Voltmeter/Gas Gauge Moves When Blinker Is On - S-10 Forum
post #1 of 4 Old 01-10-2009, 11:38 PM Thread Starter
NTL1991's Avatar
User is: NTL1991 is offline
I've only noticed this recently. The previous owner claims that the alternator is new and, in fact, it does look brand new.
The problem is that when I'm idling at a light or parked, my heater will bog down a bit (you can hear the blower motor slow down) and the voltmeter and gas gauge will go down and up, respectively. If I'm stopped at a light with the blower on high, my volts will be at about 9. As soon as I tap on the gas even a slight bit, it raises to near perfect voltage, my headlights get a bit brighter and the blower runs to full speed.
Could this be the regulator? If so, isn't it in the alternator which is new? Also, why will my gas gauge go up (past full if actually full) when the voltage drops? It doesn't move at all like some Blazers I've driven (you take a corner or hit the gas and the gauge moves around)
Nick
1997 Oldsmobile Bravada SmarTrac
4.3L V6 W-VIN w/ 145,000. Automatic Transmission.
Factory 3.73 PosiTrac; Z85 Suspension
NTL1991 is offline
post #2 of 4 Old 01-11-2009, 01:01 AM
My mirror hates my sub
Speedy2222's Avatar
User is: Speedy2222 is offline
Send a message via AIM to Speedy2222 Send a message via MSN to Speedy2222 Send a message via Yahoo to Speedy2222
Re: Voltmeter/Gas Gauge Moves When Blinker Is On
could be the battery
-Speedy
97 s10 - Audioque SDC2.5 15 3.5cu 34 hz
post #3 of 4 Old 01-11-2009, 03:21 PM Thread Starter
NTL1991's Avatar
I have a brand new battery I could swap in and test it out with...
Is that the most likely cause?
NTL1991 is offline
post #4 of 4 Old 01-11-2009, 08:12 PM
Speedy2222's Avatar
no idea, i know when i had my system the crappy interestate battery i had in there i would have a problem with low voltage( not that bad) at idle... now with my optima ylelow top i dont even get the slightest hint of it..
-Speedy
