Truck won't turnover randomly
Old 11-04-2009, 09:13 PM   #1
Photoshop Fiend
ACE2790's Avatar
For about a month now my truck has had a tendency to randomly not turn over. I have plenty of power, but when I turn the ignition...nothing happens, all I experience is the dings and lights and what not. Turn it off, give it a second or two, try it again and it will fire up. Any ideas? Bad starter or we looking at ignition issues? It's a 2000 S10 2.2L, with rougly 143K miles.
Old 11-04-2009, 09:14 PM   #2
forum idiot
orangesonoma's Avatar
Re: Truck won't turnover randomly
could be both...i would check the starter wire at the starter for power during crank
Old 11-04-2009, 09:31 PM   #3
Photoshop Fiend
ACE2790's Avatar
Thanks for the quick response sir, I'll check into that when I can get ahold of a voltmeter.
Old 11-04-2009, 11:20 PM   #4
what?
evanspears1's Avatar
i was actually getting ready to post a thread for the same reason... sometimes it will turn over on the first turn... some times it will take 4-5 turns of the switch, and on a few occasions it has took as look as 10 minutes to start...
dont know if it would matter or not, but it seems to be worse when it is cold otuside... or it could just be piss poor luck on my part...haha
Old 11-05-2009, 01:08 AM   #5
Photoshop Fiend
ACE2790's Avatar
x2, same thing here.
Old 11-05-2009, 01:57 AM   #6
Stepsides are cool
xxannihilationx's Avatar
ignition switch. had this happen a year ago. i think they are like 20 bucks from napa
Old 11-05-2009, 01:59 AM   #7
whore turned lurker
dimerunner88's Avatar
it could be acouple of things,i would do like brian said and test for voltage at the starter control wire for starters.
Old 11-05-2009, 09:04 AM   #8
94 2.2, feel the power?
deathphoenix99's Avatar
I'd check the nut for the main power wire on the starter. Mine came loose a while back. It would start perfectly sometimes, others I would turn it and I just hear a single click then nothing. Voltage and everything was fine though.
My original starter went out a couple years ago, it would start fine sometimes, others it would just spin. The solenoid wasn't engaging.
Old 11-05-2009, 09:48 AM   #9
workin it !
S10dude's Avatar
sounds like ignition switch .....had one in my old chevelle (69) do same thing
Old 11-05-2009, 03:37 PM   #10
Photoshop Fiend
ACE2790's Avatar
Care to elaborate on how to replace this thing?
Old 11-05-2009, 04:23 PM   #11
Stepsides are cool
its in your steering column. I'd love to give more details on it but i can't remember what all i had to take loose to get to it since i can barely remember what i did yesterday much less a year ago haha. alls you have to take off is the cover for the column. you dont have to take off the steering wheel. When you buy the part and look for it on the column you'll be able to find it
Old 11-05-2009, 04:58 PM   #12
Photoshop Fiend
ACE2790's Avatar
Well I'll go out there and check it out, hopefully I can figure out how to take off the column cover.
Old 11-05-2009, 07:56 PM   #13
what?
imma start on the starter wire, just gotta wait till I get home this weekend to fiddle with stuff... I hate working on anything in a college parking lot...
side story - nearly got arrested for working on my truck in a parking lot here on campus... they said I was trying to steal the catalytic converter...haha, was nowhere near that part of the truck, I was replacing the serp. belt tensioner...lol.. moral of the story=cops are dumb!
/end story...
Old 11-06-2009, 02:51 AM   #14
Stepsides are cool
might be too late now but there are 3 hex screws underneath after that it should pop off
Old 11-06-2009, 02:53 AM   #15
Stepsides are cool
/end story...
that would have been terrible if you got arrested for working on your own truck!
Old 11-06-2009, 03:10 AM   #16
what?
ya, the way these dickhead campus cops are around here, Im surprised I didnt, I didnt have any Id on me, the only reason I got let go was b/c I had a key to the thing, and I told them exactly where the title, and insurance was in my glove box when they decided to search my truck...
Old 11-06-2009, 03:58 PM   #17
Photoshop Fiend
ACE2790's Avatar
naw, I still havent done it. Any obvious signs to look for to know its bad?
Old 11-06-2009, 05:28 PM   #18
Photoshop Fiend
ACE2790's Avatar
Ok Update: Just went outside and took the dash somewhat apart, but couldnt get the column cover off due to my tilt steering column. Might try and get a volt meter and see if I can check the volts on the starter/battery cable when I can get it somewhere thats not gravel and I can get it off the ground some.
Old 11-07-2009, 01:07 AM   #19
you could just voltage seek at the 50 terminal on the starter, set the dmm for min/max and check it while cranking. see if voltage is dropping through the switch
Old 11-09-2009, 08:52 PM   #20
Mr. Fix-it Perfectionist
my_nightmare's Avatar
Arrow Re: Truck won't turnover randomly
Hi there.., I work as a mechanic. Try the following:
1) grab a partner to turn key and u get under truck to test the switch wire with volt meter. it should be 12 volts with the key is in the "CRANK" position....
(If not.., suspect the switch on the column.., if it factory switch and factory column.., post back and I can give ya details on how to replace it...)
1.5) check the fuses for the start in fuse box...( i have seen shorted fuses do this same issue as well...)
2) if you got 12 volts at switch wire..., check the volts from battery wire on starter.., it should be 12 volts as well... (if not suspect cable OR connection at battery...)
3) check all connections at battery to make sure they are no corrosion or that it has got a definite good connection to battery.(alot I seen, light up dash.., but at random times wont crank either....)
4) if all of the above is good..., i would go with switch on column.., they do have a tendency to fail alot due to how they are made nowadays... ( if new switch has been installed.., suspect the starter then.)
Hope this helps..., and if it the switch.., and u want to install it.., post on here again.., i will tell ya what I know on how to install it in details...
l8taz
Allen
Old 11-12-2009, 02:37 PM   #21
Photoshop Fiend
ACE2790's Avatar
The first thing I did was clean the connections at the battery and make sure everything was tightened down, so that shouldn't be an issue.
I'll look into the fuse thing this afternoon, but it might be like two weeks before I am able to get the truck home and on jack stands to check all that stuff out.
Can you tell me where the switch wire is on the underside of the truck?
Old 11-17-2009, 12:55 AM   #22
switch wire - it usually is a little 10# or 12# purple colored wire(on most gm's.., others its different colors) that is connected to a single small post on starter.... I believe the starter is on the ppassenger side under the truck near bottom of engine....
Old 11-19-2009, 11:20 PM   #23
Forbidden Love's Avatar
Im having this same problem on my 2000 S10 2.2l. Ill turn the key and get just the battery light but engine is turning normal but wont start. Ive noticed a pattern though. if i turn the key on and all light come on and i hear my fuel pump pump it will start right up. The fuel pump only come on when the check engine light comes on. If i turn the key and no lights engine will turn but not start. Ill keep trying 2,3-4 how ever many tries but as soon as that check engine light come on and fuel pump it will finally start. Went to Autozone todays and they said it sounds like the ignition switch in the steering colum might have bad contacts. And $65 part.
Page generated in 0.59159 seconds with 31 queries
[Output: 118.17 Kb. compressed to 109.01 Kb. by saving 9.16 Kb. (7.75%)]
