third brake light, otherwise if you tie into a tail light it will run the brakes when the blinker is on
as for the brakes on the trailer im not sure what pins they are
Old 08-20-2008, 06:07 PM   #5
Oo-v-oO's Avatar
Oo-v-oO is on a distinguished road
I have a '96 2wd pickup with the 4.3 and a 5-speed. Mine has a couple of feet of unterminated wires tucked up by the spare tire that are tied into the main harness coming back from the front of the truck. There are smaller-gauge wires for the park, directionals, 3rd brake light, etc. as well as three heavy-gauge (looks like about 10) wires, one of which is supposed to be an auxiliary 12V supply, one is a wire for the electric trailer brakes, and one is a ground, IIRC.
I would like to get the aux. power and electric brake wires connected to my 7-pin plug for my camper. I know where to connect them on my plug, but I do not know where these wires come out at the front of the truck so I can tie them into a fused lead to the battery and my trailer brake controller.
Does anyone know where they are terminated on the other end of the vehicle? They are both dead, and I tried putting fuses into the open slots in the fusebox but no luck.
Thanks...
Old 08-22-2008, 10:13 PM   #6
Oo-v-oO's Avatar
Anyone made these connections? Am I the only one who is going to be using electric trailer brakes?
Old 08-24-2008, 12:01 AM   #7
registered s10 sex offender
orangesonoma's Avatar
orangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud of
i never found them but my blazer has them
Old 10-20-2008, 04:12 PM   #8
Oo-v-oO's Avatar
I can answer this question!
While I was doing the clutch on my '96 pickup, I found the other end of the mystery trailer harness wires! They are in the harness for the taillights which runs right up the tramerail and comes out under the hood, right next to the clutch and brake master cylinder. The red power wire was already terminated with a ring terminal and a glass 30A inline fuse. There is also a 12V power strip right there with stud connections for the ring terminal. Sweet!
The blue brake wire is just bare - for the end user to figure out where to go with it from there.
You may need to hunt around some, mine were folded back and taped up against the split loom.
Old 10-21-2008, 01:40 PM   #9
Xtreme Measures
xtrememeasures10's Avatar
xtrememeasures10 is on a distinguished road
That must be what that other wire is for. I used those to wire up my line of fire bar. and there was 2 extra wires. one for reverse lights and the other must have been electric trailer brakes. He is right tho look along the L/H frame rail towards the back of the truck. Follow your harness from your tail lights back to the hitch harness. Dont expect a trailer plug. It will be wires cut off just chilling up there somewhere.
Page generated in 0.11348 seconds with 12 queries
