bellcranks no more
what voltage do these want?
took apart my 4x4 switch today,
wiring them would be a breeze, but while im at it, if i wanted to use these LEDs in there, what voltage do they want? ![]() ![]() |
Distracted Longbed Driver
Re: what voltage do these want?
1st question, why do you have a 4x4 switch?
VVV Jackass VVV
good point
bellcranks no more
i got 4x4 on my longbed. didnt you know?
VVV Jackass VVV
bellcranks no more
Educating da masses
Really, it depends on the manufacturer of the LED's, but you'll probably be safe with 3.5v @ 20-25mA
bellcranks no more
damn. im too lazy to look it up. what size resistor do i want to get a 12v (14v) down to a 3.5v?
Educating da masses
According to http://led.linear1.org/1led.wiz?VS=12;VF=3.5;ID=20, you'll need a 1/2 W (470 ohm) resistor per LED. That's assuming they're 3.5v @ 20mA.
JDepp FTMFW!!!
Led's should want 1.5vdc
bellcranks no more
uhoh...
how do i know? |
JDepp FTMFW!!!
Look at the description of these led's. It can give you an idea of voltage and power usage.
Standard LED's: http://www.jameco.com/webapp/wcs/sto...0& rscount=12 Older led's pretty much did well with 1.5vdc. Like any electrical component, you can give it a little extra juice to get more work out of it, but you run the risk of damaging it or shortening it's life. You could get fancy and get small potentiometers so you'd have adjustable voltage to the led's... lol. Here's a nice calculator for led's. Even gives some suggestions on input voltages for LED colors and power usage of the LED's. http://ledcalc.com/ |
bellcranks no more
i guess ill start off with feeding them 1.5V, and if it seems too dim i can step down the resistors
thanks! |
Educating da masses
Don't be surprised if they don't light with 1.5v. Where did you get the LED's from, and what color are they?
bellcranks no more
uhhh the stock 4x4 switch LEDs....... as pictured in post #1
ZR2 mini-truckin'
I wanted to change the LEDS in my actual 4x4 switch, but I heard it was hard, guess I was right huh?
But if you want that old "LED DASH LIGHT" how to thread lists the requirements for the 4x4 switch lights, and he said something about having to remove the covers on the buttons because they have a yellow screen there to dim and color the 4x4 lights. Pretty sure that thread was on s10 forum... if not it was zr2usa I saw it... |
bellcranks no more
im fine with the 'stock' color of them.
and changing LEDs would be easy. just a matter of knowing what to replace them with.... just snip, and solder. |
***JACOBY***
My guess is that the circuit already has a dropped down voltage. They have probably ran them in series. Follow the traces and see if a trace from the main connector plug runs into one side of one LED then out the other side to the second LED and then out of the other side of LED #2 to one side of LED #3. If so, then they are in series and this drops the voltage to each light. If so, you can just solder in your new ones without any resistors. You will need to know which side if the factory circuits are +/- by having them on and using a digital volt meter. On your new LEDs the longer lead will be your + side and the short lead (or leg) is the negative side. Most high output LEDs nowadays have a 2 to 5 forward voltage.
JDepp FTMFW!!!
if they are led's then they will already have their voltage dropped.
bellcranks no more
i cant follow the traces as it goes behind the board... and i cant take it off from fear of breaking it for now. new LEDs? i have no plans on replacing them thanks, but i dont think its getting anywhere... i installed them ignoring the LEDs for now, and ill play around with them later on when i have more time |
I Type Slow Too...
Ryo, maybe you can help me out with this. I have a 4x4 control that I plan on using in my truck also for some accessories but I can't seem to figure out how the buttons are wired up. I must have spend a good half hour last night with the multimeter trying to figure it out. You didn't happen to document which wires do what did you? I'm not too concerned about the lights right now I would just like to get the switches to work.
Oh and I have the 4 button control I don't know if that would make a difference. Right now just being pointed in the right direction would really help. Thanks! |
#24 |
bellcranks no more
![]() it shouldnt be too hard to figure out with a multimeter. you just have to follow the traces. they all have a common, see green wire and then the other ends are separate. (obviously) |
#25 |
I Type Slow Too...
Awesome! That is exactly what I needed to know. I'm going to go mess with mine right now. Thank you!
#26 |
NESS NOOB!!
if your gonna change the color...its easy. the leds there just need removed and new ones put in....and the blue bulb needs a resistor and thats it. i changed mine and it looks a million times better
#27 |
Xtreme Measures
Just plug it back in and make them light, then take a meter to them and see what there input voltage is. get your reading from where the leds are soldered into the board.
#28 |
Location: Tallahassee, Florida User is: OffLine ![]() |
LED voltages vary. But the tech sheets on most of the ones I buy in bulk are 3.2v - 3.8v. There is a Max, Nominal and Min voltage. The higher the volts the brighter the LED will be but it wont last as long.
What color do those light up? Amber? |
